Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Nov 2012, 09:20   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Game Maker accidentally brands customers as pirates
http://www.bit-tech.net/news/gaming/...customers-as/1
brumgrunt is offline   Reply With Quote
Old 27th Nov 2012, 10:43   #2
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
This is outrageous! You have designed hundreds of sprites for your latest game, taken months to create in Photoshop and other tools. And then some A-holes from which you use their software decides that you are a pirate and completely destroy your work.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 27th Nov 2012, 11:12   #3
Nikumba
Hypermodder
Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.
Originally Posted by [USRF
Obiwan]This is outrageous! You have designed hundreds of sprites for your latest game, taken months to create in Photoshop and other tools. And then some A-holes from which you use their software decides that you are a pirate and completely destroy your work.
And if you dont have a backup of all that work then your total idiot
Nikumba is offline   Reply With Quote
Old 27th Nov 2012, 13:08   #4
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
DRM in "doesn't work" shocker. The pirated version probably has that watermark replaced with a transparent image or removed completely already...
ChaosDefinesOrder is offline   Reply With Quote
Old 27th Nov 2012, 13:28   #5
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
false possitives en-masse could easily be avoided if checked against a database of keys + mac address and allow for say 10 mac addresses per key.
greigaitken is offline   Reply With Quote
Old 27th Nov 2012, 15:34   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Changing your MAC address on Linux is but a single command; doing the same on OS X or Windows is barely any harder. Any security system tied to MAC addresses is doomed to fail.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 27th Nov 2012, 18:00   #7
Rich_13
Hypermodder
Rich_13's Avatar
Rich_13 has yet to learn the way of the Dremel
Agreed/.
__________________
My blog / DSL guide: www.alpagot.co.uk
Rich_13 is offline   Reply With Quote
Old 28th Nov 2012, 01:36   #8
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
Time to sue for BILLIONS!
Gradius is offline   Reply With Quote
Old 28th Nov 2012, 01:50   #9
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan
That DRM system seems like a Dick maneuver. Why not just have it self-destruct a few key files inside of the program? Sure; It means a reinstall, but it does mean that false positives won't be nuking people's projects.
I accept the reasons behind DRM, and why it's not going away anytime soon, but that doesn't mean I have to appreciate completely arse-backwards methods like this.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Strix Soar | 2X SLI Gigabyte Windforce 670 | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | 2x Hynix SL301 250GB RAID0 | 2x WD 3TB RED RAID0 | Lite-on Blu-ray ROM
Dell U2913WM | Sennheiser HD 518s | Microlab Solo8C Speakers | Logitech G13 | Ducky Legend (MX Blues) | Func MS-3
.//TuNdRa is offline   Reply With Quote
Old 28th Nov 2012, 11:38   #10
Optimaximal
Minimodder
Optimaximal has yet to learn the way of the Dremel
Correction. Any security system tied *solely* to MAC addresses is doomed to fail.
It's a good guaranteed out-of-box UID for a system. Spoofing is a problem, but you have to *know* to do it.
Optimaximal is offline   Reply With Quote
Old 28th Nov 2012, 12:23   #11
Gareth Halfacree
WIIGII!
bit-tech Staff
I'd argue that any security system at all is, given enough time and incentive, doomed to fail. You can hire 100 top-end engineers to design your DRM, but you're pitting them against heaven knows how many thousands of top-end hackers. That's not an fight you're going to win.
Guaranteed? Only when manufacturers don't cut corners. Place I worked at once had to bin a thousand or so cheap network cards they'd bought to move from thinwire to Ethernet, 'cos every single one had an identical MAC address...
__________________
Old 28th Nov 2012, 18:08   #12
stone
What's a Dremel?
stone has yet to learn the way of the Dremel
Yes, because that code has absolutely no possibility of containing a bug or getting overlooked in an update, plus you never ever hear of people using virtualized systems in content creation, let alone ones with virtual network cards that can change their mac virtually on a whim. Also there are no other tools this could have bad interactions with. For instance, some ISPs only issue different IPs via DHCP for different MAC addresses, so there are tools that change the MAC so you get issued a new IP (for whatever reason you need that). As a sane human, would you expect your copy of the software to suddenly trash your work after 10 times of doing that, but not before?
I'm not sure how much this software phones home usually, but an extra database check and online requirement for something as stupid as a MAC database is a bad idea in its own right.
You know how this could be easily avoided? Yeah. Don't treat your customers like crap. Don't saddle them with DRM. And if you absolutely positively have to have them bend over just a little further, do something non-destructive. Like quitting the application.
stone is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
