#1 |
Hypermodder
K.3nny's LianLi Pc-7HX Casebuild, acrylic pipes - Voting time :D!
Back again with again a lianli case
!![]() Package arrived ![]() Some seconds later ![]() Dismantled the case and start measering things out. ![]() Made an working table. ![]() The first adjustment will be the front.
#2 |
Making You Feel Old Since 2010
Nice to see you back! I'm looking forward to this!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#3 |
Hypermodder
@KidMod, Thnks buddy!
Update Started with the top and front, ![]() some masking and lining everything out. ![]() Raw cut ![]() After some elbowgrease ![]() ![]() Then i started with the front, removed original frontpanel mesh, Tried some lianli mesh from another case on the drivecage area but Nah, thats not it. ![]() I didnt want the Dual 14mm intake, so i fixed a plexiglass window for it, still not done ofc waiting on some stuff.![]() Mounted ![]() Started with the top plexi window, ![]() rawcut ![]() After some elbowgrease and P400 sandingpaper ![]() Nice and smooth! ![]() To the next update! |
#4 |
Multimodder
waiting to see what's coming :P
__________________
Finished: -Mini-PC http://forums.bit-tech.net/showthread.php?t=248203 unfinished: none!
#5 |
Hypermodder
Ah not much
#6 |
Hypermodder
update time!
Psu relocation + searching for watercooling opertunities Voiding the warranty like a boss! ![]() ![]() ![]() Lets find a place for that naked psu! ![]() ![]() Well thats a nice spot isnit? ![]() Some motherboard standoffs to mount the psu-pcb to the case ![]() ![]() i did a good job, with to standoffs ![]() ![]() deleted some more Aluminium from the case. ![]() gonna mount the fan on an angle, so it gets fresh air (update for that incomming) and blowns the air to the headspreaders, and pcb. ![]() ![]() Thinking about this layout, but i need a mcp355 pumptop to confirm this loop, so thats on hold untill i got the top. ![]() Greets! |
#7 |
Supermodder
Wow brilliant idea !
#8 |
Hypermodder
Thnks silver!
#9 |
Supermodder
Looking good Kenneth lovely solution for the PSU
__________________
Completed Projects: Cooler Master Silencio 550 Limited Edidtion Project White, Black Obsession, Project Umbrella |
#10 |
Hypermodder
Update
!Created an "intake" so i had no airflow isseus with the psu ![]() ![]() Then i sawed of the mounting side of the psu INCLUDING the inline filter, so its all 1 part and not 1 thing here and 1 thing there (oh wait, xD! ) ![]() ![]() Today also came 2 packages in the mail, 15meter of red paracord sleeving and 50x152cm matte black vinyl (still wanted to try that and i kinda like it) Cleaned the front, no more fans there, because the hole innerside will be random build :P ![]() * matte black blends in perfectly with brushed alu! My psu was already sleeved with MDPC sleeving, but i wanted to go heathshrink less, so i took paracord .![]() ![]() ![]() when sleeving all wires 1 at a time i created this wire pass thru. ![]() *also ripped a piece of metal away so i can let the wires guide at the back of the motherboard panel ![]() also my top a step further, more about that tomorrow. ![]() see u with the next update
#11 |
Multimodder
The PSU idea is just... marvelous! So much free space in the bottom of the case now..
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161 |
#12 |
Multimodder
Great job K3nny
#13 |
Supermodder
subbed
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb Coolermaster 600w Silent Pro Modded Lian Li PC-0700 |
#14 |
Omnipwntent
PLEEEEASE isolate all that PSU stuff so you don't end up with a 110/220V Lian Li electrode.
How are you doing the power connectors? Very interested!
__________________
Slash88: That kettle video just made me go death thanks. Fizzban: And it is being panda'd to..lame. |
#15 | ||
Hypermodder
![]() Ty dave !Ty Quote:
#16 |
Hypermodder
update
![]() top window done and finished off with a black matt vinyl edge ![]() ![]() Bought myself some aluminium 500x1000mmx1mm ![]() Drawing all the plates on the big plate and cut them to size ![]() ![]() Frontplate innerside. ![]() Ready to bend. ![]() Psu plate is done so happy this went good !![]() Mounted ![]() ![]() Reservoir spot. ![]() Midplate done! ![]() creating some tabs to mount the midplate on. ![]() ![]() ![]() ![]() ![]() Thats straight ![]() Radiator placement ? ![]() ![]() ![]() ![]() See u next time
#17 |
Hypermodder
update!
Creating the hole for midplate ![]() Jigsaw time! ![]() Perfect! ![]() Creating 2 pass thru's ![]() ![]() Used realy strong gleu to hold up the rad against the midplate, so its supper clean ![]() ![]() ![]() ![]() started with some matt black vinyl to create some finished looks midplate ![]() frontplate ![]() psu plate ![]() ![]() ![]() Overall for today ![]() See u guys next time
#18 |
Multimodder
THAT IS an impressive job! It's perfect!
By the way, I haven't seen anything like that before, but if I'm right, you plug the PSU on the bottom of the case and it runs on the 5.25" bays place isn't it? |
#19 |
Ultramodder
Quality work
#20 | |
Hypermodder
!Ty sir! |
| Thread Tools | |
| View Mode | |
