#1 |
Supermodder
New Seasonic PSU REALLY CRAP CABLES!
I recently bought a Seasonic 550W gold standard PSU after getting some good recommendations on another thread I posted here
![]() ![]() ![]() The cables are the horrible flat type and as soon as you start bending them around you can see that the wires are going to start separating and will quickly turn into a tangled mess, this is not what I expected for an £80 gold standard PSU, even my old Zalman modular PSU has all the cables braided and they are quite well done. ![]() When I opened the box I thought "Oh great, another really useful pouch" but actually it will be useful as I can hide the unused modular cables in it ![]() I will be braiding the cables but that's not the point, to me these are horrible, nasty cables of the lowest quality and the sort of thing you see hardwired on really cheap PSU's, NOT IMPRESSED, NOT AT ALL ![]() Not surprising that there are no pictures of the cables on the Overclockers advert. Think I will have to leave a suitable review on Overclockers site
__________________
Al-13 Duplicity, Dual Mobo Scratch build Last edited by ShinyAli; 24th Nov 2012 at 13:20. |
#2 |
Supermodder
same as corsair cables from what i recall
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W. |
#3 |
Mod Master
It's the cheapest 550W Gold PSU on the market, and Seasonic aren't known for their value so they cut corners in their G series. You should be happy you have such a solid spec performer for £80.
Be Quiet, Thermeltake, Silverstone, etc models are all at £100. The Seasonic X-560 is £130. You get what you pay for tbh
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz (no moar IPS xD) | X-Fi XtremeGamer | Corsair 550D | GTX680 CM Storm Quickfire Rapid MX Brown (Filco caps) | Steelseries Xai (yay) | Sennheiser PC360 | Steelseries 9HD
#4 | |
Supermodder
__________________
Al-13 Duplicity, Dual Mobo Scratch build |
#5 |
I Mod, Therefore I Own
I hate flat cables, sata cables are awkward to route neatly so why psu companies choose to use flat cables is beyond me.
#6 |
Hypermodder
Aside from a (subjective) aesthetic point of view, I don't see what the problem is with these cables. I have similar cables on my modular Corsair PSU and haven't found anything to bother me.
#7 |
Satan the one true God / Modarator
If you don't like it spend more and get what you do like, Seems simple enough to me.
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86 A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not ![]() ![]()
#8 |
Undercooked chicken giver
£80 for a 550w psu
Screw that.
__________________
One//i5 3570K 4.5Ghz//Z68X-UD4-B3//8gb DDR3//EVGA 670 F.T.W.//HX850W//CM690ii//2x128 V200 SSD//Xonar DG// Two//i5 2500K 4.5Ghz//Assrock Z68 Gen3//8gb DDR3//MSI 7970//TX750W//Akasa Mirage//128 Vertex+ SSD//Xonar DG//
#9 | |
Mod Master
I can understand your disappointment, but you just need to get used to the market! £80 isn't a lot for a good 550W PSU any more.
__________________
#10 | |
Supermodder
So seasonic sell a gold rated PSU but if you want decent cables you have to pay even more, that attitude stinks to me.
__________________
#11 |
Ultramodder
I bet the cable they use is the same as cable under braid.
Braided cable is just bling, doesent make it quality. It may help if played about with alot, but why would you do that anyway. I bet that cable they used would be as high if not higher than any competitions. If its in spec then thats all you need. Also to be fair heatshrunk cable is only 1 step up from electrical tape. Over moulded cables are always best, which you dont see that often though. |
#12 | |
Mod Master
Edit: and I know I specifically said "cut corners" but I didn't mean it literally, Seasonic hasn't cut corners they've just used standard cables.
__________________
#13 |
Supermodder
I intend to
__________________
#14 |
Supermodder
Cause this is a modding forum and for some sleeving and braiding is considered modding.
__________________
#15 |
I'm special...
They're the same kind of cables that came with my Corsair HX520W (incidentally made by Seasonic). I find these cables to be excellent and I actually wish the Seasonic X-560 came with similar cables instead of the oldfashioned braided ones. I've also never had issues routing this specific type of cable.
__________________
It's not the end of the world ...but you can see it from here. Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA |
#16 |
Supermodder
Braided or not I do my best to hide power supply cables and the flat ones are more easy to hide TBH
Only cables that look nice are individually braided cables the rest should be hidden IMHO honestly your PSU has way more pros than cons
__________________
#17 |
Mod Master
Agreed
__________________
#18 | ||
E-tailer Tailor
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD |
#19 |
Supermodder
personally I think modding PSU cables is a bit of a nightmare I would never even try it.
Voids warranty takes ages costs a packet I just bought braided extensions for my main cables 24-pin, 8pin and 2 PCIE cables
__________________
#20 |
Multimodder
There are reviews for the G-550 (and others in the series), you could have read them to get more of an insight into the product.
Don't know what a gold standard PSU is. If you're talking about 80 Plus Gold then AFAIK Zalman have only recently (in 2012) released their first 80 Plus Gold PSUs in the GoldRock ZM-XG series. |
| Thread Tools | |
