#1 |
WIIGII!
bit-tech Staff
Zalman Reserator 3 pictured ahead of CES
Sealed-loop cooler destined for CES launch.
http://www.bit-tech.net/news/hardwar...-reserator-3/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
King Battletoad
400w....
That's not even possible?
__________________
Fractal Define XL / Asus Maximus V Gene Z / 3570k i5 @ 4.8Ghz / Corsair H80 / 8GB Corsair Vengeance 1600Mhz DDR3 / EVGA GTX 680 FTW 4GB / Asus Xonar DX / 512GB OCZ Vertex 4 / Seasonic X-650 / Dell U2711
#3 |
STILL ALIVE
Why?
(Not an attack, just interested to see why you think it can't dissipate that kind of heat)
__________________
ook |
#4 |
Marvin. I don't care what ^ says...
400W is possible, but it depends upon the Delta-T they've chosen. If it's 400W at 50°C delta T with 2000rpm, then it's not impressive at all. It does also depend upon the flow rate.
Check the graphs at the bottom of this page for how "proper" 120x3 radiators do with a 10°C delta T and the watts dissipated. The flow rates are probably higher in these examples too, so the 0.4GPM graph is probably most representative. What can be seen is that 120x3 radiators at that flow rate get about 350-400W dissipated at 2000rpm. Assuming that a 120x3 performs 3 times better than a single 120 (which it probably doesn't quite), then Zalman are looking at a pretty large Delta T for 400W... |
#5 |
Ghost In The Machine
Well it certainly looks good. I wonder if the will bring out a 120x2 version and then all we need is price.
__________________
Motherboard - ASUS P5K Premium CPU - Q6600 @ 3GHz - Arctic Freezer 13 GPU - Palit 9600GT @ Clock 750MHz - Mem 1100MHz - Shader 1850MHz RAM - 6GB Corsair PC2-6400 DHX @ 960MHz
OS - Windows 7 Ultimate (64bit) |
#6 |
Supermodder
My original reserator is still working fine cooling a 3.00ghz P4 and 7950GT (AGP). Its actually been connected for more than 5 years now and I haven't opened it up since fitting it. Thats pretty impressive reliability I think.
#7 |
A Paragon of Virtue.... Apparently
I think it's mad for Zalman to continue the Reserator moniker given how poor their previous XT model performed. The sticking flow rate indicators that would throw the system into an alarm was hopeless, even after replacing the part, mine still had problems. I have to switch mine to manual upon booting up as auto would cause the fan and flow rate to drop to alarm inducing speeds. Even after a de-gunking and fresh coolant.
Hopefully these prove to be more reliable. Their fanless Reserator 2 was excellent (it cooled a Pentium D 945 @ 4ghz + 8800GTX just nicely) and I've only just recently passed it on to a friend. Any clue as to what coolant will be used? as their blue additive gunked up worse than Porkin's home furnishings. ![]() Edit: shame no 775 socket support
__________________
Teh unofficial Bit-Tech proof reader Last edited by B1GBUD; 21st Nov 2012 at 12:04. Reason: Edit: shame no 775 socket support :( |
#8 |
Good news everyone!
I have a Reserator 1 V2 in sat in my cupboard doing nothing, but it happily cooled my old GTX580 heavily OC'd. Is this the sort of thing that people still want to own? The thing with Zalman is that their engineering is usually epic, but the products themselves are often a let down.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock Z77E-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 |
#9 |
Supermodder
that's one sexy cooling system
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
#10 |
Dib Dabbler
I really liked my Reserator - it had a real industrial look to it. I ended up plumbing in an extra radiator for some extra cooling : http://forums.bit-tech.net/showthread.php?t=187355
__________________
I got all the gear, but I got no idea ![]() 3DMark Fire Strike Extreme - 4968 My Flickr Photostream |
#11 |
DemonHighwayman
[quote=waterblock-cum-pump[/QUOTE]
It's interesting that they don't use water like regular water cooling systems !
__________________
Main Rig:Case: CoolerMaster Cosmos S, Motherboard: Asus M4A785TD-V Evo, CPU: AMD Phenom II X6 1100T, RAM: 8Gb 1600Mhz Corsair Vengeance GPU: XFX ATI 5870, Primary HDD: 128Gb Kingston SSDNOW 200, Optical Drive: LG Super Multi Blue HTPC:Case: Gutted out VCR, Motherboard: Asus AT5IONT-I, CPU: Intel Atom D525 @ 1.94Ghz, RAM: 4Gb 1333Mhz Kingston GPU: Nvidia Ion 2, Primary HDD: Hitachi 500Gb, Optical Drive: NEC ND-6500A Laptop Drive |
#12 |
CPC 464 User
I lol'd |
#13 |
I can do dat, giz a job
I think it looks ace but I have been known to pick up the occasional bint.
#14 |
Vapourmodder
Personally, I think the interesting thing here is that the radiator assembly /appears/ to fit completely into the footprint of a 120 fan. For people with 120 fan mounts that are recessed in some way preventing the installation of standard 120 radiators, this is an improvement!
I only wish it came in a red LED variant...
__________________
Current setup: Silverstone FT02B | Core i7 920 (Cooled by Noctua NH-U12P) | Foxconn Renaissance | GTX280 | Cooler Master UCP | Corsair Dominator 3GB | Creative X-Fi Titanium | Windows 7 Home Premium x64 | OS Drive: WD Velociraptor 300GB. Storage: 1x 160GB, 1x 250GB, 1x 300GB, 1x500GB (incremental additions over the years! All Maxtor) | Monitor: Dell 2709W |
#15 |
W.O.T xxxsonic1971
The water in this is wetter i wonder??
__________________
I7 3820-MSI X79 GD65(8D)-16GB Samsing Green Ram-ATI XFX 5850-XFX 850wPSU- Samsung 128gb SSD-Antec 1200-Cyborg V7-Razer Abyssus- 22"1080p LG |
#16 |
Captin Calliope
i wonder if this could be compatible with GPU units ( like the h70 was with custom plates ) id love to see a proper gpu cooling setup similar to the artic cooling one ( albeit without the insane price cost )
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850 |
#17 | |
Omnipwntent
![]() ![]() ![]() Wasn't the whole point of the reserators that they were external? I gotta admit the originals were a piece of art to have sitting on your desk/floor. I ran one for a while waaay back maybe 10 years ago. The blocks were pants but the res/rad/pump was pretty pimp.
__________________
Slash88: That kettle video just made me go death thanks. Fizzban: And it is being panda'd to..lame. |
#18 |
I Mod, Therefore I Own
it's nice that they've put their on twist on the CLC concept, you can tell just by looking at it that it's a zalman based on the shape of the fins
otherwise THIS IS NOT A RESORATOR, why couldn't they have come up with a new name instead of tarnish a known branding with what will likely end up being a sub-par product
__________________
Intel i7-3820 @ 4.65GHz | HD 7850 | 4x4GB Vengeance | Asus Sabertooth X79
HAF XB | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet |
#19 |
Captin Calliope
acually the Resorator means combined radiator and reservoir...and by the look of it
thats a combined reservoir and radiator XD and dont dismiss it before you see final cooling numbers..im sure the same thing was said when they demo'd the first tower coolers, the first all in one water coolers etc etc etc
__________________
#20 | |
really joined on Dec 24th 2004.
Now I can't wait to see the Bit-Tech / Custom PC tests on that!
__________________
| Tags |
| liquid cooling, reserator, reserator 3, sealed-loop, watercooling, zalman |
| Thread Tools | |
