Old 26th Nov 2012, 02:12   #1
shuhong90
Minimodder
shuhong90 has yet to learn the way of the Dremelshuhong90 has yet to learn the way of the Dremelshuhong90 has yet to learn the way of the Dremelshuhong90 has yet to learn the way of the Dremel
Grimelegant
Introduction
After a few projects, from corsair 800D to Lian Li-A05NB, to Silverstone TJ 07 murdermod style
and finally to bitfenix prodigy, and honestly I am not that contented. And since my family
member require a small pc for home theater, i figure i could strip down my prodigy (WHITE
MINI), and build a new one for myself and giving it the itx to my family. I had always start
modding internally from a case, this time will be slightly different. A full aluminium case will be
It was my dream case since the moment i was in love in pc modding, but is not brave enough
to stumble on that region. Well now i would be giving it a try, hopefully the result will turn out
great in my and your perspective. Since i had an extra motherboard lying around, might as well
use that one, and in the process of thinking to do some modification to the motherboard as
well, however, that will only be slight modification. This project however, will be a long term
project, as lots of modification is needed, thus, i would prefer not to rush things over. And
another reason of setting this as a longer term project is due to insufficient of fund, unless
there are sponsors :P. So here end my introduction.
shuhong90 is offline   Reply With Quote
Old 26th Nov 2012, 02:15   #2
shuhong90
Minimodder
First picture of the case ~~~
Phew, finally squeezed some time for a few photos =) Got myself a cheapo cooler master
casing. elite 430. Well i got it quite cheap.
Then, I start tearing apart.
Got this
The rest of the case parts of course will be utilized to the fullest, except the front panel that is.
Old 26th Nov 2012, 02:17   #3
shuhong90
Minimodder
ok, it took me more than a week or 2 to completely disassemble the whole thing, was too lazy,
sluggish :P basically its powermac G5 is divided into inner and outer cage. a quick snap shot of
inner cage,
Did soome work over the weekend, some cutting in fact. This stage now focus on creating a
custom back plate. The goal here is to achieve a seamless backplate design. Taking out
whatever tools i have:
Cutting commencing.
Result.
Whatever work left after the cut is filing, which will be done later. Next stage will focus on
creating a backplate and mounting. I'm taking my sweet time, going slow and steady,
cheers.
Old 30th Nov 2012, 04:28   #4
shuhong90
Minimodder
Finished some rough filing on the inner case of power mac G5
The aim of this stage is to mount the back panel roughly this way:
Did some measurement and sample cut out:
Actual aluminium plate cut out and took long long time for filing and trimming down to ensure tight fit.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
