Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Dec 2012, 08:51   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Corsair H100i review
http://www.bit-tech.net/hardware/coo...h100i-review/1
brumgrunt is offline   Reply With Quote
Old 5th Dec 2012, 09:29   #2
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
What are my chances of this fitting in the top of my R4?
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Old 5th Dec 2012, 10:26   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
By the looks of this (http://www.youtube.com/watch?v=cbXiMJh3ZZA) it would be a very tight fit & would depend a lot on what's at the top of your motherboard (the H100i is about the same size as the H100)
This (http://www.youtube.com/watch?v=mqLxS38SCVA) shows that it might fit in the front...
Awesome results btw!
GeorgeK is offline   Reply With Quote
Old 5th Dec 2012, 10:39   #4
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Thanks guys. Well with my coolermaster haf x it fits easy and above I will have 2x200mm fans which I'm tempted to leave on.
Can't wait for mine to arrive now.
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 5th Dec 2012, 11:59   #5
Digi
The not-so-funny Cockney
Digi's Avatar
Digi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming SaiyanDigi is a Super Spamming Saiyan
I bodged mine (original H100 with an R3, not R4) in because the Sabertooth Z77 has a huge shroud on it which meant it was impossible to get it to line up with the back screw holes. As mentioned above, it depends heavily on your mobo.
I've been running mine for 6 months, ''bolted'' in with 4 cable ties, it works beautifully, still.
PS: This was a pic during the build, so yes, it's untidy. I was going to be replacing the PSU a week after. .
__________________
i5 4690k / Asus Z97I-PLUS Mitx / EVGA GTX 670 2gb SC / 8gb Corsair Veng 1866 / 250gb Samsung Evo / EVGA 550W GS Modular / Corsair Obsidian 250D / 2TB Samsung HDD
A member of a mystical group of master-gamers. Find them hiding at www.tunedgaming.co.uk
Digi is offline   Reply With Quote
Old 5th Dec 2012, 12:11   #6
Pookie
Level 0
Pookie's Avatar
I have a GA-X58A-UD3R, I will crack my case open on the weekend and do some measuring up as I really want one of these. I can alway opt for the H80i which is not far off the H100i
__________________
Old 5th Dec 2012, 12:49   #7
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
I plan to put mine in my current case (CM690II Advanced) - I'm going to put the radiator in the roof cavity and the fans inside the case acting as exhausts - for me I won't fit the radiator and the fans inside the case...
Old 5th Dec 2012, 13:08   #8
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
will fit in my HAF922, but, much as I'd like it, I probably don't need it...
tonyd223 is offline   Reply With Quote
Old 5th Dec 2012, 13:58   #9
brutos
What's a Dremel?
brutos has yet to learn the way of the Dremel
I must upgrade my H8o0 to this for my 3820
brutos is offline   Reply With Quote
Old 5th Dec 2012, 14:12   #10
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
I was amazed at this thing's cooling. Genuinely thought our 1155 rig capped out at a 36C delta T before this week; Nope!
Baz is offline   Reply With Quote
Old 5th Dec 2012, 14:16   #11
dazzler
Minimodder
dazzler's Avatar
dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!dazzler - it's over 9000!!!!!!!!1!1!1!!!
Was tempted by this but it'll involve a bit of work to fit it in the Zalman Z11 case I just got, not decided yet whether to go with the Silver Arrow Extreme or try a bit of modding!
dazzler is offline   Reply With Quote
Old 5th Dec 2012, 14:22   #12
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Might be time for Bit tech to invest in a bigger case for CPU Coolers like this one as i wonder how it would perform inside a case compared to outside were its getting fresh air constantly.
rollo is offline   Reply With Quote
Old 5th Dec 2012, 14:24   #13
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
How did you kill the AMD rig, Harry? Anything spectacular?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|32GB|256GB M.2|500GB SSD|8TB NAS|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 5th Dec 2012, 20:00   #14
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
I imagine he plugged in 'the' hard drive...
Old 5th Dec 2012, 22:35   #15
DoctorBeat
Minimodder
DoctorBeat has yet to learn the way of the Dremel
I've cut holes on the roof of my Fractal XL to accommodate the H100 6 months ago...
with a i7 3870 overclocked to 4.6Ghz it works flawlessly. In the meantime I've swapped the fans for a noctua NF-F12 and the thing is whisper quiet
I can only thing of good things to say about my H100, hopefully this one is better
DoctorBeat is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
