Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 13th Nov 2012, 03:08   #1
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
Headphone/Headset Suggestions
Hi guys, ok so my current headset needs to be sent back, Mic has stopped working two months into use. I am going to send it back and spend a little bit more money.
I have a SpeedLink Medusa 5.1, so 5.1 audio is proffered as I have gotten used to it. I want to spend around £150. I have looked at several suggestions and whilst I do like the look of the Razer Carcharias I do want 5.1 audio.
So suggestions please guys. Too much to choose from.
__________________
MrDomRocks is online now   Reply With Quote
Old 13th Nov 2012, 07:19   #2
dancingbear84
Ultramodder
dancingbear84's Avatar
dancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpitdancingbear84 is almost as Godly as yodasarmpit
I'm not an audiophile but I got a Logitech g35. It is virtual 7.1 surround as opposed to actual surround but I'm very happy with it. It is USB and currently available for around 80 pounds from tesco. There are some reviews that state it is uncomfortable, I have a big head and I can find a comfortable way to wear it by changing the padded head support and adjusting the ear cups lower. In terms of weight you know that you are wearing it, but it is not uncomfortable. Being Logitech you know that there is the support in case anything breaks and the build quality is good and the drivers will work. When used for bf3 and other games I find them great. For music they are a bit worse but by no means bad.
To be fair though this is the first decent headset I've owned, in the past I've always bought chepo sub 10 things or used headphones that came bundled with phones or other devices.
__________________
Intel i5 2500k * Corsair H50 * 2 x Gkill Ripjaw Z 4gb * Asus Maximus V Gene * Evga 560Ti * OCZ Vertex 3 * 1 TB Samsung F2 * Antec Truepower 650* Fractal R3 * Win 7 Home Premium 64bit * LG 27" w2753vc
upgrade list:Blu-ray drive
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is online now   Reply With Quote
Old 13th Nov 2012, 07:58   #3
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Dom, you play BF3, the simulated 5.1 in that is pretty much just as good an effect as you'll get from a supposedly 5.1 headset.
I owned the G35s - the sound quality is excellent - definitely better than the carcharias. But: in my opinion, the 5.1 effect isn't really up to much (same with any 5.1 headset).
Dancingbear - do you have any problems with sound balance when Dolby headphone isn't on? Like its a lot louder in one ear than the other? That happened with both pairs that I owned.
When I first got the G35s they were very tight and painful, but after a while of wearing them they eased up, and were fine.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 13th Nov 2012, 10:11   #4
hamza_tm
Mod Master
hamza_tm's Avatar
hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.
If you have £150 and want the ultimate surround experience you can get, just buy the Sennheiser HD598 headphones (and cheap mic).
I know you said you prefer actual 5.1, but trust me these things will blow you away in the surround sound department. Audiophile grade cans that will also take your music and movies to an entirely new level, with such a realistic soundstage it'll shock you. Buy them and listen to that virtual Barber shop video on YouTube...
When I got mine I was blooown away, and I've tried Beyerdynamics DT770, DT880, Sennheiser PC360 and more.
Edit: a £20 Creative X Fi xtremegamer completes the package if you want a virtual surround system too.
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz (no moar IPS xD) | X-Fi XtremeGamer | Corsair 550D | GTX680
CM Storm Quickfire Rapid MX Brown (Filco caps) | Steelseries Xai (yay) | Sennheiser PC360 | Steelseries 9HD
hamza_tm is offline   Reply With Quote
Old 13th Nov 2012, 10:22   #5
majnu
What's a Dremel?
majnu has yet to learn the way of the Dremel
If you want one with a built in mic then the Sennheiser PC360 or even the u320 are good.
If you want a studio headset and can live with a dangly clip on mic then the bredemeyer dt 770 pro's won't disappoint.
majnu is offline   Reply With Quote
Old 13th Nov 2012, 11:56   #6
MSHunter
I *am* a Dremel
MSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpit
I got a Logitech 930 ("real") surround head set im looking to sell if your interested.
I have moved on to HiFi headphones and would like to sell them to some one who would make use of the surround features.
-I am allowed to say that here right?
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 13th Nov 2012, 16:34   #7
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Woah lots ogre suggestions. I will have to take a look at each one and see which i like the most.
I never really thought about getting a sound card. I am no audiophile so it never overly bothered me.
__________________
Old 13th Nov 2012, 16:58   #8
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
If your spending that much on a headset I would recommend a sound card. I got a £35 headset, and a sound card does make it sound better, and higher end models are meant to benefit more.
fdbh96 is offline   Reply With Quote
Old 13th Nov 2012, 17:15   #9
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Ok adding a sound card to my list. This is getting expensive.
Going to buy an all in one headset. And sound card.
__________________
Old 13th Nov 2012, 18:02   #10
sniperdude
Supermodder
sniperdude's Avatar
sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.
yeah mate even my old Audigy 4 sound card is far better than any onboard sound...the ASUS cards got raved about but I think I see more reports of issues with them more than anything these days.
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W.
sniperdude is offline   Reply With Quote
Old 13th Nov 2012, 18:05   #11
MSHunter
I *am* a Dremel
the g930 is USB so that would save you a sound card.
930 stats
__________________
Old 13th Nov 2012, 18:16   #12
fdbh96
I *am* a Dremel
fdbh96's Avatar
I think it would make up the difference, e.g £120 for the headset and £30 for the sound card. Plus, if you buy a pcie one, it should last for multiple builds/headphones.
Old 13th Nov 2012, 18:22   #13
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Hahaha good spot, I had realised getting a USB Headset defeats getting a sound card.
i have been offered a sound card at a bargain price. So looking into my options.
I may have to increase my budget a little. I have looked at the Sennheiser HD598 I think they will do the job and look sexy on my head. I am all about the visuals and how well they perform.
That plus a sound card and I am thinking of picking up http://www.scan.co.uk/products/blue-...ne-gloss-black as well.
So all in all over £200......
Not to mention I am sending my Speedlink Medusa's back as the Mic has died.
__________________
Old 13th Nov 2012, 18:56   #14
hamza_tm
Mod Master
hamza_tm's Avatar
You won't be disappointed with the HD598
Thing sounds amazing.
__________________
Old 13th Nov 2012, 19:20   #15
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.Yslen is the Cheesecake. Relix smiles down upon them.
This. I want the 598's myself, they're on my wishlist.
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H50-1 - G.Skill Ripjaws X 2133MHz - Gigabyte HD6870 - Crucial M4 - Samsung HDD - 530W ThermalTake SS PSU - Bitfenix Prodigy - LG IPS231P - R.A.T. 5 - Cherry G80-3494 (MX Red) - Ducky YotD (MX Brown)
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 14th Nov 2012, 08:16   #16
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Well I am sold on them, I have always like sennheiser I have some headphones somewhere that I gave to my mom as she hated her ear buds.
I am also going to buy a Blue Snowball Mic xD
__________________
Old 14th Nov 2012, 08:28   #17
MSHunter
I *am* a Dremel
Samson GO Mic is where quality mics start. I am very happy with mine.
__________________
Old 15th Nov 2012, 05:16   #18
sniperdude
Supermodder
sniperdude's Avatar
I have the HD595's myself mate, I think they're awesome, the HD598 are said to be even better but not by as enough to be upgrade worthy but if I was buying again I would get the HD598 myself.
I would spend less on a mic and more on a sound card tho
What kind of sound card are you thinking of?
__________________
Old 15th Nov 2012, 09:29   #19
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
I have been offered creative hd titanium for a reasonable price. I the Mic is for my youtube content as well as talking to you guys on VOIP. When I have the free time around work I am going to be putting together some content for my channel.
And to do that I need a decent Mic as the desk one and my current fault Headset Mic arent very good.
I am unsure about sound card as my current music files are mostly mp3 and AAC from Itunes. I have never had FLAC files or super high quality audio needs. Obviously once I have the Headphones I will test to see if I can hear the difference in audio quality.
__________________
Old 15th Nov 2012, 09:47   #20
jizwizard
stop your grinning and drop your li
jizwizard's Avatar
jizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpit
trust me you will hear the difference mate with that sound card and headset. night and day
__________________
Bitfenix Prodigy / Asus p8z77-I deluxe / 2700k@5.2 / Samsung 2x4gb @ 2400mhz /
Hx1050 (overkill) / Gtx570 (soon to be 690) / 2x64gb M4 / WD 3tb book / BenQ 2410t
G19 / G27 / and some watercooling for good measure
jizwizard is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
