#21 |
Pipebender
Small progress....
Knocked the copper back with 1600 W/D ready for some bench polishing (when the bloody thing arrives) ![]() ![]() Holding off the final profiling of the corners until i have some pumps in. Brightens up an otherwise ordinary pump top....wishing for a drill press too i think,would of made the hole drilling much easier than the trusty 18v cordless... |
#22 |
Supermodder
nice work as usual, Neg. machine Mart do some cheap drill presses. mine. My clarke has lasted years!
#23 |
69 Dude!!
Subbed, very nice build.
__________________
Urban Camouflage
#24 |
Supermodder
Very nice copper work, subbed and looking forward to updates :-)
#25 |
Pipebender
Some progress.
Fans and rads painted and soon to be fitted,got some 240 rad stands coming so i can clear out the bottom bay. I could of got a pair of 360 rads in the space under there! ![]() Top 360 in,this will have a mesh cover over the rad face or may make a rad guard out of copper sheet....Time took get hammer out! ![]() ![]() Top panel painted. ![]()
#26 |
Hypermodder
comming out nicely!
Are those Copper rings? :O |
#27 |
Pipebender
#28 |
Hypermodder
They look pretty real :P
#29 |
MD of Mutant Zombie Armies Inc
They do look awesome. what paint did you use on the rings?
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#30 |
Pipebender
#31 |
seems they've got 3 different coppers. lol is it Copper Brilliant Metallic (no.162), Copper Metallic, (no.4400) or Flat Copper Metallic (no.453)?
__________________
#32 |
Car lover and Speed Junkie
I. I....i......i.....fracking hate touch screens
![]() Just got an idea. On a gloomy, brain-currently underclocked day. I just got an idea. MY GOD, ITS FULL OF COPPER and carbon! |
#33 | |
Mad FPS Gamer
I managed to fit 1 360x60mm in the bottom with fans on both side for push/pull, but that didn't leave room for much more. If you got rid of the supports for the midplate and made some new ones you would find it easier to fit them in the bottom, because otherwise you have to fit all the fans bar one if you go push/pull and jiggle it in and then fit the final fan. As for the log I will keep a eye on this
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! . Market Place Feedback http://forums.bit-tech.net/showpost....&postcount=104 |
#34 |
Pipebender
Sorry about the wait,I have been waiting for forever for my sheet metal bender.
Thankfully it arrived today so i got on with the shrouds and rad mounts Lower bay has been cleared of all the excess junk so i can get to work. ![]() ![]() In the bay. ![]() ![]() The PSU end of the shroud will be detailed with a plexi window to show off the PSU You can see the midplate is in,the pump mount is cut and ready to fit and the first of the rad mounts in the lower bay is done. I will be getting the rad mount on the other side finished and the shroud for the drive bays done. Once all the metal work has been done then i will move on to finishing the paint work. |
#35 |
Now i'm happy again! I got my fix of copper
#36 |
Mac Pro Modder
Nice work. I like the colour scheme and that shroud is sexy.
__________________
Umbra Aqua - Mac Pro Mod |
#37 |
Pipebender
And the other side.
Cant do one side and not the other,this is a double sided case design so it has to look good front and back.And for the other side...
#38 |
So wait... both pairs of fans are blowing into the lower compartment
... But hey,You know what your doing ![]() I'm afraid I must ask this too. Didn't think of it before now. |
#39 |
Pipebender
I will dig the cap out for you.
A little teaser....
#40 |
| Thread Tools | |
| View Mode | |
