Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 21st Nov 2012, 17:08   #1
LennyRhys
Fan Fan
LennyRhys's Avatar
LennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming Saiyan
Wireless Adapter - PCI vs USB
I'm moving my PC to the spare bedroom and I'm going to have to get a wireless adapter for it but have no idea where to start because I've had a cable connection for years now.
What do you wireless people use and what would you recommend? I hope to make a purchase either tonight or tomorrow.
We have a Virgin Superhub in the living room and 60 meg broadband.
__________________
i7 5820K | MSI X99A Gaming 7 | 32GB Ballistix Sport | EVGA GTX980Ti SC | Corsair RM550 | Dell U3014
LennyRhys is offline   Reply With Quote
Old 21st Nov 2012, 17:51   #2
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
I would go for home plugs instead. I have a belkin pci-e Wi-Fi card in a rig and it has been a headache.
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 21st Nov 2012, 17:54   #3
Sp!
I *am* a Dremel
Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.Sp! is the Cheesecake. Relix smiles down upon them.
USB on a fly lead for 1 simple reason, your PCI slots are inside your case (which is probably on the floor) putting the antenna on the back of the big metal box under your desk is far from ideal antenna placement.
PS. I've still got a netgear one for sale... see here
Sp! is offline   Reply With Quote
Old 21st Nov 2012, 17:55   #4
Ivoryspike
Air Cooled
Ivoryspike has yet to learn the way of the DremelIvoryspike has yet to learn the way of the DremelIvoryspike has yet to learn the way of the Dremel
Yea, PoE plugs would be my choice too, especially seeing as the Virgin 'Superhub' wireless is utter pants.
If you have to go wireless then a PCI card my have better signal pickup (given the right model, 2-3 antennae).
edit: but SP! does have a point about placement.
__________________
i7 920 D0 @ 3.8Ghz | Asus P6T Deluxe | MSI Twin Frozr III 7950 @ 1.1Ghz | 12 GB G-Skill Ripjaws @ 1600 | 1050W Enermax Evolution | Antec 1200 | 256GB Samsung 830 | 2 x 3 TB HDD | Ducky Shine II Reds | Hazro HZ27WC | Samsung 2693HM
Ivoryspike is offline   Reply With Quote
Old 21st Nov 2012, 17:56   #5
lp rob1
I *am* a Dremel
lp rob1's Avatar
lp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyanlp rob1 is a Super Spamming Saiyan
A bit of drilling to get a cable connection across? Unless drilling isn't an option due to restrictive landlords or the such... Really - it takes so little effort to get a cable connection to anywhere in a small-moderately sized house.
__________________
The Linux Schools Project
lp rob1 is offline   Reply With Quote
Old 21st Nov 2012, 19:00   #6
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.
PCI leaves more room for the wireless card manufacture to put better components and have more power to receive a signal. However, as time moves on, and technology improves, in power efficiency, and smaller designs. I don't think there is much of a difference. Some PCI/PCI-E cards comes with an antenna that has a cable, so you can put it anywhere you want. Like ASUS or Gigabyte motherboards with Wifi built-in.
__________________
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 21st Nov 2012, 20:23   #7
LennyRhys
Fan Fan
LennyRhys's Avatar
I didn't actually consider getting a cable purely because it would be a lot of work, but now that I think about it, perhaps it would be doable and I'm looking into it. I reckon I'd need at least 25m of cable.
The homeplugs look nice, but dang they are expensive compared to the alternatives!
__________________
Old 21st Nov 2012, 20:33   #8
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
Homeplugs > PCI/PCIe w. breakout antenna > PCI/PCIe with fixed antenna > USB of any kind
USB tends to be unstable and slow, in my experience. If you go for an internal card, get an antenna with a cable rather than a directly attached one if you have signal strength issues. Homeplugs tend to work best, at least in my house. Very stable, low latency, no worrying about signal at all.
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 22nd Nov 2012, 07:49   #9
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
If you have a proper wireless router (not a Virgin Superhub), wireless should work without any issues at all. I have a 7-year-old Linksys WRT54G v2.2 and I've never had any signal or speed issues. Wireless is also an open standard unlike homeplug.
__________________
Intel Core i5 3570K @ 4.5GHz || Thermalright Ultra 120 eXtreme || Gigabyte GA-Z77-D3H || 2x 8GB Corsair Vengeance LP DDR3 1600MHz CL10 || Radeon 4870 512MB || AC Accelero Twin Turbo Pro || Asus Xonar DX || Samsung 830 128GB || 2x WD Blue 640GB || Corsair HX620 || Antec P182 || Samsung SM 2232 + 2233 || Windows Server 2012
mm vr is offline   Reply With Quote
Old 22nd Nov 2012, 08:28   #10
m3rk
Minimodder
m3rk has yet to learn the way of the Dremel
In my office at home the wi-fi signal is really poor - purchased a usb wireless module and usb extender, now works a treat now it has further reach and no drop outs on signal
m3rk is offline   Reply With Quote
Old 22nd Nov 2012, 09:44   #11
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.
Lenny, cable costs peanuts and these houses have loads of places to hide it. I have run a set of cables up the inside edge of my flu for the fireplace, they come all the way up into the loft and I drop them down the walls with a set of push pull rods and then burst holes and fit face plates.
If you can get under the floor, into the loft and have a fire place you are sorted.
If its possible to lift some floor boards at the top of the stairs, you can even run cables through the gap between the plasterboard and under underneath of the stairs.
TaRkA DaHl is offline   Reply With Quote
Old 22nd Nov 2012, 09:48   #12
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
Originally Posted by Ivoryspike View Post
...PoE plugs...
PoE is power over ethernet, which isn't what home plugs are. Sorry to thread crap.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 22nd Nov 2012, 10:25   #13
RocketPotato
Minimodder
RocketPotato has yet to learn the way of the DremelRocketPotato has yet to learn the way of the DremelRocketPotato has yet to learn the way of the Dremel
This is a good one as it supports both 2.4Ghz and 5Ghz: http://www.asus.com/Networks/Wireless_Adapters/USBN53/
RocketPotato is offline   Reply With Quote
Old 22nd Nov 2012, 13:36   #14
LennyRhys
Fan Fan
LennyRhys's Avatar
Yeah that's why it's such an attractive option for me - it's cheap and I enjoy DIY
I've already done a bit of recon and it would be pretty simple to get a cable upstairs... I just have to OK it with the boss when it comes to drilling holes
As simple as USB adapters are, I just don't think I could deal with the compromise having used cable for years!
__________________
Old 22nd Nov 2012, 15:59   #15
Ivoryspike
Air Cooled
Yea quite correct, I meant Ethernet over power plugs not the other way around.
__________________
Old 22nd Nov 2012, 17:39   #16
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
IMHO, cable is always the best option!
BUT - if not, I'd go powerline ethernet.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 22nd Nov 2012, 17:41   #17
Neilc
Multimodder
Neilc's Avatar
Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.Neilc is definitely a rep cheat.
I recently went completely to home plugs after getting fed up of crappy wireless from my BT homehub (although the wireless is actually OK, but just too far too stream HD content) - I have 1 homeplug plugged into my switch and 2 futher plugs...1 into my pc and another into my laptop that sits underneath my TV. I have an 80 Meg line (it runs at that speed due to being right next to the exchange) I can finally stream HD content from my PC to the laptop. Also really easy to setup just plug and play....highly recommend them.
Edit: not too expensive I got the following from Scan: http://www.scan.co.uk/products/zyxel...ptor-twin-pack @ 30 for a pair I think very reasonable
__________________
System Specs: Asus P8P67 Pro | 2500K @ 4.5Ghz | Asus GTX970 Strix | 16GB XMS 1600Mhz | Corsair H100 | Vertex 3 120 GB | Corsair RM750 | NZXT H440
Neilc is offline   Reply With Quote
Old 22nd Nov 2012, 17:49   #18
matt_lumley
You're only supposed to...
matt_lumley's Avatar
matt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for president
I have a PCI one in my rig that has the cable to move the antenna where ever I please really, I'm on the second floor of my house and the router is downstairs on the ground floor. Never dropped below 75% signal as far as i am aware.
matt_lumley is offline   Reply With Quote
Old 22nd Nov 2012, 18:00   #19
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Cable all the way - I've never had a wireless card (both USB and PCI) that didn't eventually crap out on me and require disabling / enabling to reconnect to the network... Gigabit ethernet also beats wireless by a factor of 20!
GeorgeK is offline   Reply With Quote
Old 22nd Nov 2012, 19:55   #20
lp rob1
I *am* a Dremel
lp rob1's Avatar
As a real world example, I have a dual Cat 6 cable run through the attic. The two parts that took the longest were cutting the coving in the right way (I am a perfectionist) and nailing in the cable holder things onto loft beams. Since you seem to have a simpler project - run a cable from downstairs upstairs, and possibly though walls - you don't have very much coving (if any) to cut, and there is less nailing things down and routing cables. Depending on the layout of your house, I would say that the easiest option is cable up through the ceiling/floor, then along the skirting board through any walls and to its destination. One length of cable trunking for completion's sake, and there you go. Add in a wall jack if you really think it is necessary, or if you want to keep your computer arrangements modular.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
