#1 |
Freelander....
The Worst Car in The History of The World
To 'celebrate' the release of Top Gear The Worst Car in The History of The World
just wondering what do you think is the worst car 'In the World'? for me the Morris MARINA
__________________
csx spartan stacker 830 case plus SSD Kingston 120gb,Intel Core i5 3570K,Corsair H80i Hydro Series CPU Cooler,Gigabyte GA-Z77X-D3H,16GB (2x8GB) Corsair DDR3 Vengeance Performance and 2GB Palit GTX 660 Ti JetStream |
#2 |
Maximum Win
with the annoying squeak coming from the front right wheel; mine.
__________________
The King of Crysis // This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus). m_stats.isWalkingOnWater = false; |
#3 |
Super Moderator
Moderator
Of the cars I've experienced personally, an automatic Focus. Brilliant handling, ride, steering and engine spoilt by a dog turd of a gearbox - the manual is great, the automatic hideous.
I'm sure there are worse cars though, I often think the worst cars are the ones that elicit no emotional response at all, i.e. a Golf or something similar, 5 doors of generic machine that does everything well, but has no character. |
#4 |
Stuck in the Mud
BMW X6
What is the point of this car? It's just a tool for complete bell-ends
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3 | Gigabyte GA-EX58-UD5 | WD6401 AALS Zotac GeForce 560Ti | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP |
#5 |
There is no rep for awesomeness.
Moderator
Austin Allegro --it was just crap all around. The first concept drawing showed a sleek machine; what rolled off the assembly line was what happens when a committee gets its hands on the design.
Ford Pinto: without any protective structure or bumper around its rear-situated fuel tank, it had a propensity to burst into flames at the slightest rear-ender. Not so much a car as a mobile barbecue. The Ford Fiero continued that theme by its propensity of spilling oil over the engine which then caught fire. This leakage also caused the car to seize up a lot, not helped by the owner's manual specifying that the car needed to be filled with 3 litres of oil instead of the actually needed 4.5 litres. Yugo, Trabant and Lada: a testimony to Communism as a superior economic system. Dashboard controls would come off in your hands, windscreens would fall into your lap and poorly cast wheels would split in two or make a bid for independence on the motorway. Going uphill made them run out of low enough gears --you had to climb them in reverse gear. But the Americans hardly did any better: the rear-engined Chevrolet Corvair was incredibly unbalanced (for want of a $6,-- part that could have remedied that --design by committee again), and flipped over repeatedly on the test track. The air-cooled engine caused the car heater to fill te cabin with toxic fumes. The non-collapsible steering collumn impaled the driver in a frontal collision. The Chevette had a more original way of killing its driver: the drive shaft could suddenly disconnect from the gearbox, causing the car to pin itself to the road and pole vault over itself. Then there is anything made by AMC. Ugly, badly built cars that fell apart on themselves.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust Last edited by Nexxo; 24th Nov 2012 at 09:53. |
#6 |
An irresponsible
Moderator
They're all shite.
motorbikes ![]() seriously: mid 90s vauxhalls of all types. that weird no-mans land of "hey we dont have to make square cars anymore" before they figured out how to make them look good
__________________
This post is non-negotiable. All terms and conditions apply. Online used motorcycle classified search - Buy a Motorbike |
#7 |
Moderator
The Ford Escort Mk. 4. Nineteen recalls in the first year. 'nuff said.
Volvo 480: great design, worst implementation ever. The engine was underpowered and had an uneven idle. Through their construction, the rear light clusters unintentionally acted as gutters for rain water running down the rear window and therefore were always filled with water. The heavy clutch often caused the clutch cable (which was insanely long as it reached over the engine to get to the gearbox) to push through a weak bulkhead --the first aftermarket mod any decent mechanic did was to reinforce it with a metal plate. Clever gadgets (lit, heated key locks, button-controlled climate control, seat heating) were prone to malfunction. The automatically variable windscreen wipers were linked to engine RPM meter rather than the speedometer. The rear wheel arches were prone to rust. Its road holding and safety were excellent though.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#8 | |
Omnipwntent
They are the epitome of mediocrity and crap build quality. I briefly had a '98 Astra and its reliability went downhill like a ton of bricks from about 3 months after I bought it with a clean history. My older Clio was more basic, but better. My dad owned one in the 90s too and it just smelt thickly of 'car' and was generally uncomfortable as a kid in the back.
__________________
Slash88: That kettle video just made me go death thanks. Fizzban: And it is being panda'd to..lame. |
#9 | |
Fenrir The Wolf
There are many Yugo's them still driving in Croatia,and they have legendary status and large fanbase. American model was even better. Trabant is also a legend-that car that can't rust or be damaged. You could flip it on the roof and then put it back to road like nothing happened. ![]() Lada is awesome-Niva is best buy terrain vehicle-has great value for money. Not like this new fancy SUV's. You can drive trough fence and you don't care. ![]() The worst band is Opel(known as Vauxhall,Saturn or Holden models in different parts of the world). The ultimate rust car with worst hadling-even the school bus has better handling. And not to mention that parts fall off randomly. |
#10 |
Ultramodder
Gearbox wise I have never driven anything as bad as a Citroen C4 Grand Picasso with an auto box. Took over a second to change gear and caused the car to lurch every time, it was so bad I couldn't help but laugh continuously for the first day I drove it whilst my head was shook back and forth.
#11 | |
Is the daddy!
Having said that, the engine is bulletproof and Volvo sorted the gearbox out making it much stronger than the french spec. Worst car, the ford explorer due to the fact that is started the whole SUV market that outed the station wagons in the states, which then came this side of the pond reducing the amount of estate car sales and increased fuel consumption.
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#12 |
Wannabe Martian
QFT. The All-agro was the biggest piece of shite to ever roll of a production line.
__________________
"Maybe we're on Mars because we have to be, because there's a deep nomadic impulse built into us by the evolutionary process, we come after all, from hunter gatherers, and for 99.9% of our tenure on Earth we've been wanderers. And, the next place to wander to, is Mars. But whatever the reason you're on Mars is, I'm glad you're there. And I wish I was with you."
- Carl Sagan A GOO-ster is Born - Build Diary RSS I'm a Great Oakley product tester! My purpose built testing centre |
#13 | |
Making You Feel Old Since 2010
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#14 | |
I Mod, Therefore I Own
Meh, maybe I'm just a bit of a hippy or I just hate the modern equivalent of yuppies. For actual shitness I'd have to go with the Triumph Stag. I absolutely adore this car, the looks, the sound, everything, and yet every single one I've ever come into contact with has literally had the driver with more time under it than in it.
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi Phenom IIX4 B60 (core unlockedX2 560 @ 3.9ghz) - 2x4GB 1333DDR3 - 1.8TB Storage - XFX GTX260 kindly loaned by Lancer778544! rep him! Relix commands you! (he does, honest, told me yesterday) ::The rig made possible ONLY by this great community! Share And Enjoy! |
#15 |
Deaf-mute
Smart cars: detestable hipster transportation that they park sideways by the side of the road, stick out 1-2 feet further than normally parked cars and the owners head is too far up his own arse to see it is in the way of other drivers.
Only saving grace is that in a crash, the crumple zone is the drivers legs
__________________
"I thought what I’d do was, I’d pretend I was one of those deaf-mutes. That way I wouldn’t have to have any goddamn stupid useless conversations with anybody." - Salinger
HAF922 | GA-890GPA-UD3H | Phenom II X4 965 BE | HD6850 | 12GB OCZ/Crucial PC12800 | 2 x 128GB M4 | 2TB WD Green | 1TB F3 | XFX 650W PSU | 23" AOC e2343F | Creative T20 | Steelseries 7H | G9x | WASD V1 | KBT PURE |
#16 | |
Is the daddy!
__________________
#17 | |
BF3: Aardfrith WoT: McGubbins
__________________
World of Tanks Player name: McGubbins |
#18 |
It's big, and it's clever.
Without any shadow of doubt, the Perodua Nippa. I speak from experience.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623 EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered MOON | Thecus N3200pro 3TB RAID5
#19 |
I Endure
Smart cars. I weigh 140 pounds and I can tip one over. This is not a theoretical, but don't ask me how I learned that. It would hurt your head (and incriminate me.) I saw one brave individual take one of those onto the interstate here. Said gentleman had the windows down as his balls were spilling out of the passenger compartment. If he crashed at speed, we'd be sweeping up foil for a month, and cleaning him up with a squeegee.
#20 |
I once drove a nissan micra 03' 1L worse car I have ever driven. It had no redeeming features. The gear box felt like it was made from plastic cogs. It also wasn't geared very well at all was doing 4k rpm at 70 mph. So the max comfortable speed was 60.
__________________
Apple = For the incompetent. My sister owns a iMac, the shame.
| Thread Tools | |
| View Mode | |
