#101 |
I *am* a Dremel
Interesting we were discussing the RFID disc thing years ago for used games sales can't believe that is just patented now.
Good idea in principle, allows easy licence registration, no arsing about with codes etc will making playback of rips harder so reduces casual copying etc. and pretty invisible to the average consumer. I'm sure everyone is looking for a solution to this that doesn't soley rely on internet/cloud etc.
__________________
Into Gaming and around Bristol, UK, Click Here Last edited by sandys; 3rd Jan 2013 at 22:27. |
#102 | |
What the?
Eurogamer have a PS4 hardware breakdown from "trusted sources".
#103 |
Do you even mod, bro?
Makes sense from what Kr4t0s from Reddit seemed to be saying. PS4 is going to whup the 360 graphics
wise. The above suggests GPU performance between a 7850 and a 7870
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG Last edited by Parge; 22nd Jan 2013 at 13:11. |
#104 |
pew pew pew
I'll definitely be buying one and skipping the new Xbox. Sony have really upped their game in terms of quality exclusives recently, and PS+ is a bargain. Throw in the fact that the new Xbox looks like it's almost a direct copy of the PS4, except with a weaker GPU (but more, slower, RAM) then it's pretty obvious which will be ahead.
It also sounds like a powerhouse, especially when you remember that developers are coding direct to the metal, so to speak, without the massive overhead of Windows etc. I'm expecting the next generation to be a real step up graphically.
__________________
i7 3770 | Asus RoG Maximus V Gene Z77 | 8GB 1600Mhz Vengeance | Crucial M4 256 & 128GB | Corsair H80 + Gentle Typhoons | Corsair AX750 | EVGA GTX 680 SC 2GB | Xonar DX | Silverstone FT03 |
#105 |
Super Moderator
Moderator
What about the next-gen Xbox though? A quick google suggests more power, but less RAM.
Sounds alright to me, should hold up to hammering a 1080p telly quite nicely... Anyone got a date for GT6? I'm putting my money on Nov 2018. |
#106 |
dat steak
It had better be a massive step-up.. Console graphics have been holding back PC graphics for years as developers don't want to have to code for two systems...
#107 | |
Now, if only I could actually get to grips with the controller.
__________________
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#108 |
I Mod, Therefore I Own
Just depends on release dates for both i guess.
Sony has picked up the better exclusives in the last few years thats for sure. Halo Series for me has ran its course and the other big game that was exlusive fable series is now on pc anyway. Removes 2 need for purchase from my list. Microsoft is going to have to come out with some pretty special exclusives to get me to buy the new xbox this time around. Sony should get the next uncharted as release title would make the console pretty much a must buy on release if its as good as the prev 3 have been. |
#109 | |||
pew pew pew
http://www.eurogamer.net/articles/df...box-specs-leak http://www.eurogamer.net/articles/df...xt-gen-console Basically, both the PS4 and Xbox 720 appear to be based on an AMD octocore running at 1.6Ghz, with the differences lying in the RAM and GPU. PS4: 4GB GDDR5, with 512MB reserved for the OS, 18 GPU ROPs = 1.84 teraflops theoretical Xbox: 8GB DDR3, with 3GB reserved for the OS, 12 GPU ROPs = 1.23 teraflops theoretical There are also rumours that two of the Xbox cores will be reserved for OS operations as well, Sony are looking at one or none. MS are using 32MB of 'ESRAM' to try and bypass their slow DDR3, but it won't match up to the GDDR5 in the PS4. GPU ROPs run at the same speed apparently. So basically, the PS4 is going to be more powerful, both in CPU, RAM speed and GPU than the Xbox. The only thing letting it down, if you can say that, is the quantity of RAM, with 3.5GB available compared to 5GB on the Xbox. That said, I can't see 3.5GB being much of a bottleneck - the current consoles get by with a fraction of that. Quote:
Microsoft may manage to get out one or two good exclusives, but they'll need to pull a magic bunny out of the bag to match what Sony have with their obviously tight relationships with key developers. MS's treatment of first party (such as Rare and Bungie) has been terrible.
__________________
#110 | |
#yolo #swag
The controller is also my favorite of any console. Simple, comfortable, and effective. Xbox controllers have never rubbed me the right way and Nintendo are off in their own little world of insanity.
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | Creative Soundblaster Arena | Cyborg R.A.T. 7 | WASD Keyboard v1 w/ MX Browns | Leopold FC200RR/AB |
#111 |
I *am* a Dremel
I'll likely buy both, prefer PS as usual but really wouldn't object to Sony taking some of the good bits from the 360 controller. These machines will probably still cost less than a highend GPU and can happily sit in my games cabinet provided their subscriptions models don't go silly.
__________________
Into Gaming and around Bristol, UK, Click Here |
#112 |
pew pew pew
What would you take from the 360 controller and give to the PS? Only thing I'd take is a removable battery (yet without adding bulk) - everything else I find the DualShock3 to be better at - although that could just be from owning a PlayStation since the 90s.
__________________
#113 |
I *am* a Dremel
The triggers and sticks with the same level if feel, preferably tighter still, also PS owner from the first, never really liked the 360 pad for ages but with more use of it on my PC I've come to appreciate some of it. Can't stand 360 battery to be honest that has to be the worst thing to take, having rechargeable along with standard charging cable I could plug into anything when batt is needed has been great, just like phones you can charge 'em off anything, how it should remain.
__________________
#114 |
Considered for President!! Moi??
It's interesting how these leaks both point to Blu-Ray being added into the new xbox.
Sam
__________________
The Laptop: Dell Vostro 3450, SB i3 2350m, 8GB DDR3, 256GB 830 SSD, Intel 6235 Wifi N/BT 4.0, Dell 5550 3G/GPS The Server: Phenom 2 x6, 8GB DDR3, 3TB Seagate, 2TB WD Green, 2*1TB Samsung F1 |
#115 |
its a natural result to add blue ray
Higher textures require more disk space. DVD is at its limits already. Blue-ray is the only medium available to Microsoft to use. Wether it will play Blue-ray films or not no one will know for a while as that will depend on Microsoft getting Licence deals in place. Usaully takes 3-4 years before you see what a console is really capable off graphics wise. Not expecting a massive increase in the quality of pc ports. Just because it works on a pc based console is no guarentee that it would work on a pc desktop. We dont even have a GTA5 release date yet for PC think PC gamers will just have to accept that they are now the 2nd rate players in the games market. Consoles went passed us in priority sadly. 360 pad in windows is easy to use. PS3 pad in windows is a pain to setup, Due to no official driver support. |
#116 |
pew pew pew
Putting DVD in the 360 was a bad move in the first place - it was okay for the start, but it later turned out to be a real mistake.
MS are trying to also push the Xbox as a media centre, so BD support makes sense (including film playback).
__________________
#117 |
Three years ago I would have agreed with you, today, that isn't the case.
__________________
#118 |
How many wifi's does it have?
The WiiU is using Blu-ray disc. It can't play play Blu-ray movies as Nintendo didn't want to pay the codec fees.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#119 |
pew pew pew
So? The Wii couldn't play DVDs either. Microsoft however are pushing the Xbox as a media centre, and demonstrated their willingness to pay licenses when they provided the 360 with DVD playback. If the new Xbox has BD it will play films, I'd put money on it.
__________________
#120 |
Oh I agree with you, but it was worth mentioning that not because it have Blu-ray drive that necessarily it will play Blu-ray movies.
Anyway, PS4 dev kit info: http://kotaku.com/5977849/the-playst...e-specs-so-far -> 8GB of RAM -> 2.2GB VRAM -> 4x Dual Core AMD Bulldozer CPUs -> AMD R10xx -> 160GB HDD -> 2x Ethernet ports -> Same old controller that never really changed. It will also feature a different account system where it looks like the account of the user is stored on the controller and not on the console, so that you can have multiple users on the same console. There isn't much details, beside: "multi-user simultaneous logins." I just hope that means that your account isn't finished if your controller breaks. It must be noted that the early dev kits are usually more powerful than the consumer consoles so that it can run diagnostic utilities with the game. So expect 4GB of RAM and not 8, and possible 2GB VRAM instead of 2.2GB. CPU cores might also drop. On the PC side, for game developers, Nvidia has special GPU analysis system, where you need a second graphic card which will monitor, and process information on what is occurring on the first GPU, and other stuff, to allow the developer to optimize their games. It's also consumes more system RAM when executing. Does that mean that the game required 2x GPU to run, and a lot of RAM? nope.
__________________
| Thread Tools | |
