Old 4th Dec 2012, 06:07   #1
xD3aDPooLx
Minimodder
xD3aDPooLx has yet to learn the way of the Dremel
Project iLLuSion
....(((((Introduction)))))....
Over the past few months, I've had some time off from modding. Life has been a big influence on not doing anything, LoL. During this time I've had the extreme pleasure of making some nice contacts and talking about builds, designs and other tech type of items. As time has came by, I was putting some feelers out about a build for the CES show coming up in January of 2013. This has been a dream of mine for some time now and its a true honor that I am able to do this.
So with out further adieu the case
....(((((Case)))))....
I formerly present Project "iLLuSion"
Yes the Phantom 820
....(((((Planned mods)))))....
New Side window with a custom made name plate
Using the in house Hue to make a custom lit motherboard plate
a redesign on the top section of the case.
If time allows a redesign of the front case footing
and a few other things.
....(((((Hardware)))))....
Gigabyte 990FXA UD3
AMD CPU????
RAM???
EVGA GTX670's
....(((((Final pics)))))....
xD3aDPooLx is offline   Reply With Quote
Old 4th Dec 2012, 06:07   #2
xD3aDPooLx
Minimodder
....(((((Index)))))....
Update 1 12/11/12 Window cut and logos made
Update 2 12/14/12 Sponsors Added
Update 3 12/18/12 First Package to arrive
Old 4th Dec 2012, 07:40   #3
PcJunkie209
Multimodder
PcJunkie209 has yet to learn the way of the Dremel
Can't wait to see what you do with this. Are u going to CES? If so see you there.
PcJunkie209 is offline   Reply With Quote
Old 5th Dec 2012, 02:51   #4
xD3aDPooLx
Minimodder
I am trying to see If work is going to allow me to leave for a few days. LOL...
Old 5th Dec 2012, 05:30   #5
xD3aDPooLx
Minimodder
I been working on designing a window accent and this is what i've come up with so far...
Any thoughts???
Old 12th Dec 2012, 05:31   #6
xD3aDPooLx
Minimodder
Finally an update.... Srry for the wait everyone, been busy around here...
I been designing a few items that I am going to be using with this mod... first off is this
Some custom made fan grills
more logos with a case badge
Now getting to some modding... The start of the window...
The window is now cut.. putting it back on the case.. looks freaking awesome.
Time to remove some internal components
With the removal and the window back on all filled and straight.
Next Question....
Should I go big or small
big paint strip or
little strip???
help me make the call.
Return to index
Old 12th Dec 2012, 07:51   #7
LPRaver89
What's a Dremel?
LPRaver89's Avatar
LPRaver89 has yet to learn the way of the Dremel
I think the smaller strip works better. Gives you more contrast between the two colors.
LPRaver89 is offline   Reply With Quote
Old 12th Dec 2012, 17:09   #8
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
Ups... I think that you cut too much the window in the side panel... maybe a different cut would match better with that case's design (only an opinion! ^^')
Talking about that stripe, as LPRaver89 said, it would be better the smaller strip as it gives you more equality between the two colours.
Great job!
Ra6 is offline   Reply With Quote
Old 15th Dec 2012, 04:05   #9
xD3aDPooLx
Minimodder
Great job!
The window was cut like that for a reason that will be seen later on... But ty LPRaver and Ra6 for the input... small is going to take it all.
Old 15th Dec 2012, 04:05   #10
xD3aDPooLx
Minimodder
A Small little update.... I got word for that these 2 companies are going to get helping out on this project.
and
Also,
the motherboard, cpu, ram and video cards are on the way...
This project is starting to really take its form.
Return to index
Old 19th Dec 2012, 04:51   #11
xD3aDPooLx
Minimodder
I got my package from Performance PCS today at work....
Here is the content of this package
3mm 480mm x 480mm plexi
5mm 480mm x 480mm plexi
The FAMOUS Mayhems Supernova Aurora..... good I love this stuff for shows.
Mayhems Dark red and Emerald Green dyes... .. I wonder what these are for...
Wire management clips
This next item is what I will be doing for my illuminated motherboard plate...
Just a teaser for now.
The Paint I will be using for the strip down the middle and other areas...
I am expecting a few more packages this week and then a nice weekend of modding.... till next time.
DP out
Return to index
Old 21st Dec 2012, 03:26   #12
xD3aDPooLx
Minimodder
I really hate bad news. NZXTs CEO Pulled all builds on released cases. They will only display a new unreleased case for CES. This means my build will not get going to CES in this format and my sponsors will be pulling out, due to this event.
I under stand that this is out of my hands, but it really sucks. I was looking forward to some hardcore modding this weekend too. This project will go on, but on a longer time frame now.
DP out.
Old 21st Dec 2012, 19:41   #13
xD3aDPooLx
Minimodder
After getting some really sound, Sound Advise... I will continue as if Its going to CES.
THE MODDING WILL CONTINUE!!! RAWR!!!
Old 1st Jan 2013, 17:58   #14
xD3aDPooLx
Minimodder
This is a big update... I got the gpu blocks and more lighting coming in the new few days.
The every nice Gigabyte 990 FXA ud3 mobo
The acrylic for the lit mobo plate
figuring out the right cut
it all cut to what I want
Lit up behind the mobo... Not really want I had hoped for. I am waiting on more leds and i am going to fix that.
Now some parts.
The swiftech block with the intel plate
now with the amd plate on.
Here is some of the paint going on
Front panel with one coat
top panel with one coat
front case foot with one coat
More in a day or two.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
