#1 |
Administrator
bit-tech Staff
Corsair H80i review
#2 |
Relapsing Filcoholic
Nice review
I've been looking forward to this (and your H100i review?) - particularly like the comparison between intake and exhaust.
__________________
Main Rig: i5 760 @ 4GHz | H100i | EVGA GTX680 2GB | GA-P55M-UD2 | 8GB Dominator LP 1600 | 1TB F3 | 128GB M4 | X-1050 | CM690II Adv | VP2365wb | Xonar DX | SP2500s HTPC: i3 2125 | H61I-E35-B3 | Lian Li PC-Q11b | 4GB 1066MHz | 64GB M4 | ST50F-P w/PP05 Short Cables | HP bd240i NAS: HP Proliant Microserver | 8Gb 1333MHz | 250Gb OS Disk | 2x2Tb Samsung F4 Raid 1 | WHS 2011 Keyboards: Black Filco TKL w/Reds| White Filco TKL w/Browns | Poker w/Clears |
#3 |
DemonHighwayman
I'd love to see an H100i and its results. Is there anyway BT could incorporate in to the final score some kind of reflection on the reliability of a companies older products ? I just ask because there are so many horror stories around the web of these all in ones leaking or pumps not pumping etc.
__________________
Main Rig:Case: CoolerMaster Cosmos S, Motherboard: Asus M4A785TD-V Evo, CPU: AMD Phenom II X6 1100T, RAM: 8Gb 1600Mhz Corsair Vengeance GPU: XFX ATI 5870, Primary HDD: 128Gb Kingston SSDNOW 200, Optical Drive: LG Super Multi Blue HTPC:Case: Gutted out VCR, Motherboard: Asus AT5IONT-I, CPU: Intel Atom D525 @ 1.94Ghz, RAM: 4Gb 1333Mhz Kingston GPU: Nvidia Ion 2, Primary HDD: Hitachi 500Gb, Optical Drive: NEC ND-6500A Laptop Drive |
#4 |
No matter what product you choose there will always be 'horror stories' of stuff dying and taking other stuff with it - PSUs in particular... There may have been problems with some H80s or H100s but, as far as I know, these are mainly new products (new pumps, new tubing, new fans etc) - I don't see that it would be fair to downgrade a new product based on a previous product that possibly only carried the same name (and may even be made by a different OEM)
__________________
#5 |
DemonHighwayman
I get that GeorgeK, but the re branded stuff comes from two different manufacturers (I think) and maybe just a short paragraph highlighting the past record of the original manufacturer and saying if the new product looks like its using the same dodgy parts or not.
I realise its probably not fair to mark down a product on a companies past mistakes I just think some info should be chucked into the reviews about any bad history thats all
__________________
#6 |
Gerwaff
Judging a product on the reliability of the previous generation is just crazy.
Of course you will find more 'horror stories' for products online than 'success' stories... I mean who thanks the manufacturer for supplying a working product!
__________________
:: ASUS Maximus IV GENE-Z :: i5 2500K @ 4GHz :: 16GB Corsair Vengeance :: 256GB Samsung 830 :: :: Awesome, Reliable Website & Server Hosting :: |
#7 |
Post moar ponies.
bit-tech Staff
H100i is tested, review in mere days.
#8 |
Awesomeness - can't wait
![]() I still don't see the merit of referring to a company's previous products - unless you happen to have data on all the H100s ever sold you're just going on internet hearsay - as Atomic has already said, for every 'wow my H100 is working brilliantly' post on the internet there must be 50 'OMG MY H100 HAS LEAKED!!!!!!1111' posts...
__________________
#9 |
DemonHighwayman
I guess you guy's are right, i've just seen a lot more negative stuff than positive stuff mentioned, even here on bit-tech.
__________________
#10 |
Same here admittedly - posting problems online can lead to fixes however. With the H100i there was initially a problem with the fans 'rumbling' at very low speeds but, because people posted online about it, Corsair released a firmware update to sort it within about a week of it being noticed - hats off to them I'd say
__________________
#11 |
Gerwaff
I'll be waiting for the H60i to come in stock anywhere, need something to replace my noisy air cooler!
__________________
#12 |
What's a Dremel?
Nobody posts "I bought this product, it works exactly as I had hoped!" on the internet.
#13 |
Does not play well with others.
I hate to moan but...
25/30 value for a £75 cooler? Ouch! |
#14 |
Hypermodder
How can this perform better than a Corsair H100 on LGA1155? It doesn't make sense. Are you sure there isn't an error somewhere?
#15 |
pew pew pew
New fans? However I fully expect the H100i to outperform it, so order will be restored.
__________________
i7 3770 | Asus RoG Maximus V Gene Z77 | 8GB 1600Mhz Vengeance | Crucial M4 256 & 128GB | Corsair H80 + Gentle Typhoons | Corsair AX750 | EVGA GTX 680 SC 2GB | Xonar DX | Silverstone FT03 |
#16 |
Multimodder
Surely having magnet beside the CPU cannot be a good thing....can it?
#17 |
Multimodder
An idea I'd like to see tested is compare the results of this cooler with a Corsair H80 with Corsair SP120 fans attached over the stock fans.
I upgraded mine with said above fans and saw 5-10 degrees knocked off my temperatures, so in my mind a £20 upgrade of fans (and sold the old ones to recover the costs) resulted in simular results to your lab tests. Also, hate to point it out, but in the first page you talk of AMD fitting... Yet no AMD test results. Any particular reason for this or just lack of time? |
#18 | |
No, seriously, wtf is a dremel?
bit-tech Staff
#19 | ||
What's a Dremel?
| Thread Tools | |
