Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Dec 2012, 10:01   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
Intel brings tri-gate tech to Atom SoCs
Promises 22nm tri-gate SoCs next year.
http://www.bit-tech.net/news/hardwar...tri-gate-soc/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 11th Dec 2012, 12:50   #2
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
Hope they'll be able to dissipate the internal temp better than on Ivy Bridge cpus ....
GuilleAcoustic is online now   Reply With Quote
Old 11th Dec 2012, 15:52   #3
OWNED66
Multimodder
OWNED66 has yet to learn the way of the Dremel
atoms never had IHSs
OWNED66 is offline   Reply With Quote
Old 11th Dec 2012, 16:00   #4
GuilleAcoustic
Ook ? Ook !
true
Reply
Tags
22nm, atom, cpu, finfet, intel, intel atom, ivy bridge, soc, system on chip, tri-gate, tri-gate transistor
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
