#1 |
Cheesecake Nom Nom
Folding rig rebooting/freezing
Hi all,
i've come into issues with my SR-2 folding rig either freezes requiring a hard reboot, or it reboots its self at least once a day now... i've just pulled the HDD and ran error checks with HD tune pro and all is fine... with it being a really old HDD i thought that maybe the issue but its not ![]() i upped the vcore a notch or 2 to see if it was a stability issue but that didnt solve it either the rig has been munching bigbeta WU's for a few months now with no issues so i'm not sure where to start now
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, GTX680 OC'd |
#2 |
Multimodder
It may be worth checking the PSU, if it's not putting out a stable voltage that could give issues like this
__________________
The Beast: Silverstone PS-07 | i7 970 @4.2 | Rampage Gene II | 12GB Vengeance RAM | H80 | GTX 560-Ti 448 |
#3 |
Cheesecake Nom Nom
How would I check the psu?
I do have a spare one I can swap it with? Sent from my BlackBerry 8520 using Tapatalk
__________________
#4 |
Multimodder
I'd swap in the spare (as long as it has the right number of EPS plugs) and see if you have the same issue. Otherwise I recall that Scan sell a PSU tester.
__________________
#5 |
Cheesecake Nom Nom
just swapped the PSU and started it folding...
will see what happens
__________________
#6 |
Supermodder
Good luck.
Did you run a memory check?
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. |
#7 |
Cheesecake Nom Nom
no i didnt...
can do tho ![]() shes still folding... not complete a WU yet tho.
__________________
#8 |
Cheesecake Nom Nom
Just checked my folding summary and its hung
![]() Sent from my BlackBerry 8520 using Tapatalk
__________________
#9 |
Cheesecake Nom Nom
it has rebooted its self.... but was stuck on the Ubuntu welcome screen
running memtest now.... 2 passes ok?
__________________
#10 |
I'm all you need!
Indeed 2 passes is usually enough. Temps ok?
Random reboots are usually memory, heat or power related. Although I'd take it back to stock clocks to rule that out completely. |
#11 | |
Cheesecake Nom Nom
![]() so far its done 1 memtest pass and at 75% on the second ive changed the PSU still the same.... will have to set it to stock speed..... i wont be able to run bigbeta WU's so the rig will get a 'rest' more often with smp? hmmmm unless i run a bigbeta WU and just take the ppd hit?
__________________
#12 |
I'm all you need!
Or stress test it with something heavy like LinX / Intel burntest without any changes first. If you can reliably recreate the issue with stress testing software it will make testing easier and there's no need to mess with anything folding related, while you hunt for the route cause.
If it reboots while stress testing, then you can remove the overclock and retest. |
#13 | |
Cheesecake Nom Nom
hmmm i dont have a HDD with windows on to stress test it ![]() EDIT: i think i do have one lol
__________________
#14 |
I'm all you need!
Are there not any Linux compatible stress testing applications you can download?
#15 | |
Cheesecake Nom Nom
i only run Linux to fold
__________________
#16 |
Cheesecake Nom Nom
Its been running SMP for 24 hours with no issues :/
__________________
#17 |
Cheesecake Nom Nom
right guys....
its been running SMP for several days with no problems at all i swapped back to bigbeta and it froze at 64% complete :/ ive backed off the OC by 100MHz and started again. its a pita because if i dont catch it within a few hours then i lose my QRB ![]() anyway im thinking of investing in a E5 setup as i can set one up for around £600 for the board and cpu's off ebay hmmmmm or add loads of gpu's to the SR2 for the beta WU's
__________________
#18 |
Cheesecake Nom Nom
right peeps....
since ive backed off the OC 100MHz its completed 2 8101 WU's with no issues now if i up the OC back to what it was and give them more vcore will it be ok hmmmm
__________________
| Thread Tools | |
