Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Nov 2012, 11:03   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Zalman FX100 Cube passive heatsink leaks
First image snapped ahead of launch.
http://www.bit-tech.net/news/hardwar...n-fx100-cube/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 14th Nov 2012, 11:21   #2
proxess
Ultramodder
proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.
That title was a bit misleading. I thought it was a water-cooling system that leaked for some reason.
__________________
Clevo P150SM: i7 4930MX @4.2GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB +220MHz Core/+350MHz Memory; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 14th Nov 2012, 11:24   #3
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Originally Posted by Article
designed to work through a process of convention
Convection maybe?
Looks interesting, I'm wondering how they'll achieve a high enough airflow passively to cool higher-end CPUs.
Maki role is offline   Reply With Quote
Old 14th Nov 2012, 11:25   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Maki role View Post
Convection maybe?
Eerr, quite. Fixed, ta!
__________________
Old 14th Nov 2012, 12:00   #5
Sc0rian
Here comes the farmer
Sc0rian's Avatar
Sc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run Crysis
i was confused by the title too.
FanlessTech, that is a cool website some really cool products posted there.
__________________
\o/
Sc0rian is offline   Reply With Quote
Old 14th Nov 2012, 12:02   #6
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
Convection maybe?
these modern spell checkers that change correctly spelt words are a bitch, lol ;-)
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 14th Nov 2012, 12:42   #7
Deders
I Mod, Therefore I Own
Deders's Avatar
Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.
What happens to the convection when it's put on it's side like in most cases?
__________________
i7 6700K @4.6GHz - Asus Z170 Deluxe - Noctua NH-D15 - Gainward Phoenix 1080 GLH 8GB @2050 & 11000 - 16GB Gskill RipjawsV DDR4 @3200 - Corsair HX850i - Nanoxia Deep Silence One - Samsung 950 Pro NVMe - Samsung Spinpoint F3 1TB - WD RE4 2TB - WD Caviar Blue 640 - Dell U2913WM Ultrawide - Logitech G19 - Corsair M65 - Sony STR-DN1050 Receiver - Q Acoustics 2000i 5.1 speakers.
Deders is offline   Reply With Quote
Old 14th Nov 2012, 13:03   #8
p3n
Hypermodder
p3n has yet to learn the way of the Dremel
Presumably referring to the gas/liquid in the heat pipes with a very low boiling point (not [greatly] affected by gravity).
p3n is offline   Reply With Quote
Old 14th Nov 2012, 13:19   #9
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Looks like you're strapping a fridge to your CPU...
GeorgeK is offline   Reply With Quote
Old 14th Nov 2012, 13:58   #10
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
for something that's supposed to rely on passive airflow, why the hell did they block off a significant portion of their air-path?
ChaosDefinesOrder is offline   Reply With Quote
Old 14th Nov 2012, 14:07   #11
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
That's why I prefer the Nofan CR-95 (also available in pure copper)
GuilleAcoustic is offline   Reply With Quote
Old 14th Nov 2012, 14:37   #12
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
I don't think they did. I think the 'corner pieces' are there to make it all rigid and appear to maybe to route the heatpipes though?
If anyone call pull this off it's Zalman. Their passive heatpipe cases were state of the art (at the time) and I have a heatpipe cooled PSU of theirs that's been going strong (and cool) for many a moon.
Guinevere is offline   Reply With Quote
Old 14th Nov 2012, 16:04   #13
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Because of the same way a chimney works maybe ?, pulling cool air in at the bottom and extracting it at the top
Corky42 is offline   Reply With Quote
Old 14th Nov 2012, 18:22   #14
AiA
Multimodder
AiA has yet to learn the way of the Dremel
I think its hollow and is like what GuilleAcoustic said http://www.hardwarelook.com/images/u...5C/large/8.jpg
but square shaped
o and under that advert is says 'fanless tech' on the picture
AiA is offline   Reply With Quote
Old 14th Nov 2012, 19:02   #15
Bakes
Hypermodder
Bakes has yet to learn the way of the DremelBakes has yet to learn the way of the DremelBakes has yet to learn the way of the Dremel
'Impressive performance'? By that I hope you mean 'cools the cpu to a level where it won't blow up on stock settings'. Seriously. If they can manage that passively, then that's impressive enough for me.
Bakes is offline   Reply With Quote
Old 14th Nov 2012, 20:05   #16
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
bous air cooling from back of motherboard as it bends like crazy
greigaitken is offline   Reply With Quote
Old 14th Nov 2012, 20:11   #17
greigaitken
Supermodder
*bonus
Old 15th Nov 2012, 07:32   #18
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
I'm no thermal engineer, but like Deders said, how the hell is this supposed to work via convection when it will be sideways in the typical case? Ah, well, I'll wait for the reviews.
Also, keep in mind the TDP of Ivy Bridge tops out at 77W. This might work brilliantly for those and even SB @ 95W. You might want to avoid sticking it on your AMD FX-8350, though
fluxtatic is offline   Reply With Quote
Old 15th Nov 2012, 10:55   #19
Skippylee
Now then!
Skippylee's Avatar
Skippylee has yet to learn the way of the Dremel
Here is some more information from Zalman - http://www.zalman.com/global/Contact...Menu=1&idx=699
Skippylee is offline   Reply With Quote
Reply
Tags
cpu cooler, cpu heatsink, fanless cooling, fx100 cube, heatsink, passive cooling, passive heatsink, zalman, zalman fx100 cube
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
