Old 2nd Dec 2012, 13:52   #1
Scorpuk
Supermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Which GPU
Looking at adding a GPU to my i7-2600k, but not sure what to go for.
I have an unregistered copy of Windows XP, so can use v7 client no probs.
How are 640, 650 or 650ti at folding?
__________________
Folding stats
Folding Summary
Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit.
Scorpuk is offline   Reply With Quote
Old 2nd Dec 2012, 14:36   #2
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
TBH Scorpuk the kelper GPU are not that good at folding.... yet...... they will be tho... id wait till the Standford releases the optimized core thingy and see peoples results.
if you want to earn big PPD now my GTX560 non Ti is set to run the beta WU 8057 its getting that WU 90% of the time and getting 125k ppd
i red that the 570/580 pulls 200k +
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 3rd Dec 2012, 05:11   #3
Scorpuk
Supermodder
Hmm.
Maybe I shoudl get a 680/690 for my gaming rig and move the 580 to the fold.
__________________
Folding stats
Folding Summary
Old 3rd Dec 2012, 07:48   #4
kirk46
Cheesecake Nom Nom
kirk46's Avatar
I'm looking at getting a 670/680 for gaming, and folding,
And keep the 560 to fold, I've also just bought a 480 which pulls 130k +
But don't forget this beta WU won't last forever
Sent from my dated BlackBerry using Tapatalk
__________________
Old 3rd Dec 2012, 16:11   #5
Scorpuk
Supermodder
Think I'll hold off on the 680/690 and fold on my gaming rig while I am away.
Just bought 9 WD 3TB RED HDD's to replace the 6 2TB drives I have in the server. Will run them in Raid 6.
Early Christmas present for myself.
__________________
Folding stats
Folding Summary
Old 3rd Dec 2012, 16:19   #6
kirk46
Cheesecake Nom Nom
kirk46's Avatar
9
OMFG
__________________
Old 3rd Dec 2012, 16:48   #7
Scorpuk
Supermodder
Will be about 21TB .
__________________
Folding stats
Folding Summary
Old 3rd Dec 2012, 22:52   #8
MrGumby
CPC 464 User
MrGumby's Avatar
MrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run Crysis
I know they are power hungry but overclockers has some GTX480s for £72!
__________________
Folding stats
MrGumby is offline   Reply With Quote
Old 4th Dec 2012, 07:22   #9
kirk46
Cheesecake Nom Nom
kirk46's Avatar
I know I bought 2
Sent from my BlackBerry 8520 using Tapatalk
__________________
Old 12th Jan 2013, 21:57   #10
mikemaher205
Multimodder
mikemaher205 has yet to learn the way of the Dremel
Does this mean that the difference between Nvidia and AMD will be reduced, or will Nvidia still be dominant in the folding world? Was thinking of replacing my HD 5850 with a GTX 660 for gaming and I chose the Nvidia card over the AMD HD 7870 on folding alone but now not sure as the reduced power draw of the AMD card is very tempting...
__________________
Folding stats
mikemaher205 is offline   Reply With Quote
Old 12th Jan 2013, 22:02   #11
kirk46
Cheesecake Nom Nom
kirk46's Avatar
im not sure about AMD GPU's at present .
they didnt produce as much PPD as Nvidia but what put me off isthat AMD GPU's use 1 full CPU core to fold on which hurts SMP if you fold on your CPU
HTH
__________________
Old 21st Jan 2013, 14:08   #12
mikemaher205
Multimodder
I've recently bought a GTX 660, as it was on offer on Dabs.com and came with AC3.
Does anyone fold on one of these cards yet, and what sort of PPD do you get?
I'm hoping to switch to100% CPU folding and a GPU slot, should see 25,000 PPD at least hopefully... Better than my 12,500 PPD at the moment!
__________________
Folding stats
Old 25th Jan 2013, 21:44   #13
gero1369
Ummm...Wha?
gero1369's Avatar
gero1369 has yet to learn the way of the Dremel
I'm running a GTX 650 Ti and get around 16-18k PPD with a pretty nice OC (+160 MHz clock using Precision X).
__________________
Folding stats
Folding stats
See my hardware
gero1369 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
