#21 |
Minimodder
Time for closing the case with some panels
![]() Front panel - vents for the rad (2x120mm) and intake (120mm) for the bottom compartment (just in front of the HDD cage). Also two USB 3.0 ![]() ![]() Right side panels - intake for front rad.
#22 |
Banned
Great start! Looks like its going to be quite rugged! Gotta say, love welding parts onto a pc case
#23 |
Minimodder
Update - modding the top panel.
![]() ![]() inside 80% ready.
#24 |
Supermodder
great metal working skill! love the way you build, it's just to bad i really don't like that kind of screws... =P
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#25 |
Minimodder
#26 |
Minimodder
Top panel ready.
![]() Big side window installed. ![]() ![]() Cover for the rear fans mounted.
#27 |
Supermodder
Built like a tank! This thing would survive a nuke! Nice job.
#28 |
Minimodder
Small update - coolant temp gauge installed and power / reset buttons.
![]() HDD cage and ventilation for the PSU.
#29 |
Minimodder
All the panels are ready
![]() ![]() ![]() ![]() Now it's time for sanding and painting. |
#30 |
Minimodder
Update.....
![]() ![]() ![]() Next pics will be with the case painted |
#31 |
Minimodder
Preparation for painting.
![]() ![]() ![]() ![]() Primer applied ![]() ![]()
#32 |
Minimodder
Case painted. The colour of the paint is "metallic black" .
![]() ![]() Wheels mounted for easier movement of the case and airflow for the PSU. ![]() It is a lot better now with the paint, what do you think ? |
#33 |
What's a Dremel?
I really like this project a lot! I joined the forums just so I can sub to this thread and like 2 others (usually I just lurk the forums). I've been following since the beginning, can't wait to see what you will do with it
The paint/sand job was awesome! Keep up the great work!
#34 | |
Minimodder
Next step is to apply some anti-noise/vibration material where needed. ![]() ![]() ![]() ![]() Next step will be installing hardware. |
#35 |
Minimodder
Merry Christmas everyone.
Seems to have been very good this year, because look what I found under the christmas tree. ![]() ![]() But first let continue with the assembly of the case. ![]() ![]() Mid-plate with acoustic absorption material. ![]() ![]() I forgot to make a cpu rear bracket opening for changing coolers without dismounting the motherboard, so ...... ![]() ![]() First harware added to the case was the PSU. ![]() Next step will be mouting the motherboard and starting to assemble the watercooling . |
#36 |
Minimodder
Happy New Year boys and girls
![]() Lets continue from where we left off.... motherboard intallation... ![]() Positioning the reservoir and rads. ![]() VGA in place. Now it's time to think about the tubing routing. ![]() The tube passing behind the 360 rad will not be visible after i install the fans.
#37 |
What's a Dremel?
Looking great so far!
Looking forward to more!
#38 |
Minimodder
Update!
![]() I know that the tubing between the two gtx 460 is not right, but i run out of 90 degree compression fittings. So until the parts arrive ..... ![]() The bottom compartment is a little messy, but it will be arranged later ![]() ![]() Tell me what you think so far |
#39 |
Minimodder
more pics ......
#40 |
Supermodder
color does a lot with a piece of steel
![]() keep em' updates coming!
__________________
| Thread Tools | |
| View Mode | |
