Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Nov 2012, 10:26   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Sapphire brings Vapor-X tech to CPU cooling
Vaporisation cooling offers 200W of dissipation.
http://www.bit-tech.net/news/hardwar...-vapor-x-cpu/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 30th Nov 2012, 11:29   #2
Tyrmot
Supermodder
Tyrmot's Avatar
Tyrmot has yet to learn the way of the Dremel
Review incoming?
Tyrmot is offline   Reply With Quote
Old 30th Nov 2012, 12:12   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Interesting ... waiting for reviews !
GuilleAcoustic is offline   Reply With Quote
Old 30th Nov 2012, 13:19   #4
Bloodburgers
Multimodder
Bloodburgers has yet to learn the way of the Dremel
Sadly i am not in the market for a new cooler until i re-build my current system however for those who are they are on offers at ocuk. (i do not work for ocuk i hasten to add)
http://www.overclockers.co.uk/showpr...odid=HS-000-SP
__________________
Leviathon: Asus Sabertooth 990FX, AMD FX8320, Corsair H40, 8GB Corsair Vengeance 1866Mhz, Seagate 2TB , CORSAIR HX 520W MODULAR PSU, XFX HD7850 2GB Black Edition
Bloodburgers is offline   Reply With Quote
Old 30th Nov 2012, 18:17   #5
flibblesan
Destroyer
flibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpit
I need to see a review on this as these type of CPU coolers have been tried before and failed.
flibblesan is offline   Reply With Quote
Old 1st Dec 2012, 10:56   #6
Bakes
Hypermodder
Bakes has yet to learn the way of the DremelBakes has yet to learn the way of the DremelBakes has yet to learn the way of the Dremel
Can we stop with the whole bit-tech 'can dissipate x heat'? Of course it can dissipate 200W heat; anything can dissipate 200W heat. Seriously, if a pinhead were at a sufficient starting temperature it would be able to dissipate 200W heat at room temperature, because the temperature gradient would be high. Even the Artic Cooling Freezer 7 Pro was marketed at being able to dissipate 200W heat, back in like 2007.
Bakes is offline   Reply With Quote
Old 1st Dec 2012, 16:19   #7
Roskoken
Multimodder
Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.
To think google have been spending a fortune on elaborate server cooling for all this time when all they needed were some pins!
You should email them RIGHT NOW with your theory.
Roskoken is offline   Reply With Quote
Old 1st Dec 2012, 23:32   #8
foxrena
What's a Dremel?
foxrena has yet to learn the way of the Dremel
It's funny everytime I see comments like yours. You think you know but you don't.
This is simple physics... claiming 200W heat dissipation is meaningless if no temperature difference is given. It's just a way of advertising for the company. I would hesitate buy such a product if I see these misleading ad numbers.
What truely matters for a cooler is the C/W ratings, as should be used by all cooling enginners. Anything can dissipate 200W, @Bakes is right. The stock cooler can dissipate 200W of power when it's 30C higher than ambient while a high performance cooler dissipates the same amount with maybe only 10C higher than ambient. When you compare 0.15C/W with 0.05C/W, you know which is better.
Sapphire engineerers know this. But their marketing department do not care.. They will just throw out a numbe .... 200W, sounds plenty, Ha!
foxrena is offline   Reply With Quote
Old 2nd Dec 2012, 04:12   #9
feedayeen
Multimodder
feedayeen has yet to learn the way of the Dremelfeedayeen has yet to learn the way of the Dremelfeedayeen has yet to learn the way of the Dremelfeedayeen has yet to learn the way of the Dremelfeedayeen has yet to learn the way of the Dremel
What Bakes said is physically accurate. Newton's Law of Cooling says that heat transfer is directly proportional to both surface area and temperature difference. If you make either one of these values large enough, it compensates for the other.
feedayeen is offline   Reply With Quote
Old 2nd Dec 2012, 14:32   #10
xxxsonic1971
W.O.T xxxsonic1971
xxxsonic1971's Avatar
xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.
Looks like Darth Vader built it....
__________________
intel pentium 4 640, 1gb ddr2 @266mhz, radeon x600.
xxxsonic1971 is offline   Reply With Quote
Old 2nd Dec 2012, 15:22   #11
Roskoken
Multimodder
Only if its linear
Old 2nd Dec 2012, 16:16   #12
feedayeen
Multimodder
Only if its linear
I figured you would have dropped this. Newton's Law of Cooling applies to the lumped capacitance model of thermal bodies where temperature remains at a constant temperature inside both bodies. This improves the rate of heatflow since the gradient is so narrow. For small or metalic objects, it's a good approximation, for air, not so much since the thermal conductivity sucks. But even when you factor this in, you wind up with a temperature curve that looks like 1-e^-x with some constants to scale the amplitude so that x=0 produces the temperature of the heatsink and another to determine the half life.... but even this is linear since the derivative at x=0 is proportional to the temperature.
I've already determined that it's linear so I could stop this right now, but it's actually better than that. If you get really, really hot, well above what semiconductors can survive at, maybe 500-1000C depending on geometry, the warm air will have significantly less density than cool air, convection has now become a major force.... In practice, it reduces the size of this half life and thus makes the derivative at the boundary x=0 larger, thus more heat flow.
You then have blackbody radiation, which is proportional to 1/(e^(1/x) - 1), this curve starts out less than linear and it's one of the least efficient modes of heat transfer, but it accelerates slowly.
Old 2nd Dec 2012, 17:58   #13
Bakes
Hypermodder
Only if its linear
Shh you. Even if we completely ignore Newton and just stick the pinhead computer in space, by the time we reach 10000C it's emitting about 500W in black body radiation alone. If you can make your components survive temperatures of 10000C, then by all means attach a pinhead for cooling purposes, because it'll get the job done.
Old 3rd Dec 2012, 11:47   #14
Kris
Lord Lolwut
Kris has yet to learn the way of the DremelKris has yet to learn the way of the DremelKris has yet to learn the way of the Dremel
I love the discussion - who knew you could get from a CPU cooler to black body radiation with only so few comments.
In all seriousness though: what if sapphire actually, against all odds, took the number 200W as it's "normal" mode of operation and performance as compared to the competition? (like keeping a 3960X at 50C while it is OC-d to 4,5GHz or whatever) One can hope.
__________________
Phenom X4 B50 @3.5GHz| 2x2GB DDR3 1333Mhz | Asus M4A79XTD Evo
Radeon 6950 2GB | 1TB + 500GB Samsung F3 | Akasa Omega | Akasa Nero
Kris is offline   Reply With Quote
Old 3rd Dec 2012, 11:55   #15
Gareth Halfacree
WIIGII!
bit-tech Staff
If Sapphire had released any other figures, you'd have those too. As it is, "can dissipate 200W" is as close as the company has got to talking about performance. If it makes you feel any better, assume a worst-case scenario of "can dissipate 200W of heat without allowing the CPU temperature to raise to a point where it would trigger the chip's thermal cut-out."
In other words: yes, a pin head could dissipate 200W of heat - but not without raising the CPU temperature to a level at which it stops operating. The Vapor-X CPU - and any other cooling system that says "can dissipate XW" - by contrast can.
__________________
Old 3rd Dec 2012, 12:04   #16
LennyRhys
Fan Fan
LennyRhys's Avatar
LennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming Saiyan
My GPU uses a similarly hyped "vapour chamber" style cooling and although it works well, it's still a bit of a gimmick. Heatsinks do what they are meant to do: they take heat away from the component and dump it.
If anything, this heatsink has arguably missed the bus by going the 120mm route; the very best air coolers are all 140mm and it's unlikely that a 120mm heatsink will be able to compete, whether it uses vapourisation or not.
EDIT: the "dense aluminium fin stack" is also a bit of a step backwards... all it means is that the cooler will need powerful fans for optimal performance (or, conversely, that it will fail dismally when furnished with quiet fans).
EDIT 2: The American spelling of Vapour is really bugging me.
__________________
i7 5820K | MSI X99A Gaming 7 | 32GB Ballistix Sport | EVGA GTX980Ti SC | Corsair RM550 | Dell U3014
LennyRhys is offline   Reply With Quote
Old 3rd Dec 2012, 12:08   #17
jamsand
Ultramodder
jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.
Looks like it'll be loud as hell, 40 at 2200rpm!!! I'll stick with my silverarrow or d-14
jamsand is offline   Reply With Quote
Old 3rd Dec 2012, 12:25   #18
Gareth Halfacree
WIIGII!
bit-tech Staff
Same. It's a proper noun, sadly, so I have to override my fingers every time I try to 'correct' it - i.e. every single time I type it...
__________________
Old 6th Dec 2012, 01:20   #19
Bakes
Hypermodder
Yes, it's all you've got, but it's a totally useless piece of information, because it tells us nothing about the quality of the cooler. For example, a standard 3770k will throw out about 77W when not overclocked; basic electronics tells us that if at 5GHz with a fairly dramatic 1.45V vCore it will be sticking out about 148W - which is enough for an Artic Cooling Freezer 7 Pro v2, which is rated at 150W (sorry, didn't mean 200w in the previous post).
Would you want to run those settings with a Freezer 7 Pro? Probably not.
All the numbers are saying is that what they've come up with is at least a viable CPU cooler. < Not interesting info.
There's not really any point attempting to quantify it/buying into the marketing info; the information means nothing, because any modern processor would be running at obscene speeds before it would actually release that much heat (I may be overlooking some of the Sandy Bridge-E parts here). < my point
Old 6th Dec 2012, 08:48   #20
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
silverarrow is noisy as heck compared to my passive hyper Z600
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Reply
Tags
120mm fan, air cooling, aluminium heatsink, cpu cooler, heatpipe, sapphire, sapphire dual-x, sapphire vapor-x, vapor-x, vapor-x cpu cooler
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
