Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Nov 2012, 10:12   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
Intel backs away from Itanium, plans Xeon drop-in chips
Future motherboards will support Itanium or Xeon.
http://www.bit-tech.net/news/hardwar...rops-itanium/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 9th Nov 2012, 12:25   #2
fellix_bg
What's a Dremel?
fellix_bg has yet to learn the way of the Dremel
The founding issue with Itanium is that its EPIC architecture philosophy is simply too far removed from the modern trends in the industry, like power efficiency, uniform top-down scalability (from mobile to server) and broad software compatibility. And the thing is just too expensive to build, since to be an efficient ISA it needs a ton of cache memory to keep the static scheduled wide pipeline fed with data and instructions.
fellix_bg is offline   Reply With Quote
Old 9th Nov 2012, 20:35   #3
Alecto
Minimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
And a ton of cache is what it does have. Since these are premium chips it doesn't matter that Intel has to spend more die area on cache - the customer pays for it anyway.
Alecto is offline   Reply With Quote
Old 10th Nov 2012, 07:18   #4
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
Holy crap, Larry Ellison was right!?
fluxtatic is offline   Reply With Quote
Old 10th Nov 2012, 16:47   #5
greigaitken
Multimodder
greigaitken has yet to learn the way of the Dremel
holy crap, i thought this thing was burried years ago
greigaitken is offline   Reply With Quote
Old 12th Nov 2012, 06:56   #6
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
just plain old holy crap!
Griffter is offline   Reply With Quote
Reply
Tags
amd64, cisc, epic, hp, hpc, ia-64, intel, itanic, itanium, opteron, risc, x86-64, xeon
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
