#1 |
Made in Canada
Playstation 4
So it seems that Sony is currently referring to its PS3 successor as 'Orbis' - they have not adopted the Playstation moniker yet (though maybe they won't).
The second revision dev units have apparently been shipped out and reflect the final hardware fairly closely (apparently). They are based around the AMD A10 APU - likely the 5800k - so it is reasonably fair to assume that the next PS will be a quad-core CPU clocked at around ~3.8Ghz though I wouldn't be surprised if they scaled them back a bit for additional power savings. What is more interesting is that the A10 has a 7660D Radeon built into the APU which is fairly snazzy - and should have fairly good performance. The new standard for Sony is apparently 1920x1080/60p [or 120i 3D] and the 7660D should probably be able to handle that. I believe Anandtech tested the A10's GPU with Crysis just under 1080p and managed to get about 70fps. Considering Crysis is not optimized for the platform- it seems to be a fairy reasonable bit of hardware. There are two flavors apparently kicking around- one with 8GB of DDR3 RAM and another with 16GB DDR3 RAM. Not sure if they plan to have 2 variants, or if it's just for internal testing to see whether they can get by with 8GB to save money. Those familiar with the PS3, Wii + Wii U, Xbox 360 will know that they use IBM PowerPC CPU's. They tend to be quite hot, 40nm - and are expensive. The move to an x86 based platform by Sony would actually be an extremely smart move. - Sony seems to have learned that expensive bespoke hardware is not the way to make money off a console. - The A10-5800k SOC is cheap retail- so in large batches AMD will benefit from sales and Sony will benefit from low costs. - The concept of 'porting' might disappear as developers will only be optimizing for resolution, rather than PowerPC. This is actually good for PC gamers. - Using fairly stock hardware we should see a cheaper retail price. - Blu-Ray is still onboard; so optical media will stick around for awhile. - WiFi + Wired is still onboard. Not sure about bluetooth, but given backwards compatibility it'll like still be around. - Based off x86 hardware, packing an A10 SOC, and plenty of RAM we could see this developing into a very neat HTPC as you might be able to thrown Linux on there with XBMC or even Windows 7/8. Storage seems to still be HDD - 500GB. But that's generally the least important design decision- it could change at any time. Honestly seeing a 128GB or 256GB SSD variant would be better. The final production revision is expected May-June 2013. No pictures- Sony sends them out in regular desktop PC cases.
__________________
[[Asus Rampage III Formula RoG | Intel Core i7 980X @ 4.2 Ghz | Corsair H70 | 12GB DDR3-1600 G.Skill | 2 x MSI 560Ti 1GB Twin Frozer II SLi | Corsair AX750 PSU | 2 x Crucial C300 128GB SSD + 3 x Samsung F1 1TB | Silverstone Fortress FT02B]] |
#2 |
Do you even mod, bro?
Where are you getting the above info?
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG Last edited by Krikkit; 9th Dec 2012 at 19:57. Reason: Removed huge text quote. |
#3 |
Made in Canada
__________________
#4 |
Ultramodder
Urrr... ?
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | 7950w/boost WC | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | Cheap LG IPS
#5 |
Mod Master
There's no denying the 5800k/7660D is a cheap, smart and efficient option for Sony. Also no doubt it's much more powerful than the GPU in the PS3, which I believe is some kind of cut-down nvidia 7800.
That said, it's not nearly as powerful as having a dedicated GPU in there. Last I saw, rumors were flying that the PS4 was packing a Sea Islands dedicated GPU, which would make it a formidable machine. I just don't want to see them put in weak-ish hardware and have a situation 7 years from now where they stretch out the generation far longer than the hardware can cope with. Though I will admit that devs have done some amazing stuff with the hardware they're stuck with. Uncharted 3, God of War 3, Halo 4, etc.
__________________
Asus Sabertooth Z77 | Intel Core i5-3570k | Cooler Master Hyper 212+ | 16GB Corsair Vengeance 1600 | Evga GTX 670 FTW | Crucial M4 128GB SSD |
#6 |
How many wifi's does it have?
Assuming it's all true, boys, say bye bye to Sony then.
The company is bleeding money like no tomorrow. Worst than Nokia and AMD. They can't afford another 500$ console. The problem with the PS3, is that while it is selling, people are buying it for the Blu-ray part not the games. So Sony is loosing a lot of money. Teh PS Vita isn't doing well as well. It's way to pricey, and they still lose money. And people dont' buy a lot of games, due to lack of quality content for it. If SOny was smart this is what they should have done: 1- Replicate the WiiU specs. 2- Every penny saved by not having the gamepad, could be transferred onto getting a better CPU, and hint faster GPU (the GPU will automatically be much faster, as the console will have to render on only 1 screen, and not 2). Now, they'll have a 350$ console, that beats the WiiU in all aspects in terms of performance and graphics. You are done. Plus, you can push the PS Vista as a gamepad alternative fully, to compete with XBox SmartGlass, and WiiU Microsoft is going all Kinect and Media Center on the next XBox. So expect most of the money to be on set on PVR like features, and Kinect system. The console will be better of course than the WiiU in term of performance as, like the PS4, even the one I suggest they do, as they can get better hardware 1-2 years from now, and also they can afford to lose money as Microsoft makes massive amount of money with their subscription online multi-player service
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#7 | ||
Made in Canada
There is the cost aspect. Sony learned the hard way. Seeing a dedicated GPU is unlikely. Heat generated by a system with multiple components, rather than SOC also means you draw more power, and need to dissipate it somewhere. My 60GB PS3 - as much as I love it - it a giant, heavy, hot brick. Down sizing is smart in general. Given what a console is generally expected to do, I am quite happy with the A10 being used. Most importantly it's x86. Avoiding a dedicated GPU also means Sony can upgrade the "PS4" by merely swapping the A10 SOC out (since it just sits in a single socket) for something newer when AMD releases it. Such as a die shrink, or even an improved GPU (as they are packaged together). The PS3 has not had its GPU upgraded- however it has undergone three die shrinks on the CPU. Seeing 8GB on the base unit is a good sign. No more 256MB XDR memory as with the PS3- which when released was already well behind the curve. All things taken into consideration- its hardware is on par with current decent everyday gaming PC for non-extreme users. Quote:
It's using a triple-core PowerPC-750 clocked at 550Mhz, based off the GameCube; which coincidentally also used the PowerPC-750. It has a Radeon 4000/5000 based GPU clocked at 649Mhz. Backwards, is not the means to go forwards. If you expect Sony to save money, going x86 and running away from PowerPC is the *best* thing to do. It means porting games no longer takes years because it is the same platform as the PC. There is a lot of time and money saved in that. Using an off-the-shelf APU that isn't an expensive, slow, PowerPC is also very smart. It means Sony isnt' wasting money on R&D and having to adapt their SDK's to a different architecture. Cost savings. The entire premise of my initial post *is* about cost savings. The Wii-U's lethargic processor will never push the 1080/60p + 3D content Sony is aiming for from the start. It also has a longer development cycle due to porting.
__________________
[[Asus Rampage III Formula RoG | Intel Core i7 980X @ 4.2 Ghz | Corsair H70 | 12GB DDR3-1600 G.Skill | 2 x MSI 560Ti 1GB Twin Frozer II SLi | Corsair AX750 PSU | 2 x Crucial C300 128GB SSD + 3 x Samsung F1 1TB | Silverstone Fortress FT02B]] Last edited by Jasio; 9th Dec 2012 at 18:41. |
#8 | |
I *am* the guy with two left hands
Performance is much, much worse : http://www.bit-tech.net/hardware/cpu...d-a10-review/7 With 7660D, at 1920x1080, we talk about 9.4FPS in case of Crysis 2 at 1920x1080 : http://www.tomshardware.com/reviews/...ce,3304-7.html
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04 |
#9 |
I'm sorry, that image doesn't in any way answer my question, so everything you've said so far might as well be made up.
I heard its using a 3930K, triple 690's and 32GB of RAM. Sure, less likely, but my source is as valid as yours.
__________________
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#10 |
I Mod, Therefore I Own
Wiiu specs are pretty awful.
Lack or dedicated Gpu will be a problem you can't just upgrade the CPU in a ps4 when AMD release something faster as you will have issues of games not running on launch hardware and people been pissed off. The best thing about a console for most is the ease of use if it says ps3 and you have a ps3 you can be sure it will work. If you have 2 dif versions of ps4 issues will arise. |
#11 | |
Made in Canada
__________________
#12 | |||
No it doesn't. Doesn't mean that the lunch title was not amazing as due of being rushed out, and that the developers don't know how to use GPGPU abilities of the system (new to gaming console), and don't know anything about optimizing content to it as its brand new, that the console has terrible hardware. Early XBox 360 games looks like XBox 1 games. It was terrible.
The GPU is a powerful Radeon 5000 series DirectX 10 ready (but won't be used, as it needs to run a Windows OS, but has the equivalent from OpenGL). The GPU support GPGPU (AMD version of Nvidia CUDA), so developers can offload part or all of the physics and AI onto the GPU, if CPU performance is needed. Seeing how no games so far, and select few on the PC even uses this feature, it is normal that developers currently have a hard time using it, let alone know how to optimize it. Quote:
x86 processor are really not efficient processors, and very costly. Quote:
__________________
#13 | |
Made in Canada
Wrong as usual faug
__________________
#14 | ||
Made in Canada
The processor is not on the same die as the GPU. It is on the same package, not the same die. ![]() Quote:
x86 efficiency is irrelevant, it always comes down to cost. IBM has less volume, on an older process. x86 is cheaper and mass produced in consumer hardware, I am not quite sure how you managed to get a higher cost out of a high volume, high yield, budget product like the A10 which sells for $115.
__________________
#15 |
But can it run crysis....................just kiddin. How much will they be asking for games for the next gen consoles???
#16 |
Uniform November India
Yeah, I can see just how necessary it was to quote the entire OP (wall of text that it is) in the first reply to the thread. Totally sensible.
__________________
#17 |
Ultramodder
There is no way in hell they'd use the onboard 7660. They did sign some sort of agreement with amd iirc. This will surely only be for GPU...
I really think, if they've learnt anything, it will be to have a more flexible memory architecture for simpler cross platform titles.
__________________
#18 | |||
If you ever have hope up for a powerful console with Nintendo, you'll always be disappointed. From the NES (family computer) to the WiiU. Yet, Nintendo, usually have a huge success, which tends to, for some reason which I don't get, pissed off, and start bashing things. I don't get it. Just buy 2 consoles, or don't. Why get angry and bash things.? Anyway, this is off topic. Microsoft tried the x86 approach. It was called the XBox. It was using a Pentium 3 733MHz, and a Nvidia GPU. Why did Microsoft changed? And to consider that the original XBox was based on Windows NT OS, they had to heavily modify it for the XBox 360. You would think it would be more costly, but clearly its not.
__________________
#19 | |
Made in Canada
A) You argue there will be a dedicated GPU. From a technical epeen angle, this makes sense. The PS3 did set the bar quite high when it was released in terms of its sheer processing power (though it was gimped by memory). There was a fairly decent GPU in there too- so why wouldn't Sony follow on with this design decision again? Well they can, there is nothing stopping them and it could make it easier for the consoles long-term viability as dedicated GPU are more powerful then integrated ones. B) You argue that an integrated GPU is the way to go. Taking a page out of the Wii U, it is quite possible that this is a sign of things to come. The PS3 was a power hog, chucked out a lot of heat, and in its first iteration before a die shrink was heavy and took up a lot of space. The two key draws on power being the CPU and the GPU. Modern integrated GPU's such as those found on the AMD A10's are not all that bad. They do a decent job for HTPC and light/medium gaming use for someone who doesn't push multiple displays or insane resolutions. There is also the cost factor: The packaged SOC is cheaper, draws less power, puts out less heat, and takes up less space. Those are all very good things from both a manufacturers cost perspective and the consumers perspective. You can say that we live in times of "austerity" and Sony probably cannot handle another huge loss like the PS3. Looking to an 'all in one' package is probably going to be the route all the big guys go for despite what we might really dream of / want. Both sides work- I really do want a stand-alone GPU but I do not see that happening. The dev units point to that. We are also ~6-8 months away from the final spec, and the PS4 might end up getting packaged with A10's replacement Richland, Trinity's successor.
__________________
#20 |
Ultramodder
But older stuff was just less efficient. You can see the slim as an example of power consumption falling. Also, it wasn't exactly the biggest complaint that needed addressing.
The biggest complaints would have been with ps3:
I'd expect to see hd7950 performance or hd6950 with as low power consumption as feasible. I wouldn't even be too surprised to see a return of the cell. Iirc K Kuturagi or whatever he was called envisioned continuing down the cell road. I'd imagine the leg work to be mainly done by now. Maybe we'll see the 4.2ghz we were promised. Edit: The 360 in general had a more flexible gfx card also. Less fixed function... Nvidia joined the party when they launched the 8800. Someone with more expertise should explain that... It's all old misfirings in my brain regarding these consoles
__________________
| Thread Tools | |
