#1 |
Ultramodder
Do any of you leave your computer on 24/7
Is this ok for the health of the computer? I guess stuff like fans just die earlier
not idling btw. Mine is usually constant at around 50% cpu doing various stuff
__________________
BF3: Pr0_snipe i7 2600k @ 4.6 | Asus P8P67 Deluxe | Asus GTX 670 Direct CUII TOP | Gskill Ripjaws x 16gb 2200mhz | Noctua nh-d14 | Antec 1200 | Enermax Revolution87+ 850w | Crucial M4 64gb | WD Caviar Black 500gb | Dell U2711 |
#2 |
Multimodder
Yes i leave mine on 24/7. powering up and down hdd's all the time is pretty much the worst thing you can do to them. Haven't had a hdd failure in years.
#3 |
Supermodder
I don't personally think you should leave them on all day every day, I always turn mine off!
__________________
Steam/Battlelog: chewbaccas_nan |
#4 |
Multimodder
I always leave mine on. It probably does degrade the life of the fans and other components. But in today's PC world, upgrades are fairly common every 2-3 years anyway.
__________________
Intel Core i7-2600k @ 4.4GHz | Corsair H100 | ASUS Sabertooth Z77 | G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1866 | 2x Crucial C300 256GB SSD| 2x MSI GTX 680 Twin Frozr III 4GB | Rosewill BLACKHAWK-ULTRA | Kingwin Lazer 1000W | LG 10x Blu-Ray Burner | Creative Sound Blaster Recon3D THX | Logitech G500 | Razer BlackWidow Ultimate (Dragon Age III Edition) | 3 x Dell UltraSharp U2412M 24" 3600x1920 | Logitech Z-5300e 5.1 | Win 7 x64 Ultimate |
#5 |
Side bewb.
Was told at uni by a lecturer to leave PC's on 24/7, the cpnstant spinning up (on reboot) of the HDDs etc can cause issues with them. I've never done any research into it though.
I turn mine off as if I leave it on, I can see the power bill rise a little too much.
__________________
Bewbs. |
#6 | |
Margon Man
I don't leave my pc on all the time. I have a home server that I leave on all the time. I got a few machines here at work that have been on for years, and they were old machines to start with. Really if its well cooled etc. then there is no harm having your machine on all the time, it just uses more power etc. If I left my pc and my server on in my room all the time, i could start selling space as a sauna! I have no heating in my room all year round and its always toasty. and the server creates a nice amount of white noise to aide sleeping......oh yeah its a huge pain sleeping with a server on!
__________________
i7 920 - 12GB - 5870 Keycool 87 Modded Clears - Cougar Attack Reds - KBT Oni Browns - Ducky DK1087 Blues - Cherry G80-3700 Blacks Last edited by Margon; 29th Nov 2012 at 15:11. |
#7 |
Super Moderator
Moderator
It should be easy to calculate which is best for a drive, but it's not.
![]() If the spec sheets still had MTBF on them, you could compare MTBF and the load/unload cycle count to see which one you would exceed first. Chances are a power up and down once a day over the lifetime of a drive won't have a huge significance. |
#8 |
I leave mine on 24/7 but put it to sleep while at college / asleep.
As far as I know, leaving it on 24/7 won't do any harm as long as it is sufficiently cooled. Things may die earlier time wise, but you should get the same usage out of them. E.g. If something has a 3 year life span and you use it 24/7, it will last 3 years. If you only use it 12 hours every day, then it will still last 3 years, but it will take 6 years to reach 3 years of usage.
__________________
NZXT Tempest EVO >> Phenom II X4 955 >> Thermaltake Frio >> Zotac GTX570
ASRock 890 GM Pro3 >> 4GB (2x2GB) Crucial Ballistix DDR3 1600MHz CL8 >> Corsair TX650W Samsung Spinpoint F3 1TB >> NZXT Sentry 2 >> WD Caviar Black 640GB |
#9 |
Good news everyone!
Mine is only on when I'm playing a game or watching Youtube/browsing. So about 3 or 4 nights a week for between 2-4 hours at a time.
The Nexus 7 and Galaxy SII take the lion's share of the browsing duties in our house now.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#10 |
Ultramodder
depends if I forget or not to turn it off basically. Sometimes, I don't go in the office for days. In which case... it's more like 24/3
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | 7950w/boost WC | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | Cheap LG IPS
#11 | |
How many wifi's does it have?
Business class systems -> Depends if it's a low-end or high-end, workstation or server or normal desktop PC High-end gaming/workstation PC that we buy -> No problem. Assuming you clean the dist out of your computer properly every 3 or so months (depends on the dust level where you are), quality fans should last you 5-6 years+. Quiet fans might get a bit noisier, but nothing much, unless you got crappy quiet fans. I know Noctua fans has a 6 year warranty on them. So I guess they know it won't get loud or break over time.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#12 |
Butt-kicking for goodness!
Mine gets turned off for windows updates. That's about it.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors BT Feedback |
#13 |
Too broke to mod
Mine is always in sleep mode. I'm either at it, or it's in sleep mode. I only restart when I need to.
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 8GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | 2GB 6950 | Asus PA248 IPS + Acer P243w | Asus Xonar d1 | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Cooler Master Quick Fire Rapid | Cooler Master Inferno Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook |
#14 |
Same here.
__________________
#15 |
I Mod, Therefore I Own
Depends what it's doing, if I've Brought stuff to download from steam Ect then its turned on, but if its doing nothing and I'm not going to be using it again it gets turned off.
iPad handles general web browsing duties in household. My phone works fine for me 90% of the time if I'm just browsing around. Dou't it saves alot of electric in truth rig is bearly using 100watts at idle, our washing machine uses some insane 2kw/hr and is on pretty much all day. Photo vid rig is shutdown if not in use. |
#16 |
I *am* a Dremel
never could get sleep mode to stay in sleep always randomly wakes up.
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711 PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1 |
#17 | |
- Open Command Prompt as true Admin. - Type: cd C:\. Hit Enter - Then, type: powercfg -energy. hit Enter A report will be done and saved in your C:\ drive. Usually culprit are: -> Keyboard/Mouse -> Bluetooth device -> Network/Wireless wake-on LAN or/and magic packet All of the above can be solved in their properties of Device Manager panel.
__________________
#18 |
E-tailer Tailor
I will admit, I'm kind of horrified by the sheer wastefulness going on here. The hell is wrong with you people?
![]() When I'm not using it, my computer's off, just like when I'm not in it, my shower's off, my bedroom lights are off, and my car is off. Anything else is just a colossal waste of energy. Your computer turns its disks off all the time by default anyway. I've been turning my computer on and off at least three times a day for the last ten years, and I've never had an HDD failure. I'm kind of stunned that you guys consider leaving a computer on 24/7 (at a guess, running at a draw of about say... 200W when it's running?) reasonable. I'm not sure what a unit of electricity costs on average in the UK at the moment - I think it's about £0.14/kWh - but at that price it's costing you £245 a year, and that's before you get into the cost of running a display. If you ran it when you were actually using it (say 4 hours a day) you'd save £204, or the cost of three SATAII 1TB drives every single year... It may be that when you're saying "Oh, I leave it on 24/7" what you mean is "Oh, it's hibernated when I'm not using it" but that turns your drives off anyway. Why, if you know you're not going to be needing it to return to exactly where you left it for the next few hours (e.g., because you're asleep/at work/at school) would you not turn it off? This reminds me of the asshat in a water cooling thread who was saving money by not buying a radiator or a pump for his water cooling loop - he was running an open (that is, full loss) loop straight from the water mains, through his loop, and into the drains. His excuse was that he paid a flat rate for water. I hate people sometimes. ![]() You got a sensitive mouse by any chance?
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD Last edited by PureSilver; 29th Nov 2012 at 20:05. |
#19 |
200W? Nha.. unless you have people insist in setting Windows power plan to Higher Performance, instead of Balance. Oh well not my electric bill.
__________________
#20 |
Umpteen to the elfteeth
Servers and workstation stay on 24/7. Only exception is power outage longer than two minutes.
__________________
Too weird to live, and too rare to die | Help me get more space at Dropbox | Hardcore gamer and proud of it Main: i7 3770 | Asus P8Z77-V LX| ENGTX560 Ti DCII TOP | 16GB | 7 Professional 64bit | 24"+24" | Crucial M4 256GB | 1,2TB HTPC/VMhost: Q6600 G0 | Asus P5N-D | HD4350 Silent | 8GB | Windows Server 2008 R2 | 3TB RAID5 (two identical boxes) Samsung SF510 | Archos 101 8GB | HTC Wildfire S Black | Oh man. My iPod Touch got wet in ra1n. | 100/50Mbps VDSL2
| Thread Tools | |
