#41 | |
LIKE AN ANIMAL!
Can't wait to see this beast finished with proper toned-down lighting & leak-protection.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#42 |
Beyond Complexity Lies Simplicity
Here is another weekend update !
Made the alu cover plate and a plexi strip around the mobo ![]() ![]() The reflective properties of the HDD platters are gonna create more depth and angles into the design! ![]() ![]() Cant decide if I am going with the black or uv green tubing. ![]() I am leaning towards green so I will leave it in for now. ![]() ![]() That was it for this weekend. Maybe a small update tomorrow.
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#43 |
Ok, guys. I was getting a little worried about the amount of green in the case.
With the green tubing (still havent decided yet) and the green coolant and the green plexi. It might just be a little much. Also green tubing with the BORG. never seen that before. So I tried this. I got a box of PE flexible hosing normally used for electriocal work and cut it open. Dont look at the exact cuts yet, just did this in like 10 minutes or so, just to get an idea for the effect. What do you think? Changes the whole feel of the case doesnt it ? But does it change it in the right direction ?
__________________
#44 |
Addicted to modding.
Oooh i see what you mean, the borg is mainly green accents and lighting, as far as the borg race goes there all black silver n gun metal. I guess the tubing does look a bit biohazard, but really cool!
I think with green lighting, acrylic sections and seeing the green fluid in the blocks, i think there will be enough green for you to safely use all black on the tubing... or spray the tubing a gun metal/dark silver colour. |
#45 |
Fenrir The Wolf
Yo done great thing with tubbing,it looks like Borg implants on drones.
Don't forget to put some red lasers for scanning.
#46 |
Multimodder
A big case made even bigger! Tha'ts a perfect match for the colors! And this black tubing in combination with the green ones is amazing! But be careful with the cut
#47 |
Do you even mod, bro?
This is awesome!
I've used flexible PE hosing before, for a couple of wires I couldn't be bothered to sleeve - it worked very well. In your case, it does look cool, but on a couple of the bends its gone 'fat' and makes it look a little unprofessional (probably only noticable because the finish of the rest of the build is so good). I wanted to ask you by the way, what do you use to cut the aluminium (and how thick is it?). I've been loving acrylic recently, but that's just because its so easy to work with.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#48 |
Supermodder
Like what youve done with the cable tidying trunking , Very good idea =)
#49 | ||||
Thansk! It often the most simple idea's that work best !
__________________
#50 |
Keep calm & mod on. =)
Very nice ASPHIAX.
#51 |
Thanks man !
ps Gave you a +1 star as per request, but it should have been a +11 mate !
__________________
#52 |
*learning english*
TBH i don't get how Your loop works... especially at the part of gfx and board block...
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#53 |
Maybe this picture will help.
![]() At the white arrows all the pressure is the same as the tubes are all connected together. At the blue arrows all the pressure is the same they are all connected together and no collant can flow back into a block . (this is where I need to test out the config as I have not yet seen anyone integrating the SB block also and the restriction might be different)
__________________
#54 |
Modder
ASPHIAX, try use clear tube and UV water ... I think under the UV light is very cool!
#55 |
This is uv reactive tubing !
__________________
#56 |
Modder
#57 |
MD of Mutant Zombie Armies Inc
Had a thought about your excess of green, you could use clear non-uv tubing then mix black dye with uv green. That way you get the subtlety of the black with a sneaky peak of green.
http://www.specialtech.co.uk/spshop/...-pid-3414.html Plus http://www.specialtech.co.uk/spshop/...pid-16820.html Plus http://www.specialtech.co.uk/spshop/...pid-16817.html Equals awesomeness
__________________
Project: RAt MoD - Update 16th June '13 - Deliveries of the Banned i5 3570K, ASUS Maximus 5 Gene, Gainward GTX 670 Phantom, 4GB 1600MHz G.Skill RipjawsX CL6, Modded Antec Kuhler 620, Enermax Revolution 1050W, WD Raptor 150GB , Antec P182 How to Get a FREE (sort of) Hard Drive and Other Small Parts |
#58 | |
He suggested the UV green and emerald green dye so i already tot that in House. But mixing in black is also a good idea. If the emerald doesnt deliver, i'm going to try that! Thanks man!
__________________
#59 |
Pipebender
I like that split hose look,very BORG....
#60 |
Thanks man, will be working my @ss off this weekend trying to get it as far as I can.
Trying to get it all painted up. Powder is going to take too long. Maybe in phase II of the build
__________________
| Thread Tools | |
| View Mode | |
