Reply
Thread Tools View Mode
Old 18th Nov 2012, 13:35   #1
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
[Build Log] Arctic Water
Another month and another build,this time for an OC3D member,Omega Stalker.
This build is based around the massive CosmosII from Coolermaster,a very well appointed beast of a case!
The theme running thru this is a white/black/copper colour scheme with some icy touches...
These are coming out for 2 240 Koolance rads...
Looks about right for 2 large bays....
Magoo approves this post!
And the mandatory Cosmos 'bird of prey' pose.
B NEGATIVE is offline   Reply With Quote
Old 18th Nov 2012, 13:45   #2
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Leta make a start on the cooling..
Omega got a great deal on some Koolance rads and decided he wants to go with those,these 240 rads have a neat party trick!
Prep and primered.
These will be white. Thanks Koolance for making my life easier.
Now,you cant leave the 360 on its own,it need some love too!
Just waiting for Paints 4 u to get the white paint then i can do the rads,finish them off and turn my attention to the outside of the case.
Large window cutouts to do,lots of interior paneling out and more tasty things....
Old 18th Nov 2012, 23:34   #3
Hanoken
Modder
Hanoken has yet to learn the way of the Dremel
and he is back again with another mod the first few pics don't show much but heck, from previous works I can pretty much say " a storm is coming" sub for updates and mod on ^^
Hanoken is offline   Reply With Quote
Old 19th Nov 2012, 11:50   #4
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
This is going to be nice. I am looking forward to seeing what you have planned for this. Will be watching.
krussellusaf is offline   Reply With Quote
Old 19th Nov 2012, 16:56   #5
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Today i get on with the paint triage and the dis-assembly.
Not hard to do but you must be careful,the tab plastics are thin and wont take abuse..
Lets start by getting those doors off,nicely made and with the best hinges i have seen on a case.
Clear out the endless drive bays from the now rad bay.
Magoo surveys the scrap for potential morsels...
Greedy boy....
Top panel.
Separated for painting..
The usual sharp edges from the fold tabs made me a few choice expletives a few times
And the now exposed 360 rad mounts.
Surgery performed and parts stacked up for prep.
Magoo is making pointed reminders about dinner in the background....
Oooge fan!
So now its paint prep time,the more effort i put in now,the better the result!
I wont bore you with all the prep photo's when im done,you must of seen that kind of thing endlessly now....
Old 19th Nov 2012, 19:13   #6
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
I like Magoo!!! And also the start of the project of course
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 21st Nov 2012, 10:30   #7
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
OmegaStalker sent down the pump top he is using,a dual loop EK D5 top.
As you can see,this one is crop circle free....and better for it...
Old 21st Nov 2012, 11:39   #8
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
good old plain EK stuff - I like it!
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is online now   Reply With Quote
Old 21st Nov 2012, 12:14   #9
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
i have to agree. all those cirrcles are hideous on a block of any kind. or pump. i have seen very few builds with 'em. and thats when le pumps are hidden.
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is online now   Reply With Quote
Old 21st Nov 2012, 12:32   #10
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
mmmh! the circle design is vry ugly... =/ flat black or clear with an EK logo is a lot more beautiful!
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 21st Nov 2012, 12:37   #11
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Yep,a piece of the golden years...
If the whole loop is CSQ then it doesnt look so bad,im a Watercool guy myself.
There is going to be a 2mm thick polished copper cover going over the top of the pump top,just the inlets will be seen,i want to get rid of the recesses for the screw in res.
Old 21st Nov 2012, 19:03   #12
LazyMan
Minimodder
LazyMan's Avatar
LazyMan has yet to learn the way of the Dremel
Coming along nicely...looking forward to more updates.
__________________
It's A Mod'n World
LazyMan is offline   Reply With Quote
Old 22nd Nov 2012, 10:29   #13
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Its slow but its coming....
What is this? 2mm Copper? Shiny copper? Luuuurvely copper....
This is going to be for the front panel and pump tops,plus any detailing that i want to pick out...
Old 25th Nov 2012, 12:57   #14
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Take one plain looking EK dual top..
Add copper and a whole lot of manual metal working...
This piece needs to be hit with a bench buffer before it goes on,i have seen one at a good price so that will be my next purchase for the 'lab'
There will be a matching piece for the pump side too,should look good when its done.
Old 25th Nov 2012, 13:12   #15
siliconfanatic
hehe
PUT ON THE COPPAH!!!!
NOOOUUW!!!
lookn good even in matte. copper is copper, and thatll be a heaping order of awesomesauce.
__________________
Blackalize it!
Old 2nd Dec 2012, 21:21   #16
siliconfanatic
page 3 not good
BUMPETY BUMP BUMP for all that is gangnam style
no incubation on page 3 for this log
__________________
Blackalize it!
Old 3rd Dec 2012, 15:39   #17
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Sorry mate,been at i47 displaying my rigs alongside coolmiester so its been a bit busy!
Old 3rd Dec 2012, 19:14   #18
siliconfanatic
its alright, just aint gonna let it stay on page 3 thats all
__________________
Blackalize it!
Old 5th Dec 2012, 18:38   #19
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Its been a bit busy recently but today I made a start on the back plate for the pumps.
Its roughed out,I need to take some fine files to it to finish it off.
Round the corners and finalize the shape then off to the buffer!
Old 6th Dec 2012, 02:10   #20
siliconfanatic
lookin wicked!
__________________
Blackalize it!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
