Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 10th Dec 2012, 09:44   #1
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Do I need a new car battery?
Having googled around I can't seem to come up with a definitive answer so I thought I would ask the source of all knowledge (aka the BT forums )
I drive a 2004 1.8 Diesel Focus which I bought 3, maybe 4 years ago - it's done about 60,000 miles iirc. To my knowledge it's never had a new battery - I've certainly never had it replaced. Recently, particularly with the cold weather, it's been really sluggish to start - on one or two occasions I've doubted whether it will start or not. My question is simple - do you think I need a new battery? Is there any way I can test it? I don't own a multimeter however...
Cheers
George
GeorgeK is offline   Reply With Quote
Old 10th Dec 2012, 09:49   #2
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
That sounds like a new battery to me. If the starter motor turns over, but sluggishly, it is because it cannot draw enough current from the battery. I would suggest that you buy a new battery.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 10th Dec 2012, 10:08   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Yeah - it does turn over but is really sluggish... Even this morning when it wasn't that cold (3 degrees ish) it was fairly slow to get started... The only thing that's bugging me is the thought that it may be glow plugs instead...
Old 10th Dec 2012, 10:11   #4
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Take yourself down to the local motor factors and see if they have a battery tester - they should tell you in a couple of minutes if it's knackered.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 10th Dec 2012, 10:15   #5
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Good idea - hadn't thought of that... Come to think of it I did notice that Halfords offer a free battery check when we were walking past the other day but didn't put 2 + 2 together!
Old 10th Dec 2012, 10:18   #6
steveo_mcg
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
Last time I got a "free battery check" Kwik-Fit just turned everything (but the engine) on and measured the voltage. A healthy battery would have sagged with that kind of load. Having knackered my battery the *******s wouldn't even jump me out their yard, thankfully it started and I got a battery from a mate for 12 instead of 60 kwik-fit wanted!
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 10th Dec 2012, 10:25   #7
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
lol - maybe not the best of ideas then!
Old 10th Dec 2012, 11:35   #8
Atomic
Gerwaff
Atomic's Avatar
Atomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming Saiyan
New battery is likely the way to go, had the same thing on my Civic - was on the original battery too and after 60k it had got to the point it wasn't giving enough current.
Diesels are harsher than a petrol on batteries as they glow-plugs require a lot more current to heat up than the spark plugs on a petrol do. Especially during the winter as the engine block and battery are much colder so needs more power to start.
Still got the original battery as it's great for camping - can run a full set of 12v lights all night for two weeks in the tent and charge my phone off it.
__________________
:: All your PowerShell are belong to me ::
Atomic is offline   Reply With Quote
Old 10th Dec 2012, 12:17   #9
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Might just bite the bullet and get a new one - I'll probably just be lazy and get halfords to fit it (for the sake of a few quid I'd rather they were fumbling round in the cold and dark than me).
Anyone got any advice on which of these to go for?
Thanks for all the suggestions guys!
GK
Old 10th Dec 2012, 12:26   #10
julianmartin
resident cyborg.
julianmartin's Avatar
julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.
Not worth the risk in cold weather. Remember that batteries are a chemical reaction and the cold inhibits it, hence why your battery seems worse than normal. Defo time for a new one. 60k and 8 years on a diesel battery is decent going , I think I got to 8 years but about 120k on my 2002 Pug 206 diesel.
__________________
work
Xeon X5660||Asus P6X58D-E||12GB XMS3||240GB SSD||GTX770||Define R3||X58 forever
julianmartin is offline   Reply With Quote
Old 10th Dec 2012, 12:28   #11
enterobsidian
Hopless World Wonderer
enterobsidian's Avatar
enterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysisenterobsidian can run Crysis
Do you regularly do lots of short trips? If you only go to the shops and back, then it may be that you are using more charge than you are putting in, especially with a diesel. If this is the case, either run the car for a long drive or use a battery charger on the car. If you have access to a power socket I would recommend an Optimate charger to do this, as you can unclip the battery very easily.
If you regularly drive several miles and still have this issue then it's likely the battery is dying.
If I had to choose a new battery, I'd go for the sliver top, as it is a very good battery. The one I had in my Discovery never failed to start the car unless it was really flat, and it has a five year warrantee as well.
Have a quick look on the net for instructions on how to change your battery. It might be easier than you think depending on where it is. With my MG I can change a battery in 5 minutes with a 10mm socket and a 10mm spanner. That said, if there are lots of electronics on top of the battery, like VAG do, then let them have the hassle of changing it. Same goes if its in an awkward place.
Hope this helps
Enterobsidian
__________________
"Is a dream a lie if it don't come true? Or is it something worse?"
Bruce Springsteen
Searching Distant Seas
enterobsidian is offline   Reply With Quote
Old 10th Dec 2012, 12:37   #12
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
dynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyan
Personally I'd go for the Bosch rather than the Halfords own brand.
Do you not have a local independant garage or motor parts store you can call into? Most will test for free and when I went (pretty much same symptoms as you on a 1.8 petrol) they tested it, showed me what batteries would be suitable and it came out with a better battery around 20 cheaper and fitted. Might be worth a drive around unless you feeling extra lazy.
Also make sure you do get a diesel battery, I'm pretty sure you need to be looking for something in the 650-700+ starting ampage range for a diesel
__________________
-: MM UF0 Duality :- 2700K, 16GB Ballistix Tracer 1600, P67A-GD65, RAID0 2x250GB 840 Evo, GTX970, AX1200 :-
-: Dual Loop Watercooling :- 2x Laing D5, 2x PA120.3, EK 580GTX Fullcover, EK Supreme HF, EK TubeRes :-
dynamis_dk is offline   Reply With Quote
Old 10th Dec 2012, 12:53   #13
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
You sure its the battery?
Its cold weather and the glow plugs will have to work a little harder for turn over.
Flick the ignition over to position 2, waiting 30-45s then crank or if the dash has a glow plug lamp wait just a little longer after the lamp goes out.
If its still having issues then yes maybe a new battery.
Also to note, is the car difficult to start after its been driven and warmed up?
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 10th Dec 2012, 12:55   #14
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
I have a standard Halfords one and it's fine, no complaints at all.
__________________
Old 10th Dec 2012, 13:04   #15
dire_wolf
Last Of The Dovakhiin
dire_wolf's Avatar
dire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for presidentdire_wolf should be considered for president
This! you'll probably be looking at a 20 premium over the cheapo own brand ones but the Bosch Silver batteries are bullet proof, really great Amp rating VS standard batteries too. If you have a local Andrew Page you'll often find they're as cheap as the web for these (The one I bought from them was 40 cheaper than what Halfords were asking)
__________________
"Don't Fear Citizens! TAD KNOWS HIS RAID!" - Bindi
MAIN BOX E7400|HD5770|Viewsonic VX2260WM|Asus Xonar D2X|4GB Dominator|Samsung F3 1TB|Gigabyte GA-EP43-S3L
WIN98/DOS GAMES BOX 1GHz P3 Coppermine|GF3 Ti500|Creative Live! 24-bit|256MB Rimm|WD 10GB HDD
dire_wolf is offline   Reply With Quote
Old 10th Dec 2012, 14:14   #16
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
My 'normal' is a 25 minutes ~18 miles trip to work in the morning then home in the evening. Maybe some shorter trips in the evening / at the weekend but not really that many.
I might be tempted to fit it myself if it wasn't (a) dark every day when I get home from work and (b) freezing cold! I might do it at the weekend perhaps - getting them to do it is only 7 though...
I was leaning towards the Bosch as well - for the sake of 20 it certainly seems a better deal... I do take my car to a local garage for service, MOT etc so I could give them a call - the convenience of Halfords was the main factor in considering them, but might be worth it - cheers for the suggestion.
The Halfords site brought up those batteries when I typed in my reg (and it did correctly identify my car) but the Bosch is only coming back as a 600A battery...
The dash does have a little light - I always leave it a few seconds after the light goes out (which is almost straight away).
The car doesn't have any issues in starting after a drive - i.e. the other day I drove home but stopped off at Tesco on the way - Tesco is a couple of miles from my house so it must have been 15 miles from work to Tesco. It was sluggish starting at work (after sitting for 8 hours in the cold) but not at Tesco (I was only in there for 10 minutes). What would this point to?
I'd noticed the difference in the Amps too - it's 10-20% more than the other two.
Unfortutely the nearest Andrew Page is miles away...
Old 10th Dec 2012, 14:39   #17
Picarro
Picarro's Avatar
Well it could be some things, but it sounds like your car battery is charged okay by the generator, but then discharges very quickly when left in the cold. Other than that it could be the glow plugs.
Do you have a set of jumper cables and a mates diesel car? If your car starts without a problem running of your mates battery it is your battery at fault, but if it starts slowly then it might be the glow plugs.
__________________
Old 10th Dec 2012, 15:13   #18
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
Might be worth a shot...
Old 10th Dec 2012, 15:21   #19
CrapBag
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
I had an issue with my battery last year, car was refusing to start the nxt day after being sat over night. Would jump and bump start.
It finally refused to start at tesco's car park and the AA came out and ran a full diagnotsic on my electrical system and found nothing wrong. Installed a new battery the next day and been fine ever since. So much for diagnostics
CrapBag is offline   Reply With Quote
Old 10th Dec 2012, 16:23   #20
TheBlackSwordsMan
The world need more lemon cakes
TheBlackSwordsMan's Avatar
TheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming Saiyan
A car battery last about 5 years, sometime less. You know its done for, when it mysteriously lose its charge for no reason. I had to change mine, last week, I was overextending its life for 2 months : / You know something is wrong, when you drive and the voltage is under 12v.
Ps: Diagnostics are ****, they gave me a dead battery at the autopart store ! They said they were very sorry, that the battery was fine the day before... You know something is wrong when your car don't boot with a brand new battery. They gave me a 30 quid discount and freshly made battery :-)
__________________
i5 2500K@4.3Ghz l Z77 Extreme6 l MSI GTX 570 l Corsair K70 l Crucial M500 l 8.5TB Storage l Seasonic X650 : Corsair K70 : Ikari Optical : Cambridge Soundworks FPS2000 4.1
TheBlackSwordsMan is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
