Reply
Thread Tools View Mode
Old 27th Nov 2012, 05:13   #1
PcJunkie209
Multimodder
PcJunkie209 has yet to learn the way of the Dremel
HAF XB mod Not yet named
Hi everybody! I'm starting a mod for CM to have on display at CES next year or couple months actually. This is with their new lanbox the HAF XB. I'll update the hardware list once I have the specs. Here's some pics....
I was able to get Swiftech to sponsor this build. I'm pretty excited about that. Here's some of the parts they sent....
Intel was kind enough to sponsor a board, cpu and SSD....
So right away I tore into the case, so no before pics. Sorry. Here's the plan all three panels will have windows. I'll be having the case either painted or powder coated Intel blue, white and black. On with some more pics....
Holes drilled for Rad on the floor and all my panels are cut...
Thats it for now stay tuned for next update. Until then..............
PcJunkie209 is offline   Reply With Quote
Old 1st Dec 2012, 05:41   #2
PcJunkie209
Multimodder
Here's some pics of the front. I'll be adding a window for the Intel 335 SSD ( which looks a little plain so I may have to give it a facelift! ) in the old hotswap and cutting away the plastic behind the front grill. I also got a package from PPCS they sponsored the EVGA waterblocks for me! They are the best!!! Here's some pics....
Here's all my parts from the HAF XB and Stryker headed for powder coating...
That's it for now. I'll have some more pics when the parts come back. Until then....
Old 27th Jan 2013, 21:25   #3
PcJunkie209
Multimodder
So here we go! I need to get this log caught up so here's some pics......
Time for some hardware...
Thats all for now....................
Old 28th Jan 2013, 00:31   #4
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
Coming out quite nicely, keep up the good work
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
