Reply
Thread Tools View Mode
Old 14th Dec 2012, 21:38   #41
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Love where this is heading
especially liking the roof window
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 15th Dec 2012, 05:44   #42
fractal arc modder
Multimodder
fractal arc modder has yet to learn the way of the Dremel
This is going to be one epic build
fractal arc modder is offline   Reply With Quote
Old 15th Dec 2012, 13:21   #43
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Originally Posted by jotinha17 View Post
very well done ..
I like it, I acampanhar here.
Originally Posted by elAwesome View Post
I have been following the build all the time without commenting
But since I'm writing anyway: It looks pretty cool! Thanks for the detailed project log :P
Doing me great that people are willing to put some effort into reacting on builds, more reactons - more updates, Counts for all buildlogs!
k.3nny is offline   Reply With Quote
Old 16th Dec 2012, 09:37   #44
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Awesome job so far Kenneth. Waiting for the next update.
__________________
Completed Projects
Project Desk Art - Project Flipmode - Project The Next Level
In progress
Project P42
Paslis is offline   Reply With Quote
Old 16th Dec 2012, 16:28   #45
k.3nny
Hypermodder
k.3nny's Avatar
Thnks ! Yes i need some little parts then i can move the hardware and finish it up
Old 18th Dec 2012, 11:00   #46
k.3nny
Hypermodder
k.3nny's Avatar
update,
Well, My budget has reached his max point (49 euro) so yeah, All i can do is take the my daily and strip it down so i could do the heart transplant :P also using some other parts
Also created a new powercable fot the pump and sleeved it
Because i was so busy i forget to take pictures, i spend around 6 hours today on the setup and case.
Here some random pics, less text more pics
Thats it for this update !
Main point was i could re-use 3 pieces of solid tubing, glady saved me 10 euro on a new 2 meter acrylic pipe!
Budget modding is always fun to do, and see what u can realy achieve with less expensive things
Costs:
Case: 110 euro
Alu sheet / paracord: 25 euro
Splitted order with a pal HighFlow.nl: 60 euro 20 Euro my costs
2 liter Demiwater: 4 euro
Mat black vinyl : Free
Total 159 euro
Got 1 euro left, The point was i had some things laying around, could save on those allot
Bye guys!!
Old 18th Dec 2012, 12:27   #47
Sam__
Multimodder
Sam__'s Avatar
Sam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the DremelSam__ has yet to learn the way of the Dremel
good job on the re-using and a nice job on a budget.
__________________
3770K @4.5Ghz ¦ ASUS Maximus V Extreme ¦ 8Gb Kingston 1866Mhz ¦ ASUS GTX 560 Ti DCII ¦ Kingston Hyperx 120Gb & V200+ 60Gb ¦ 2x 500Gb ¦ Corsair HX 520W
Sam__ is offline   Reply With Quote
Old 18th Dec 2012, 21:20   #48
k.3nny
Hypermodder
k.3nny's Avatar
Ty sam!
Old 19th Dec 2012, 00:17   #49
k.3nny
Hypermodder
k.3nny's Avatar
Making Acrylic tube yourself!
Time to explain how to make acrylic tubing * my english is not THAT good!!!!
First of al, search and use object for the bends, i prefer steel, it keeps the heat stuck, and doesnt cool down your acrylic pipe that quick.
Always make the tube longer than u need!, the bends can not come out how u want sometimes (weakspots)
I use a Power suply 7mm thick cord (EU)
I prefer a hairdryer, because u cannot overheat the tube and it wont make it to warm so you pull the tube flat.
If the tube is hot enough, u cant start bending the pipe, dont pull to hard otherwise u get a flat spot at the end of the pipe.
If u are at the point that your tubing is bend and lined up with the fittings u can cut it to size
I used a cheapo rotary tool and a dremel atachment (sanding barrel P120)
My working situation xD!
Tape it 7/8mm of the edge, so you know you dont get an ugly spot above your fitting
only sand the tube till its frosted! dont use pressure, dont create flatspots, the pipe is sold as 12mm but the exact size is 12.3/12.7! so yes just a little touch all around is enough! finish it up with sandpaper Grid P400 so the rubber ring wil fit nicely!
Test the fitting
*tips
1. Use always the same test fitting! Orings can and will be damaged while testing!
2. If there is to much tension in your object between for example GPU-CPU bend, leave it in place, Heat it up til you see that the tension will be away *you wil probaly feel or see gpu moving
3. always use the same bending object in a build, its not that nice to see different bends in a casemod( or the situation is different)
4. Cool the tube after bending with a bucket of cold water
5. Only use C47 of bitspower!
6. This "guide" works only the best with 12mmODx8mmID Acrylic tube, I know there is also 1/2mm thick pipe but u will get flat spots or kinks in the inner bend.
7. Cut the tube gently! u dont want to trow away a perfect bended tube! because of a crack.
Thats it for this little guide
Further on with this update!
ready to be cleaned and Filled up !
Waterrr
Dirty loop
After draining the loop, i put fresh and new water in it, Then started to play with Mayhems red Dye!
1 drop
2 drops
3 drops
4 drops
5 drops
6 drops
Gonna leave it like that for now, maybe some more or ill thin it up, we will see in the future
Rest of the pics.
Bye bye
Old 19th Dec 2012, 01:52   #50
Sam__
Multimodder
Sam__'s Avatar
I really like the look of that bent acrylic pipe.
__________________
Old 19th Dec 2012, 14:15   #51
Stem83
Addicted to modding.
Stem83's Avatar
Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.
Yep that pipe looks much better than tubing. nice work and thanx for showing how you did it.
Stem83 is offline   Reply With Quote
Old 19th Dec 2012, 14:52   #52
Bitwacker
C# forever
Bitwacker's Avatar
Bitwacker has yet to learn the way of the Dremel
Brave to strip a PSU; you must be a ninja
__________________
i7-2600K | 16GB 1600 | ATI 5870 (Asus) | 2x120GB SSD (RAID 0) | 2x1TB Samsung F1 | Asus Xonar DX | 30" DELL | 2x23" Dell | Cooling: single water cooling loop
Bitwacker is offline   Reply With Quote
Old 19th Dec 2012, 15:07   #53
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Thanks for the tutorial!
I still can't decide whether I should use nickel or acrylic tubing in my next build...
elAwesome is offline   Reply With Quote
Old 19th Dec 2012, 16:31   #54
k.3nny
Hypermodder
k.3nny's Avatar
Thnks !
No problem glad to show off the things you can do
Nah, Just Challenge accepted its still running flawless, i had it on prime 95 and furmark for some stresstests nothing changed, i think i did a good job
Acrylic is the way man !
Old 19th Dec 2012, 17:01   #55
elAwesome
Multimodder
elAwesome's Avatar
Reasons? :P
Old 19th Dec 2012, 20:45   #56
k.3nny
Hypermodder
k.3nny's Avatar
no stains always perfect sight :P
Old 19th Dec 2012, 21:51   #57
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Awesome mod Kenny.
Nice result from a hair drier too, thanks for the tut.
Waynio is offline   Reply With Quote
Old 19th Dec 2012, 22:04   #58
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
wooah. I got a similar case (lian li pc-9f) and what you have done is very different from any integration sketch I did That is what makes me believe you job is great! ^^
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 19th Dec 2012, 22:20   #59
k.3nny
Hypermodder
k.3nny's Avatar
Thnks guys !
Old 20th Dec 2012, 11:40   #60
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Looks realy cool. Me like the idea of using those plastic tubes
dream1 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
