Reply
Thread Tools View Mode
Old 13th Dec 2012, 22:29   #81
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
I'm highly impressed you do what you do mate while maintaining everything that's important, keep up the awesomeness.
Waynio is offline   Reply With Quote
Old 14th Dec 2012, 17:46   #82
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
LOL, thanks Waynio!
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 14th Dec 2012, 18:20   #83
Asouter
Tremendously Difficult Lifestyle
Asouter's Avatar
Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.
Nice work man, the flexi tubing over the uv tubing looks very cool
__________________
Finished Project : D33P THOUGHT
Finished Project : THING
Current Project : Mini Moto Mayhem
Asouter is offline   Reply With Quote
Old 14th Dec 2012, 21:42   #84
ASPHIAX
ASPHIAX's Avatar
Thanks man !
Have you got something new lined up?
__________________
Old 15th Dec 2012, 00:01   #85
Asouter
Asouter's Avatar
Originally Posted by ASPHIAX View Post
Thanks man !
There's two projects in the pipe line, I've just been so busy over the summer racing. It kinda puts a drain on the funds but now it's winter so the projects should start.
I'm liking the Borg build, and catching up with other project logs, lots has been going on
__________________
Old 15th Dec 2012, 18:18   #86
ASPHIAX
ASPHIAX's Avatar
Thansk !
Yeah its hard to keep up all the time !
Only 600 more "Cubes" te go before the next update ! Auch ...
__________________
Old 15th Dec 2012, 19:31   #87
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
Ouch! Is that rubber or foam?
__________________
Project: RAt MoD - Update 16th June '13 - Deliveries of the Banned
i5 3570K, ASUS Maximus 5 Gene, Gainward GTX 670 Phantom, 4GB 1600MHz G.Skill RipjawsX CL6,
Modded Antec Kuhler 620, Enermax Revolution 1050W, WD Raptor 150GB , Antec P182
How to Get a FREE (sort of) Hard Drive and Other Small Parts
The_Crapman is online now   Reply With Quote
Old 16th Dec 2012, 09:35   #88
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Looks awesome mate cant wait for the next update.
__________________
Completed Projects
Project Desk Art - Project Flipmode - Project The Next Level
In progress
Project P42
Paslis is offline   Reply With Quote
Old 16th Dec 2012, 11:38   #89
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Looks good good luck with the cubes.
dream1 is offline   Reply With Quote
Old 16th Dec 2012, 14:42   #90
ASPHIAX
ASPHIAX's Avatar
Its hard PVC
Thanks !
Thanks, here is a new update !
__________________
Old 16th Dec 2012, 14:43   #91
ASPHIAX
ASPHIAX's Avatar
Started on the Tubing work.
The bottom section of the Cosmos II is packed
Every system needs a good drain IMO !
Ok, need a Sanity check here guys.
Created about 1/3rd of the cubes (total over 600) and placed them randomly (well as random as posible) on the foam design.
Everywhere there are 2 or more identical cubes I can place wiring, piping and leds and such. The insid of the foam will also be walled up with the cubes.
The sides will also be "Cubed"
PS: Thnk for the inspiration Bill ! That soundproofing material rally kicked it off !
__________________
Old 16th Dec 2012, 14:59   #92
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
You should change your camera... it's all pixelated!
Ra6 is offline   Reply With Quote
Old 16th Dec 2012, 15:30   #93
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Very,very interesting-waiting for more.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is offline   Reply With Quote
Old 16th Dec 2012, 16:32   #94
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
I dig it ^^
k.3nny is offline   Reply With Quote
Old 16th Dec 2012, 17:34   #95
ASPHIAX
ASPHIAX's Avatar
LOL!
Hope to have more soon !
Originally Posted by k.3nny View Post
I dig it ^^
Diggin that you dig it !
__________________
Old 31st Dec 2012, 17:38   #96
ASPHIAX
ASPHIAX's Avatar
So after a full week of non-internet connected fun on a snowboard its back to business !!
Yesterday was my birthday also and as usual I always ask new tools for my workshop.
So I got this nice sawtable for my birthday. Actually its called a tile cutter and you would use it for cutting up bathroom and kitchen tiles. But because its a full flat blade instead of a tooth blade its extremely suitable for cutting up pvc and plastics as its doesnt bite into the material. Also a small watertray underneath the blade reduces the dust and cools the blade so the plastics wont melt. I have about 600 more cubes to make for the BORG so I am very happy with it !
Its always a good sign once you get to the painting part of the build. This is a quick shot after an afternoon of sanding, sprayputty and spraycans
Got a couple of days of holiday left so hope to make some real progress!
__________________
Old 2nd Jan 2013, 13:44   #97
ASPHIAX
ASPHIAX's Avatar
Ok here is the first update of the small mod marathon !
I wanted to have several levels in the BORG cube fangrill panel so I cut out the right depth with a dremel
After glueing all the mesh down I started with the ever so important first row.
Wood glue is always the best when working with different types of plastic as it wont melt your work. I am glueing PVC with aluminum mesh with Polystyrene.
Then cleaning its up with a cotton tip. Its gonna be airbrushed but the wood glue dries transparantly also.
Laying out the design before I commit to it. This makes sure the design flows right.
Damn, I need to make more cubes ...
__________________
Old 2nd Jan 2013, 16:31   #98
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
It's a great idea to play with those little blocks to shape the exterior, but I think I would've taken balsa or foamy stuff instead to reduce the overall weight.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 2nd Jan 2013, 18:02   #99
ASPHIAX
ASPHIAX's Avatar
Yeah, its not light stuff.
I have learned from the eurisko that foam or depron is not the best stuff if you want to preserve the build. The slightest bump or fingernail leaves a mark that you remain forever.
Taking it to a lan party is very difficult then.
__________________
Old 2nd Jan 2013, 19:03   #100
jrs77
theorycrafting
jrs77's Avatar
Taking a large 40kg case to a LAN-party is difficult aswell
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
