Reply
Thread Tools View Mode
Old 30th Nov 2012, 00:00   #1
great white
Banned
great white has yet to learn the way of the Dremel
Toshiba satellite P30 revival..."The Tank"
As in the subject line I've got an old Toshiba that just won't die.
It's a tank. Both physically and Software wise. A big, clunky, "push through anything" tank.
P4, 3.0 Ghz, but 512 MB ram. Meh, it does the job. Cpu always run low percentages, ram is always maxed and into heavy disc access.
It checks email, surf's the net, plays videos and DVD's, runs photoshop CS and does pretty much everything else I ask of it with little or no complaints.
I'll probably put more into it than it's worth, but money is not what this is all about. Just a little fun with an old friend.
It slows down from time to time, but that's usually my fault and a quick clean up gets the speed back up (at least what speed it had).
I've had it apart more than a dozen times. It's been ripped off the table by the power cord more than I can count (and resoldered inside). It's bounced down a flight of stairs. It's been literally around the world more than a half dozen times. The built in Ethernet adapter has died and is now a Belkin usb unit. Ditto with other conflicts that have been disabled.
Yes it's big, yes it's heavy but it's the one I reach for when I need it to work.
I like the speakers (Harmon and they sound really good in the context of a laptop), I really like the big screen and I've got a nice Kensington briefcase/carrier for it that I use every day even when the laptop isn't in it.
So I'm going to upgrade the old beast a bit and modify it. Time for some fun.
First up is RAM. It's running the original 512. Yup, it works ok but compared to modern machines it's sloooowwwwww!
50 bucks gets me the max 2 Gb PC2700 DDR it will support.
Next up is a backlit keyboard. I've always wanted one, usb lights suck. So I order up a Toshiba M505 backlit keyboard. 30 bucks so I'm not out much if it can't be made to work. Looks to be the same format and size as the P30. Some keys are moved around, but I can remap those if the keyboard works. I'll need to wire the leds up myself since the P30 doesn't support a lit board.
Some lighting and painting will come along also. Haven't decided on what yet but I'm 47 years old so it will be something fairly reserved yet unique. "Classy" at least.
Some cooling modifications will also be in there. I have a few ideas for that.
I'd like more USB ports, I'll have to dig around the board and see what's supported.
It's running the 5400 drive. A 7200 or maybe a SSD will come along eventually although theres probably not a lotof sense in ssd since the old beast is a pata interface. Storage isn't a big concern; I keep everything I need besides the programs on a 1 TB compact external drive and the current 55g drive is only 55% full.
Bigger battery will also be needed eventually (more piles in the case if it can be had) or at least a new one. It's almost always used plugged in, but the battery dies off within 20-30 minutes when called upon to support. I treat it more as a UPS and make sure I don't run too long on it if I'm doing anything important.
I'd like to find a way to get HDMI out of it, but there's no way to do the card change and most TV's support the PC out now anyways. It does support S-video, but that is dying out also it seems.
A better sound card would also be nice, but he proprietary nature of laptops gets in the way once again.
I'd also like to up the wifi a bit (N would be nice), but not sure what it will support.
Adding internal GPS would be nice, but not essential. Bluetooth would also be nice.
For a laptop, there's lots of room in the case so some additions may just be possible through internally wiring some USB access or by some other means.
OS will most likely stay XP SP3. I know it, it supports all my stuff, doesn't need custom drivers for the older hardware and it just plain works for me. The vista and W7 machines we also have just never feel right to me...never quite as easy to use or just seems to "restrict" you in some way.....
So, that's where I am; big dreams and waiting for parts.
We'll see where it goes and how well "The Tank" takes to it.
I just can't bring myself to chuck it out just because it's "old tech". Heck, I've still got a Compaq Armada 1750 that I use and just won't die. That one is even more of a "tank" than the Toshiba, although it just carries my tuning software for the diesel these days.....gotta love being able to still use a serial port for my older interfaces!
Yeah, I guess I'm just and old sentimental fossil....
great white is offline   Reply With Quote
Old 30th Nov 2012, 08:56   #2
great white
Banned
Work begins on the "case":
The basic form finished, clay work begins:
Once the clay work is done, it's into the mold compound to make the negative. Then the fiberglass work begins.
The plan is to have the front "scoops" as air intake and the case will exhaust out the back.
Kinda big, but it's already a monster of an old laptop and I'm going for a bit of an automotive style look to the front....
Old 30th Nov 2012, 13:25   #3
tp148
Multimodder
tp148 has yet to learn the way of the Dremeltp148 has yet to learn the way of the Dremeltp148 has yet to learn the way of the Dremeltp148 has yet to learn the way of the Dremeltp148 has yet to learn the way of the Dremeltp148 has yet to learn the way of the Dremel
ignore
tp148 is offline   Reply With Quote
Old 30th Nov 2012, 16:22   #4
great white
Banned
Originally Posted by tp148 View Post
Hi you should probably read the forum rules,
First post should contain pictures of modding in progress....
Understood. I sent a revised post with pics but this is the one that was posted. Second post has been submitted and has pics. Waiting for moderator approval.
Old 30th Nov 2012, 22:09   #5
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Alienware style mod. Nice.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is online now   Reply With Quote
Old 30th Nov 2012, 22:45   #6
great white
Banned
Just buying an M17x would be nice!
The size and weight isn't a big concern for me, but the $3000 price is...
Old 1st Dec 2012, 17:31   #7
great white
Banned
Work continues:
Still thinking about what to do with the center area.
I'm thinking a center "bar" like a car grill with a lighted "Toshiba" logo. I also may put some micro sized switches under it to control the LEDs I'm adding in the case and the key board. Possibly a pwm type dimmer....i don't want LEDs on full bright (or maybe not on at all) all the time.
Old 1st Dec 2012, 22:20   #8
great white
Banned
Well, I started out with an "Alienware" theme, moved on to trying to make a car grill but somewhere along the way an alien face came out of the clay:
I was going for an automotive "grill" look using a cadillac cts-v as a model, but it seems the alien inside cannot be denied!
Lol.
Old 2nd Dec 2012, 19:32   #9
great white
Banned
Well, all those days of sculpting and adjusting are over and the clay is now just a great big ball on the table.
But, it did not sacrifice itself in vain:
Mold is done!
It's a little rough, but easily fixed. The details I needed from the pour are almost perfect. The bottom will need another pour to level it out but that's about it.
Then it's on to laying up the fiberglass.....
Old 3rd Dec 2012, 00:06   #10
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
oh lordy lordy lordy!!! an old tank being remodled into an ALIENWARE tank reminds me of that idea i had to watercool an alienware laptop.... hmmm.. *goes off in a lightningstorm as month old nuerons fire up and spew dust*
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 3rd Dec 2012, 10:02   #11
ferret141
Hypermodder
ferret141's Avatar
ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!ferret141 - it's over 9000!!!!!!!!1!1!1!!!
Not impossible:
http://www.youtube.com/watch?v=uhw1n1N0hD0
http://www.techpowerup.com/forums/sh...ad.php?t=39547
http://hackedgadgets.com/2006/10/28/...cooled-laptop/ Interesting inline pump
__________________
Intel i5 2500K | Thermaltake Frio | 4x4GB Corsair Vengeance LP | ASUS P8P67 Pro | EVGA GTX680 2GB SC Signature 2 | Silverstone ST85F (850W) | 256GB OCZ Vertex 4 | 1.5TB Samsung F3 | 2TB WD Caviar Black | SONY-NEC BD-5300S BD-RE | Silverstone Raven 2 Evolution (RV02E-BW USB3.0) | ASUS VG278H 3Dv2 | Win7 Ult. 64bit | Creative X-Fi Fatal1ty Platinum Champion Series | Speakers:Logitech G51 | Headset:Beyerdynamics DT770 Pro | Keyboard:Logitech G15 | Mouse:Logitech G9x
ferret141 is online now   Reply With Quote
Old 3rd Dec 2012, 10:15   #12
siliconfanatic
already seen 'em diff. is i aint gonna use no ghettofied resin block. mine'll be made fer dat crud, with a bit of a better pump if can find one. just gonna need 40 or 80 mm wide rads.... alll depends on how i restyle it, if i do that right anything goes. initially wanted to replace the gpu but hehe thats abit of a pipedream. specially considering the laptop market isnt as easy to undrstand as desktop mrkt. just gotta buy a fairly spec'd alienware and open her up.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
