Reply
Thread Tools View Mode
Old 2nd Dec 2012, 20:52   #1
alain-s
Supermodder
alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.alain-s is definitely a rep cheat.
Lian Li Pc-7HX Grafit !!! COMPLETED !!! IT IS ON !!!
Time for a small mod named Grafit.
Last week I have picked up a Lian Li PC-7HX in the local hardware store. I didn't had much choice because it had to be this one.
With this case I want to enter in the Lian Li Case Mod Competition. I know that the end of the competition is in less then 2 months. ^^
So lets start!
Fitting the 420 Rad in the front of the case.
Removed the alu that is in the way. To make room for the radiator.
By lowering the radiator in to the hole the top of the case fitted back on it.
Placed some hardware in the case to check out how much space I have left for all the rest.
I picked up some new parts from IT-Service this weekend.
Corsair fans are really well designed.
Working on this piece of plexi when this is ready I will post a new Update.
For some reason some of the pictures that needed to be in Landscape are in portrait mode. :s
__________________
Simplicity Designs
alain-s is offline   Reply With Quote
Old 2nd Dec 2012, 22:36   #2
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
Great! That rad fits perfectly! And nice fans! Are they loud?
Ra6 is offline   Reply With Quote
Old 6th Dec 2012, 22:32   #3
alain-s
Supermodder
Thanks Ra6 well there not louder then my 120mm silverstone fans at 2400 rpm
Update.
Removed the MBtray and replaced it with a plexi version.
Used the Original MB tray for all the dimensions.
Drilled holes taped wire and placed the standoff on it.
Making the opening for the PCI cards
Tray in the case
Using a HDD case from the Cosmos 2
Saw 3 pieces of alu to make new fronts for the HDD
First front is ready the rest will follow later this weekend.
Till next Update. ^^
__________________
Simplicity Designs
Old 8th Dec 2012, 14:04   #4
Ace_finland
Multimodder
Ace_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for president
Keep up the good work!
Ace_finland is offline   Reply With Quote
Old 9th Dec 2012, 14:22   #5
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Yess KUTGW
k.3nny is offline   Reply With Quote
Old 9th Dec 2012, 17:18   #6
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Good luck getting it done in time Alain!
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 9th Dec 2012, 21:53   #7
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Good luck mate !
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 9th Dec 2012, 21:56   #8
j3akalua
Banned
j3akalua has yet to learn the way of the Dremel
Niceee
j3akalua is offline   Reply With Quote
Old 11th Dec 2012, 21:56   #9
alain-s
Supermodder
Originally Posted by k.3nny View Post
Yess KUTGW
Originally Posted by ASPHIAX View Post
Good luck mate !
Originally Posted by j3akalua View Post
Niceee
Thanks Guys will do my best to make the deadline. ^^
Small Update
Dismantle my TJ07 this weekend with pain in my hard. I will be needing all the hardware for this build.
Drainage ^^
After the draining I cleaned the pc and prep it to put it back in to the box till the buyer comes and pic it up.
By By
Back to the Lian Li case.
Cutted the top plated in to pieces. And filled up the holes with some 2K filler.
Reshaping the side panels
Total picture.
That was it again I am waiting for some pieces before I can continue with the body and cable management. Hope u all like it so far.
Cya next time
__________________
Simplicity Designs
Old 11th Dec 2012, 22:45   #10
Ra6
Multimodder
Ra6's Avatar
That's a nice and interesting cut!
Old 11th Dec 2012, 23:27   #11
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Nice cut-will there plexi be placed in cut area?
Pranja is offline   Reply With Quote
Old 13th Dec 2012, 09:36   #12
alain-s
Supermodder
Thank U Ras
Thanks Prania, the case will stay open but the top will change bit.
__________________
Simplicity Designs
Old 13th Dec 2012, 11:14   #13
Bitwacker
C# forever
Bitwacker's Avatar
Bitwacker has yet to learn the way of the Dremel
Lian Li are always good.
__________________
i7-3930K@3.4Ghz | 64GB@1600 | 2x120GB SSD (RAID 0) | 2x1TB Samsung F1 | 30" DELL | 2x23" Dell | Cooling: single water cooling loop
Bitwacker is offline   Reply With Quote
Old 16th Dec 2012, 23:26   #14
alain-s
Supermodder
Thank U Bitwacker
Update!!
Did a small mod on the heat-sinks of the MB. Because the theme color for this build will be red. I was obligated to change the color of it.
Removed the heat-sink from theMB
Filled a small cup with D-stop and placed the pieces that where colored in the cup for 10 minutes.
Cleaned the product with water. As u can see there are still some blue spots on it. These are the places where the glue was so U wont see a thing of it when the are back in place.
This way I don't have to sand the pieces and I keep the brushed effect on the parts.
The HDD case is finished to but I am not convinced by it.
Had to come up with a new idea for the HDD. Started with some plexi to create a new HDD bay.
Short movie of how u place the HDD in place
Case Mod Lian Li PC-7HX Grafit (HDD Cage) - YouTube
Did the wires already for the HDD and found a spot for the AC poweradjust 2
That was it again if the mail service do there job good I will have a very nice suprice before Xmess is here.
Cya next Time.
__________________
Simplicity Designs
Old 17th Dec 2012, 23:23   #15
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
I like how this is shaping up.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 17th Dec 2012, 23:51   #16
Editor22
E22 | Hex-Gear
Editor22's Avatar
Motherboard improvement factor +10
__________________
Old 25th Dec 2012, 22:00   #17
alain-s
Supermodder
Thank U Waynio
THanks Nate ^^
Update!!!!
The update was suppose to be posted before Xmess. But do lak of time with the holidays I only had time to post it today. Time to get a move on.
Received my 1st package from Nate (Editor22) E22 - Welcome to our website! . Thank U Nate for the great service in this short time.
Custom made top res/window.
And a lovely Cherry MX key chain HL.
Some extra pins for the powercables.
Extra colour sample for future mods.
On Xmess evening I received a lovely gift from my GF.
Installed on the MB
Removed the top of the case.
Drilled some holes and taped wire in them to mount the res.
Didn't had much time these days with all the Family dinners and visits to work on the case. Now that it is all past and over I can continue my work.
Cya next week for a Update.
__________________
Simplicity Designs
Old 25th Dec 2012, 22:51   #18
Pranja
Blackwolf
Pranja's Avatar
I like this-you have a nice play with curved and straight lines. Nicely done.
Old 26th Dec 2012, 11:57   #19
sorry2
What's a Dremel?
sorry2's Avatar
sorry2 has yet to learn the way of the Dremel
Alain shifting in win mode
sorry2 is offline   Reply With Quote
Old 26th Dec 2012, 12:05   #20
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Bloody hell that looks awesome!!
I'm definately following this one
elAwesome is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
