#1 |
WIIGII!
bit-tech Staff
Gigabyte boasts of motherboards' 4K capabilities
Dual-Thunderbolt boards drive Ultra HD displays.
http://www.bit-tech.net/news/hardwar.../gigabyte-4k/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
Modder
chops?
__________________
| i5 2500K | Asus P8P67 | 8GB Vengeance | ATI 6950 | | M4 128GB SSD | 2x2TB F4 Eco HDD | Galaxy 850W | | Dell 2407WFP | Dell 2405FPW | TJ07W | Aego M 2.1 | |
#3 |
WIIGII!
bit-tech Staff
To "test your chops" means to prove one's skills. It's a pretty common colloquialism.
__________________
#4 |
Supermodder
big balls / bollocks / big cahonees :-) prove their strength
#5 |
I unsuccessfully then tried again
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, 8GB, 4TB, Samsung 840 Pro 256GB, MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 Put my hands behind my head, crouch down and fall forwards - that's how I roll. |
#6 |
Supermodder
u guys maybe not British or country with British influences like me in SA
#7 |
Multimodder
am i right in thinking the 2012 Olympics were filmed in the Ultra HD 4K resolution?
#8 |
How many wifi's does it have?
Sadly, the Intel graphic solution can't handle this resolution. Already people are saying how nothing is smooth with the MacBook Pro with retina display especial if they play a video and do something else.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#9 | |
Mega mom
But why bring up the retina macbook (Which one?) as an example of how weak integrated graphics are when one of the machines is basically an 'ultrabook' and the other is in a different league spec wise? My retina macbook is smooth no matter what I'm doing, and I'm driving 10 million pixels of display (That's 1.7 million more than a 4K display for those who are counting). I can certainly tell you that your "Nothing is smooth" if I "Play a video or do something else" is factually incorrect. How can this be? Because it has a dedicated GPU, like so many other machines. And shock horror a Kepler class GPU is a pretty capable chunk of silcone and even able to perform the impossible of "Smooth scrolling while watching a video". Of course Intel integrated graphics are going to be choppy when pushed too far, and it's for that reason why any decent spec laptop will have a discrete GPU as well... even Macs. But I'll give you a nod that you have a point about Intel graphics when driving a high res screen. If I force my retina to use the integrated graphics (Using an app or hack) and change my res to 1920x1200 then OSX will actually be working at a resolution of 3840x2400 and scaling it down to 2880x1800 You're still wrong that 'nothing is smooth' when playing a video or doing something else, but yes the integrated graphics are not as competent at driving and rescaling a 4k screen resolution than the dedicated GPU. |
#10 |
6 screens 1 card since Nov 17 2007
Meh, been running at almost 4K resolutions for five years and I started with a 7950GX2 under XP. It was only using one of the GPUs but it still ran Guild Wars at full resolution just fine & medium-high details - though my HD5870 is smoother. 2D was tested on a 6600GT and was smooth. I never had any 4K movie content to test it with though.
__________________
"There are no ordinary people. You have never talked to a mere mortal." C.S Lewis - The Weight of Glory |
#11 | |||||
reviewers, me, and comments on articles and forums.
Intel GPU plays nice up to 1920x1200, anything higher the Intel GPU has trouble, and needs to work at max performance and as soon as you try to do something fancy, like play an HD video, and do something else, like move window or Windows flip 3D or something that uses the GPU in some fashion, it will be quiet choppy. While, an Nvidia or AMD GPU, will have no problem, even a low end model, like a GT 640, or equivalent from AMD, and possibly lower models too. Quote:
__________________
#12 |
Hypermodder
I fail to see what the point of this is.... If you spend more than $500 (or tens of thousands), on a monitor you're not going to skimp out and try to run it on intel integrated graphics. The entire ATI 7000 series (non-rebadged parts) supports 4k over a single HDMI 1.4 or DP 1.2 cable, with the cheapest part (7750) starting at under $100; not exactly a budget breaker.
__________________
Intel Core i5 2500k @ 4.5Ghz
Asus P8P67 16GB Gskill DDR3 @ 1600mhz CL9 1.5V ATI HD 6870 1GB Patriot Wildfire 120GB SSD + 1TB x6 (4.54TB formatted) Raid5 on RocketRaid 2680 |
#13 |
My point is say that this is not news worthy. What Gigabyte has done is just silly. I would agree if thunderbolt was on Nvidia or AMD graphic card... now we are talking.... but then again DisplayPort does already support all of that. So dual thunderbolt, or DisplayPort.
__________________
#14 |
IT Consultant
I see no problem with 2D content, the problem lies on games (3D). Now we hope manufactures start to releasing 4K monitors with REAL price on that (not fantasy price!).
#15 |
36k U.S is not fantasy price :P Then again, the EIZO monitor does display 278 trillion colors, and not 1.67 million.
__________________
#16 |
What's a Dremel?
#17 |
Pan-Galactic Revolutionary
Three 4K monitors for PC gaming!
#18 |
I *am* a Dremel
New 4k monitors you say?
Dusts off 3 year old U3011 2560*1600=4.096.000 But having at a lower price is great news, but hardly a "breakthrough"."
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711 PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1 |
#19 | |
WIIGII!
bit-tech Staff
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! Last edited by Gareth Halfacree; 24th Nov 2012 at 14:46. |
#20 |
a.k.a KazeModz
UltraHD and 4k is NOT the same, thats why they made the term UltraHD, because the TVs being advertised as 4k were in fact not the 4k standard so yeah... every computer running current gen graphics can handle UltraHD resolution just fine.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 • |
| Tags |
| 4k, 4k resolution, displayport, eizo, gigabyte, hd, hd4000, intel hd4000, mini displayport, thunderbolt, ultra hd |
| Thread Tools | |
