Reply
Thread Tools View Mode
Old 16th Jan 2013, 13:21   #41
makarov7
Minimodder
makarov7 has yet to learn the way of the Dremel
Originally Posted by kelmannen View Post
color does a lot with a piece of steel
keep em' updates coming!
Yes you are right! Good paint is 50% of the look - like rims and cars
In my build there is no plastic, so it's easier to paint (no need to match color on metal and plastic).
Now it's time to make this case glow I am putting some RGB lights with a controller.
Some test with the colors and the brightness.
makarov7 is offline   Reply With Quote
Old 18th Jan 2013, 13:51   #42
makarov7
Minimodder
Closed bottom compartment with filters installed.
Plate dividing front rad from the main case installed.
Old 20th Jan 2013, 13:03   #43
makarov7
Minimodder
Case closed up with all panels
Old 24th Jan 2013, 12:48   #44
makarov7
Minimodder
Old 24th Jan 2013, 22:12   #45
Ream
Multimodder
Ream's Avatar
Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!
Nothing beats seeing an old case being made in to something that not only looks sweet but has better functionality than it originally had.
Amazing job, now just wish I could weld.
Ream is offline   Reply With Quote
Old 28th Jan 2013, 09:08   #46
makarov7
Minimodder
It's not so difficult, it's just a matter of practice thanks for the support !
The new fittings arrived, now the tubing between the cards is looking a way better
Old 8th Feb 2013, 19:41   #47
makarov7
Minimodder
New card in the system
I chopped it a little and made it a hybrid .....
Now the card have liquid cooling for the chip and air cooling for the rest. Also added some heatsinks to help the fan colling the PCB. (pics of that later - forgot to take photos )
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
