#101 |
Beyond Complexity Lies Simplicity
LOL, more like 50kg when I am finished with it !
*mental note, design some wheels under case*
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#102 |
I just realised, the doors of the Cosmos are extremely easy to take off, so I can take the door off and transport it seperately and more securely!
__________________
#103 |
I got fed up with the work on teh cubes so I started on the assembly of the case itself.
![]() Da SSD tray ![]() Fangrills (need to get me some black m4's !) ![]() ![]() ![]() ![]() I think the matte black works ![]() And the current status of the cubes. I need to glue the top left cornour down (2 hours work I think)
__________________
#105 |
Multimodder
I really don't know why this thread only has 3 stars. You're doing some really awesome work, 5 stars from me!
#106 |
theorycrafting
The rating-function doesn't work properly.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#107 | ||
__________________
#108 | |
Keep calm & mod on. =)
![]() The various levels of the side panel gives me a nice idea to add alongside layers, I finally see a great way to make very complex forms from good material which would actually turn out nice & cheap but a bit on the heavy side lol. ![]() Will look even more awesome with some lighting, looking like it's gonna hit the bulls eye again. ![]() Keep it up Asphiax, coming along awesome.
#109 |
Thanks man !
Yeah I got some scrap pieces of UV green plexi and some leds and 5 lasers I want to incorporate into the panel so there's definately gonna be lighting in there. I might just keep the colour as is also. Its almost the colour I would have gone for and the different cuts and surface structures just give it a used appereance. So airbrushing might now be necessary.
__________________
#110 |
Here is the last update in this mini mod marathon.
Glueing the old HDD platters for final placement! ![]() Lighting fixation for the front panel. ![]() ![]() Playing around with the PCIe cables. These are alchemy extension cords. ![]() ![]() ![]() I was actually planning to put all the PCIe cables into the silver hose but that would mean a big silvery spot just next to the reservoirs and would be to distracting. So I will keep the extension cords but place a couple empty hoses in between. ![]() ![]() Also made some for the SLI bridge. Will make a nice piece of UV plexi to cover it and act as a fix point for the hoses. ![]() ![]() I think its just enough to liven up the interior without being to distracting. ![]() Although this looks just nice also. ARGH ... decisions !!! ![]() Laters and thanks for watching !
__________________
#111 |
Custom PC/bit-tech modding sections
Awesome! Really coming along now.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now! |
#112 |
tadbitnerdy
Amazing work! I'm really diggin' the silver hoses linking the GPUs and going from the SLI bridge out of the case. Any plans for the SLI bridge?
-Tad |
#113 |
Fenrir The Wolf
Well done,mate. Nice idea about that tubings.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#114 |
Was just a mad idea I had when I bought an air brush & found it difficult to know where I was going to be painting exactly & never got around to trying it out but I was going to mount a laser pointer so it aligns for where the paint would hit pretty much as an air brush stabiliser until I got a good feel for the technique of using one with accuracy, if/when I decide to start leveling up my air brush skills I'll definitely be trying the idea out.
![]() I don't know if it's a good idea with it just being an idea but it might turn out really useful for air brush beginners so just thought I'd share it. |
#115 | |
Thanks Antony!
Thanks man! Yeah such a cheap material but it looks the part!
__________________
#116 |
Multimodder
"Resistance is futile"
![]() Nice work mate, also nice idea for tubing. |
#117 |
Professional Sleever & Modder
i would have skipped the silver plastic tubing
#118 |
still thinking....
I don't know about the outside, but the interior is outstanding! Very sci-fi. Like some giant scientific machine. I love it.
__________________
stillthinking |
#119 | ||
Its aluminum .. Quote:
The exterior will need a boatload of work to get it to the finish I want. The cubes are the groundlayer on which I will create the Borg stucture.
__________________
#120 |
Here is another small update !
Started on the wiring and made some coverstrips for the sharp edges of the drive bay. ![]() ![]() Measuring and placement of the SSD's. Need to score me a 240Gb Hyper-X for storage and I can take that off the list. Need to cut out the sata and pwr cable holes and then I have decided to paint the backplate also black. Just doesnt look right with the SSD's in there. ![]() ![]() ![]() Was testing out some hosing for the mobo connector. After searching my workshop for an hour to find that one 90 degree connector I knew I had, I gave up. Gonna order me a new one. Damn was really hoping to do that work today. ![]() Oh well better tidy up some cables then. Pretty handy stuff that loom! ![]() ![]() That was it for today! Thanks for watching!
__________________
| Thread Tools | |
| View Mode | |
