Reply
Thread Tools View Mode
Old 18th Nov 2012, 15:50   #1
marius_mym
Minimodder
marius_mym's Avatar
marius_mym has yet to learn the way of the Dremel
Noir - by marius_mym
Hello guys, I'm Marius and I'm from Romania.
I'm a member of this community for almost 2 years, but I didn't have the guts (until now) to post my previous projects. This is my current project, I started this project because I had some hardware components from my previous rig.
I already made an ITX case, and also a full tower case, so this time I decided to base my project on a micro tower case.
The name of the project represents, as you already figured out, the main color of the build.
I wanted a stylish case, but I didn't have enough money for a Lian Li so I bought a Fractal Design Core 1000, and also a mATX motherboard
(I sold my previous motherboard because it was ATX form factor).
After I took the photo above, I "strip" the case to do some measurements.
I already knew that I want to install two 120mm fans in the front panel of the case (maybe for a water block sometime). In order to do that I had to cut the original face of the case chassis, and build a new one.
After I finished the front piece I cut a second piece of aluminum to "extend" the motherboard tray, then I took the pieces, plus some hardware parts and I painted them.
I used a thermo resistant paint because is more resistant that the normal one and also you don't have to apply primer or lacquer. The disadvantage of this paint is that you have to heat the painted piece up to 160-200 C in order to obtain a full dry of the paint.
Because I don't have an oven to dry the parts, I heat the pieces with my heat gun . For ram radiators I used a "normal" paint.
The results are below :
The next parts that received the "thermo resistant paint treatment" was the rear brackets of the case, the bracket of the GPU and the top cover of the PSU (because I scratched when I removed the stickers).
When I finished with the painting I took the left panel and cut a hole for a windows. I cut the acrylic piece and I sanded the edges to obtain that "frozen" effect. The windows looks good but I'm not 100% happy with it and I think I'll change the acrylic piece with a dark one (to fit better with the theme of the project).
The next step was the sleeving job, but before anything else I would like to thank to sleeve-modding.com for sponsoring my project.
After I received the package I started to sleeve the front panel connectors, and then the PSU.
I wasn't happy with the long and useless (for me) cables of the PSU so I decided to short some cables, and get rid of other and make my power supply semi-modular.
Because the space inside my VX450 was very tight I was forced to mount the connectors for modular cables outside of the PSU. Overall I'm pretty happy with the results.
And some garbage :
After I finished the work with the PSU I started to work at the front panel. I didn't like the original metallic mesh of the case so I asked a friend to help me with a piece of black (matt) acrylic in order to replace the metallic mesh.
The shapes were cut with a laser, because I was afraid no to damage the acrylic.
This is the current state of the project, I'll make an update as soon as I manage to do some progress.
Hope you like my little project !
P.S.: My english isn't perfect, but i did my best !
marius_mym is offline   Reply With Quote
Old 19th Nov 2012, 00:47   #2
Hanoken
O.O
Hanoken has yet to learn the way of the Dremel
your English is fine understandable and clear ha ha ha, I love your black theme that you have going at the moment! can't wait to see what you have in store for this project and good luck !
Hanoken is offline   Reply With Quote
Old 19th Nov 2012, 03:57   #3
jay2
Indonesian Modder
jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.
molex and sata cable? gone?
well, i'll sit here and wait for your next update
jay2 is offline   Reply With Quote
Old 19th Nov 2012, 09:02   #4
makarov7
Minimodder
makarov7 has yet to learn the way of the Dremel
Very cool side panel windows - frosty
Noir = black , it will be a dark build i think
makarov7 is offline   Reply With Quote
Old 19th Nov 2012, 09:35   #5
LukeDaly
Pokemon Master
LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.
I think a tinted window would look great
Sent from my GT-I9100 using Tapatalk 2
LukeDaly is offline   Reply With Quote
Old 19th Nov 2012, 11:23   #6
biojellywobbles
Supermodder
biojellywobbles's Avatar
biojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyan
Wanted to see one of these modded for a while, gives me ideas on what to do with mine!
__________________
Main box: i5 4690K @4.5GHz, Corsair H80, 8GB Value RAM, Powercolor 280X with Kuhler 620 on G10 Bracket, OCZ ARC100 240GB, 2x500GB Seagate Barracuda, Silverstone PS07, Win7
biojellywobbles is offline   Reply With Quote
Old 19th Nov 2012, 11:53   #7
jamsand
Ultramodder
jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.
Fantastic finish on that paint work!
jamsand is offline   Reply With Quote
Old 19th Nov 2012, 11:56   #8
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
Great work so far, love the effect on the side window!
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 19th Nov 2012, 12:09   #9
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
looking promising =) Love the Ram photos
SilveR_172 is offline   Reply With Quote
Old 19th Nov 2012, 12:58   #10
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Comme une nuit noire. Me like it
dream1 is offline   Reply With Quote
Old 19th Nov 2012, 13:04   #11
timerhan
Modder
timerhan's Avatar
timerhan has yet to learn the way of the Dremel
+1
Very cool!!!
timerhan is offline   Reply With Quote
Old 19th Nov 2012, 13:49   #12
marius_mym
Minimodder
marius_mym's Avatar
Woow, thanks for the kind words guys, I didn't expect to see so much replies in a such short time.
Thanks !
Well, I had to get rid of those "tentacles", because they were useless. I only need one sata power connector (for HDD), and maybe another one for an SSD, but I'll make my own extensions.
I'm glad you like my side window guys ! I've been waiting for a long time to use that "effect" and this project offered me the perfect opportunity, because the window is pretty small and I can change it very quickly without wasting too much acrylic (in case that I don't like the way that looks).
I agree with you! The tough part is to find a tinted acrylic window in Romania, but i'll do my best.
Well, I hope that my project will give you some ideas ! I can't say that this case offers unlimited possibilities, but there are couple of things that you can change .
Thank you, sir ! I did my best, but the paint helped me a lot. The entire process (from the first layer of paint until full dry) took about 2 hours
Originally Posted by timerhan View Post
+1
Very cool!!!
Thanks ! I love them too !
Glad you like !
P.S.:My french is even worse than my english, i had to use translate google to understand !
Old 20th Nov 2012, 17:30   #13
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
So far, so awesome!
__________________
Ediface
FT03 Mini - 4770S - Noctua NH-L9i - GTX 1060 - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - 27" AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 20th Nov 2012, 17:32   #14
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
Agreed! Not too keen on the window style though, takes away from the minimalism of the build.
You're awesome with spraypaint though! Look like you've powdercoated everything!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 20th Nov 2012, 18:48   #15
marius_mym
Minimodder
marius_mym's Avatar
Originally Posted by Parge View Post
So far, so awesome!
Thank you Parge!
Totally agree with you! Even if the window looks fine, it doesn't fit 100% in project. I'm going to change it as soon as I find a tinted acrylic sheet.
I'm glad you like my spraypaint !
On the other hand today I made some kind of "splitter" to power on a stripe of LEDs and also a fan controller.
I choose to power on the fan controller with a 2 pin connector because in this way i can reduce the number of cables (I'm going to use 26 awg wire and only one sleeving wire for both cables of the fan controller).
Old 27th Nov 2012, 16:27   #16
marius_mym
Minimodder
marius_mym's Avatar
Last time I show you the splitter that I'm going to use to power the fan controller and a LED stripe. In the previous weekend I made a cable to connect that splitter to the power supply.
After I finish the cable I made a backplate for the GPU . I know, is pretty simple, but I like that "clean" look.
Ohh, I almost forgot, today I receive a small package form my sponsor sleeve-modding.com.
I'll use a part of these items to build the fan controller.
The other part (the rubber grommets and the switch) I took it "just in case" .
P.S.
: I'm still searching for that tinted acrylic !
Old 27th Nov 2012, 16:44   #17
KidMod-Southpaw
More great stuff!
By the way, what I meant about the windows was that the smudged style border doesn't work. The actual clear plastic is fine and probably better.
__________________
Old 27th Nov 2012, 19:47   #18
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
that window! Mind = Blown!
k.3nny is offline   Reply With Quote
Old 27th Nov 2012, 21:21   #19
marius_mym
Minimodder
marius_mym's Avatar
More great stuff!
Glad you like my little update !
Regarding window panel... meh, it would be to easy to mount a clear acrylic !
Glad you like it mate !
It looks good indeed and also is easy to obtain (you only need a 300-400 grit sandpaper, a piece of acrylic and.... some imagination ) but unfortunately it doesn't fit perfectly into the project.
Old 23rd Dec 2012, 14:07   #20
marius_mym
Minimodder
marius_mym's Avatar
Hello guys !
I know is been a while since my last update, but i didn't have anything "cool" to show.
As I said before i wanted to made a different type of fan controller for this project, so i asked a friend to help me (i'm not very good with the solder gun) and this is what we manage to do :
The "fan controller" has 3 positions : 12V=>off=>7V.
After I mounted the fan controller, I also mounted the cpu cooler and i manage to do some photos .
Unfortunately i still need an SSD , but the good thing is that the lack of the SSD didn't affect the "design" of the interior, because the SSD will be placed under the GPU card, and as you can see the Sata power cable for the SSD is already in place.
So... enjoy the photos ! Hope you like !
After i did the photos i realized that i don't like that "code" from the fan of the cpu cooler, so i rotated the fan by 90 degrees , and I made some "indoor photos", because outside is veeeery cold .
Hope you like it guys !
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
