Reply
Thread Tools View Mode
Old 11th Dec 2012, 23:49   #1
TheGreatSatan
Dark Lord of BT!
TheGreatSatan's Avatar
TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.
Borderlands 2 Loot Box PC
I love Borderlands 2 and will be putting a Mini-ITX system in the Limited Edition Loot Box!
__________________
2011-3 WET DREAM MACHINE
MountainMods U2-UFO with an Intel i7 5960x (8-Core), MSI X99S-SLI, 32GB (4GB x 8) DDR4, 960GB Crucial M500, 1TB Samsung 850 Pro, 240GB Sandisk Extreme, Corsair AX1500i 80 Titanium, GTX Titan X, a Corsair H80i and 15 Green LED Coolmax fans!
TheGreatSatan is offline   Reply With Quote
Old 12th Dec 2012, 00:28   #2
Panomama
I once signed up on uniform dating
Panomama's Avatar
Panomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpitPanomama is almost as Godly as yodasarmpit
Gonna be awesome
Subbed!
__________________
♦Steam♦ ⚔⚔⚔⚔ ♠Youtube♠ ⚔⚔⚔⚔ ♣Website♣
Panomama is offline   Reply With Quote
Old 12th Dec 2012, 00:35   #3
atc95
I have the upgrade bug!
atc95's Avatar
atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.
This will be incredible , how big are the loot boxes?
__________________
PC: It's a work in progress, but isn't it always...
Check us out on twitch at https://www.twitch.tv/digitalbacongaming
atc95 is offline   Reply With Quote
Old 12th Dec 2012, 19:15   #4
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
If I had bought the LE of Borderlands2, I would have done the same! LoL
But I think that you would have to repaint it for more realism and take away that plastic feeling...
@atc95: That box is quite big... 30 or 40 centimetres long maybe? I don't know exactly, but they are enough for an mini-ITX system for sure!
Ra6 is offline   Reply With Quote
Old 14th Dec 2012, 14:25   #5
TheGreatSatan
Dark Lord of BT!
I'm waiting for the box to come and finalizing the specs, which are:
Intel 2500K
Gigabyte H61-USB3
8GB DDR3
Radeon 6850
600 Watt Modular PSU
120GB SSD
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
