#1 |
Banned
TJ07 Black and White, Blue
Staff will present my project
![]() I put stuff here and I'll use some pictures Hope you enjoy -Sponsors- I'm trying to get Hardware: Box: Silver Stone TJ07 Motherboard: Processor: Memoirs: Graphic Card: HD7750 1GB DDR5 Disco: 1x 320GB sata Power Supply: watercooling: Connectors: 10x Single Alphacool 4x Curve 45 º Alphacool 3x Curve 90 º Alphacool Curve 30 º 2x Alphacool 5x Pass Alphacool Panels 10x Connectors Stop Alphacool Radiator: CPU block: Reservoir: 2x Phobya Balancer 250 - Black Nickel Pump: Fan.s: Accessories: EK Dual Loop Led.s White Extensions Before ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now 11x Connectors Simple 3x connectors 90% 4x connectors 45% Connectors 30% 2x 5x Pass Panels 10x Stop.s 2x Led.s for reservoir By now I hope tomorrow is all receive another reservoir and dual loop, the 2 tops for led.s for reservoir I hope you enjoy and comment
#2 |
Do you even mod, bro?
FYI - none of your photos show up.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#3 |
Hypermodder
looks fine to me
#4 |
sabertooth 990FX
just murdered my bandwith resize thew pics
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing |
#5 |
__________________
#6 |
Fenrir The Wolf
Jesus,even with 10 Mb/s I cant't see pics.
#7 |
breaker of things
^ bandwidth killed 3264 x 2448 is a tad overkill to say the least, i think due to the high bandwith demands from the images some people are going to struggle to actually load all the images
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW |
| Thread Tools | |
| View Mode | |
