Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Dec 2012, 08:17   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Enermax ETS-T40-TA review
http://www.bit-tech.net/hardware/coo...40-ta-review/1
brumgrunt is offline   Reply With Quote
Old 6th Dec 2012, 12:57   #2
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
good to see lots of hardware reviews, but I'd prefer a 12 page cooler review roundup at end of week.
Do i buy a cooler now, or do i wait till next week incase an ULTIMATE EXTREME cooler is still to come...
greigaitken is offline   Reply With Quote
Old 6th Dec 2012, 13:11   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
^ That'd be the H100i...
GeorgeK is offline   Reply With Quote
Old 6th Dec 2012, 14:25   #4
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
'one thing struck us as a little out of the ordinary, namely the baseplate. It uses what Enermax terms Heat Pipe Direct Touch, which is exactly as it sounds. Rather than a traditional smooth baseplate, the four heat pipes themselves are flattened out and make direct contact with the CPU. '
Erm... Don't loads of coolers use this design...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 6th Dec 2012, 17:33   #5
SuicideNeil
Banned
SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.
Yeah, that is a little odd to draw attention to that 'feature' as though it was something special or new, which is actually rather common among many heat sink bases...
SuicideNeil is offline   Reply With Quote
Old 9th Dec 2012, 05:04   #6
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Yeah, the direct-touch design is very common...and very commonly not very well implemented, as Enermax has done. The idea of the design is good, but you can't half-ass it - there shouldn't be massive gaps between the pipes and the base.
Also, no AMD testing at all? I am disappoint.
fluxtatic is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
