Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Nov 2012, 10:04   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Intel details NUC specs ahead of launch
Dual-core 1.8GHz Core-i3 in a 100mm-square box.
http://www.bit-tech.net/news/hardwar...12/intel-nuc/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 12th Nov 2012, 10:12   #2
proxess
Hypermodder
proxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysis
35$ vs 300$ I don't see how this is going to fend off the Raspi, especially seeing you can build a similar MicroATX PC for probably half the price.
It definitely doesn't have the same impulse-buy effect as the Raspi did on me, seeing that I bought two Raspis.
__________________
Laptop: i3 330M 2.13GHz; 2x 4GB 1066MHz; Radeon 5650 1GB @ 675/1020MHz; Crucial M4 256GB SSD; Ubuntu 12.04 x64 and Windows 7 x64.
Ubuntu #8076 / Linux #429448
proxess is offline   Reply With Quote
Old 12th Nov 2012, 10:21   #3
derviansoul
Minimodder
derviansoul has yet to learn the way of the Dremel
You are definitely right. However i can see this to be a decent htpc or for a microserver , just hope the uk price matches the expectations.
derviansoul is offline   Reply With Quote
Old 12th Nov 2012, 11:39   #4
Pookie
Need's a Holiday!
Pookie's Avatar
Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!Pookie - it's over 9000!!!!!!!!1!1!1!!!
As has already been said really, you can put together an equal if not better system using matx for half the money. And have upgrade options, you also dont have to bin the whole setup if something fails.
__________________
Fractal R4/ GA-X58A-UD3R / i7 920@3.8Ghz / Corsair H60 (2013 Model) with 2 x Corsair SP120 / Corsair Force GT 120 SSD /Sapphire 6950 (6970 mod) / 12GB (3x4GB)Corsair Dominator 1600mhz with Airflow Kit / AOC i2757fm 27" IPS Monitor
http://www.compu-care.co.uk/
Pookie is offline   Reply With Quote
Old 12th Nov 2012, 12:48   #5
asura
jack of all trades
asura's Avatar
asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.asura is a hoopy frood who really knows where their towel is.
Yes, but it still makes it a bit of a kick in the teeth for VIA... RasPi killer - no way, it's priced to high. Nano x2 killer, it's still a bit expensive - but a) a lot of people are going to buy it just because it's a better known brand and b) it's even smaller than MTX 100cm2 vs 289cm2...
asura is offline   Reply With Quote
Old 12th Nov 2012, 18:41   #6
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for president
and it will run windows
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 12th Nov 2012, 19:02   #7
Anfield
Supermodder
Anfield has yet to learn the way of the DremelAnfield has yet to learn the way of the Dremel
I'd think of it more as a far cheaper mac mini alternative than a Raspi competitor.
Anfield is offline   Reply With Quote
Old 13th Nov 2012, 05:58   #8
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
$300 and no RAM or storage? Nah, I'll pass. Granted, we're talking two different markets, but odds are good I'd be looking at this for the same purpose as AMD E350 boards....which can be had for less than $100.
Like asura says, this could crush some of Via's offerings on performance without being out of line on price.
And, unless I missed something, HD4000 is your only option? Not going to fly for HTPC types, I'd guess. Let's see it once Haswell/Broadwell comes along and it may be worth the money. It might do well in the modding community and boutique builders, but it's not worth my money yet.
fluxtatic is offline   Reply With Quote
Old 13th Nov 2012, 21:38   #9
Anfield
Supermodder
The $300 for the cpu + board + case isn't that bad if you consider MSRP for the Cpu alone is $225... http://ark.intel.com/products/65697/...Cache-1_80-GHz
Old 13th Nov 2012, 22:08   #10
Gradius
IT Consultant
Gradius has yet to learn the way of the Dremel
So basically they are selling CPUs with a good boost on profit!
Gradius is offline   Reply With Quote
Reply
Tags
arm, core-i3, intel, microcomputer, next unit of computing, nuc, qualcomm, raspberry pi
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
