Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Dec 2012, 10:30   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Toshiba outs high-performance STT-MRAM technology
Could replace SRAM cache in future devices.
http://www.bit-tech.net/news/hardwar...iba-stt-mram/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 11th Dec 2012, 21:20   #2
Viking
What's a Dremel?
Viking has yet to learn the way of the Dremel
Seems to be a lot of memory technologies "just around the corner"... when will any of them become a reality..
Memory performance really need to start to improve
Viking is offline   Reply With Quote
Old 12th Dec 2012, 04:17   #3
schmidtbag
Supermodder
schmidtbag has yet to learn the way of the Dremelschmidtbag has yet to learn the way of the Dremel
Agreed on the first part, not so much the 2nd. RAM doesn't really to improve, its already plenty fast enough and it isn't a bottleneck. What needs to happen is to lower latencies, or at least spread the ratio between latencies and higher frequencies. Although what REALLY needs to happen is quadruple memory channels, especially for AMD. While the 8 and 12 core optersons support that, today I don't see much of a point in having 2 slots per channel anymore.
schmidtbag is offline   Reply With Quote
Reply
Tags
cache, cache memory, magnetoresistive, memory, mram, spin-transfer torque, sram, static ram, stt-mram, toshiba
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
