#1 |
Nuttier Bubbles
Update_Core?
My GPU's have stoped running with this status "Update_Core". I have had a look at the log and it is pointing at a file that is not there at the moment http://www.stanford.edu/~pande/Win32...00/Core_15.fah any one know how to fix this problem?
#2 |
Ultramodder
Try deleting the core files. FAHCORE_15
Will be in the work folders, depending which client you are on depends where they are. |
#3 |
Nuttier Bubbles
Hi TaRkA DaHl, I have searched everywhere on the computer and cant find any files called FAHCORE_15. It looks to me like FAH is trying to download the missing file. Trouble is if you go to the URL the file is missing
#4 |
Nuttier Bubbles
Ops sorry did not say I am running Windows 7 if that makes any difference.
#5 |
Ultramodder
C:\Users\*LOGINNAME*\AppData\Roaming\FAHClient\cor es\www .stanford.edu\~pande\Win32\AMD64\NVIDIA\Fermi
You then will have either a beta folder, or core_15.fah folder. The file will be in there. Sorry for the slow reply, didn't see your post. |
#6 |
Need help with scratchbuild!
Not sure if this is still an issue but i was getting the same fahcore_15 update stuck at 0% until yesterday when i re-added the gpu again (radeon hd 7950) and it now works and is working on the 0x16 core.
__________________
i5 3550 // gigabyte g1 sniper m3 // xfx 7950 dd @ 1ghz // 2x4gb C. Vengeance // samsung 256gb 830 // 750gb scorpio black // silverstone tj08be // enermax ets t40 tb // ocz modXstream pro 700w // Dell u2412m // IBM 17" tft. Xbox PC mod (nearly finished): a10 5800k @ 4.6ghz, h100i, msi fm2 a75ia, 8gb samsung greens, 256gb sandisk ultra!
#7 |
Nuttier Bubbles
I finally got it sorted, I reinstalled over the top but did not keep settings, thanks for the help TaRkA DaHl.
__________________
| Thread Tools | |
