Reply
Thread Tools View Mode
Old 27th Nov 2012, 09:02   #61
BOBDBONE
Owner at BS Mods
BOBDBONE's Avatar
BOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the Dremel
This would make the Borg proud!
Great work man. Super clean build. Love it.
__________________
_______________
www.bsmods.com
BOBDBONE is offline   Reply With Quote
Old 28th Nov 2012, 07:54   #62
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Thanks man!
Its decision time. Should I go for the small or large window...
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 28th Nov 2012, 09:41   #63
gungravevn
What's a Dremel?
gungravevn has yet to learn the way of the Dremel
I would say large since your SSD window is amazing.
gungravevn is offline   Reply With Quote
Old 28th Nov 2012, 20:36   #64
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks !
I am thinking of 2 windows now. 1 for the midsection and one long small one for the SSD's.
Gonna look into this tonight.
Keep you updated !
__________________
Old 29th Nov 2012, 03:53   #65
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
i like the idea of two separate windows, could look great!
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 30th Nov 2012, 19:13   #66
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks but plans have changed again !
Will post an update soon.
__________________
Old 30th Nov 2012, 19:44   #67
ASPHIAX
Hypermodder
ASPHIAX's Avatar
This is what I like about modding. You think you got something planned out and when you do the work, you have to think on your feet as it doesnt turn out the way you planned it !
I was planning on doing a double window. The second window would have been where the X was marked with tape. (please note this is the rough cut, it needs a couple of hours of love to be perfect!)
BUT ...
Look at the size of that hole between the door and the case itself. In this picture you can look into the door.
But even with a piece of alu posing as the rim I wanted to create, you can still look behind the door. This doesnt look right. Just does not have the feel I want to get with this build. It almost feels like an after thought.
Also the second window would become very thin and cover most of the SSD's. It would let you see on the top left ...per-x and bottom right king... (normally Hyper-X and Kingston)
This wont do either !
The side is not the only one with a large crack. Gotta figure something out for this.
So this is waht I will do. I will widen the rim for the window so that it will align with the midplate of the case. This will also funtion as a stop for the warm air. The 480 rads cannot push their warm air up anymore. 2 problems solved in one !
It also just looks better imo. The SSD's will be visible only with the door off.
Door Challenge nr 2 !
As I have 2 x 480 rads in the bottom and the case comes with ventilation slots for 360's I need to change the door in that aspect also. The ventilation slots I have cut out for the window I will cut up and place them in the bottom.
So the rest of my weekend will be spent getting this filed up perfect and glued into position.
Not a small job. But still having fun !
__________________
Old 30th Nov 2012, 23:58   #68
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Wow! Well done,mate.
Pranja is offline   Reply With Quote
Old 2nd Dec 2012, 13:22   #69
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks man !
__________________
Old 2nd Dec 2012, 13:23   #70
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Not so spectacular work yesterday, spent most of the day planning stuff.
Did do some work though!
Location of the pump and the hole for the psu cables.
I will make a alu wall between the pump and the psu for safety
Tubing out of the pump that will be routed through the backplate into the rads
Topside air intake and tubing passthrough!
All sorts of cabling for cable management
Time to get creative on the BORG door!
Guess what's coming here ??
__________________
Old 2nd Dec 2012, 13:30   #71
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
Sculpting a door?
This thing looks beautiful, man.
KrunchR is offline   Reply With Quote
Old 2nd Dec 2012, 14:39   #72
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.
Holy **** balls! This is awesome!
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 3rd Dec 2012, 09:39   #73
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Originally Posted by KrunchR View Post
Sculpting a door?
Thanks ! Yeah I got something special in mind for that door!
LOL, thanks man !
__________________
Old 3rd Dec 2012, 20:10   #74
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Here is a quick update.
Made the missing plexi ring for the bottom fan.
Damn for forgot the mesh ..
SSD drive bays. Love my alu bender
Started on the door. This is the rough design for the work.
The idea is to make a multilayered cube with lasers, uv plexi and some kitbashing.
Need to decide if I am going for the white traditional panelling or the cube appoach
Fan grills for the warm air of the 480 rad
the cube approach
__________________
Old 3rd Dec 2012, 21:16   #75
KrunchR
Supermodder
KrunchR's Avatar
The cubes are cool looking. Could you do a mixture of both? Cube and panels?
Old 3rd Dec 2012, 22:51   #76
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Yeah, the mesh is going to get some panelling and pipes that go from the surface "into" the door. Also got lots of small modelling stuff that can go on the cubes to break the design a little.
Here is the inspiration for this section
__________________
Old 4th Dec 2012, 13:38   #77
Petrol head
Modder
Petrol head's Avatar
Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!
The case looks amazing, can't wait to see the end result. Great attention to detail.
__________________
2500K at 4.5GHz MSI Z68A-GD55 8G of Corsair Vengance 256GB Samsung 830 Seagate 1TB MSI GTX670 Power Edition Antec 1200 case. Never peaks more than 45 degrees
That took me a lot of saving with a wife and 4 young boys!!
Petrol head is offline   Reply With Quote
Old 4th Dec 2012, 14:34   #78
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Congrats on the motm nomination. Got my vote
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 4th Dec 2012, 20:41   #79
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks! Cant wait to see how the foam will look when fully covered with cubes and panelling. Got 15 meters of cube pvc rods coming in today!
Thanks man ! Lots of excellent mods again this month!
__________________
Old 13th Dec 2012, 20:09   #80
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Sorry people that I havent had an update for you recently !
End of year is always killing with sales targets to be made and annual reviews with employees. There is one in the making but it will take some more time.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
