Reply
Thread Tools View Mode
Old 9th Nov 2012, 15:59   #1
Alan5510301
What's a Dremel?
Alan5510301 has yet to learn the way of the Dremel
Project Ethereal (Formerly "Unnamed")
I would like to welcome you to my first scratch build.
I needed a PC case for my first PC build so I designed a small, compact yet elegant PC case.
Specs:
CPU: i5 2400
Ram: Kingston Hyper-X 8 GB (4x2)
GPU: ATI Radeon HD 6870
MB: ASRock Z68 Pro-3M
And some old hdd's
I live in Minas, Riau, Indonesia, in a forest -____- Literally
So I don't have alot of Materials and tools to choose from.
I will be primarily using plywood
And I MIGHT not have alot of free time, so you might not hear from me often.
The current status of my PC (Taken with phone)
Yep, This is my backyard (They're eating guavas, Again, I live in the middle of a jungle )
DESIGN
I wanted to get as small and compact as possible yet have room for more HDD's and a few upgrades.
The pictures should explain everything.
LET IT BEGIN
The GPU (I took off the faceplate)
I started taking off the metal thing on the side for mounting (What the hell is it called? )
Here it is without the thing
ASRock
It clearly says, Z68 Pro-3M
I already installed the CPU that's the generic Intel CPU Fan
The Wifi I'm using, Apple's AR5BXB72
Using tape to... Well, make it stick
My Arsenal of Hard Drives Total of 1 TB and 700 GB
The Hyper-X Ram sticks
Hyper-X Mounted
The SATA cables, need to be one color, going to paint them black soon
Thats it for tonight, Im gonna hit the sack, its 12 AM here, got school, need to wake up at 6 -_-
Alan5510301 is offline   Reply With Quote
Old 9th Nov 2012, 16:55   #2
Lance
I ate Bhindi Bhaji.
Lance's Avatar
Lance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on you
Nice.
Looks cool, sort of like Gtek's HTPC.
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is offline   Reply With Quote
Old 9th Nov 2012, 18:43   #3
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
love the case!
kinghong1970 is offline   Reply With Quote
Old 10th Nov 2012, 13:54   #4
Alan5510301
What's a Dremel?
Originally Posted by kinghong1970 View Post
love the case!
Originally Posted by Lance View Post
Nice.
Thanks! Yea I looked at Tenuis after I made some plans for this, Tenuis looked great, so I made a few adjustments I just hope that this case will be as nice as that
Old 10th Nov 2012, 16:55   #5
Alan5510301
What's a Dremel?
Quick update:
Cut some plywood, glued some hinges, and painted the wifi
Pics:
Old 10th Nov 2012, 18:00   #6
ShinyAli
Supermodder
ShinyAli's Avatar
ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!
Cool, you have wi-fi in the jungle or does wi-fi stand for wild-fings
ShinyAli is offline   Reply With Quote
Old 11th Nov 2012, 18:29   #7
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
Nice wood colour! This is going to be interesting!
Ra6 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
