Old 23rd Nov 2012, 18:33   #1
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpit
Kepler or FERMI for folding?
The GTX 580 DCII I got in placec of my GTX 670 for folding has died, so I need to buy a new card. Does anyone know if Kepler is properly supported now? When I had a Kepler card, it folded slower than Fermi, although it has double the theoretical maximum procecssing power. As I need to buy a new card tonight (and will only buy new this time - I suspect the 580 DCII had been benched ub#nder LN2) I am looking for whatever info I can get
I have also asksed in the f olding forums, and will post here if I get a definitive reply.
__________________
Folding stats
debs3759 is offline   Reply With Quote
Old 23rd Nov 2012, 18:53   #2
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
id go for a kelper card just because it will be far faster at folding when it is supported...
as far as i know the WU's for kelper cards for in beta testing
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, 7970 OC'd
kirk46 is online now   Reply With Quote
Old 23rd Nov 2012, 18:57   #3
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
At the moment, Fermi gives far better bang/buck. BUT. Kepler will likely lead the way once it is supported.
TaRkA DaHl is offline   Reply With Quote
Old 23rd Nov 2012, 20:59   #4
debs3759
debs3759's Avatar
Thanks guys. I just bought an EVGA 680 SC Signature, should be here on Monday. Fortunately, my ppd indicates the system is still folding on the CPU
__________________
Folding stats
Old 26th Nov 2012, 21:05   #5
debs3759
debs3759's Avatar
The new card arrived this morning and is folding. I look forward to when it properly supports Kepler - at the moment it's only generating roughly the same points as my GTX 570! At least my average ppd isn't going to drop farther
__________________
Folding stats
Old 26th Nov 2012, 22:37   #6
rollo
I Mod, Therefore I Own
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
Kepler will be faster eventually whenever that maybe.
Fermi is faster at the moment.
rollo is offline   Reply With Quote
Old 27th Nov 2012, 01:37   #7
debs3759
debs3759's Avatar
I guess that's why they cost roughly the same, because of the change in architecture not being adopted yet by software developers (at least, as far as Kepler goes). Aat least it runs cooler and has a 3 year warranty
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
