Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Dec 2012, 08:28   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Intel launches 6-8W Atom S1200 server chips
Takes aim at the cloud computing, micro-server markets.
http://www.bit-tech.net/news/2012/12...-atom-server/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 13th Dec 2012, 06:29   #2
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
Speaking as an AMD fanboy, I can only say, SHUT THE HELL UP ALREADY.
All this just comes across as petty and weak - you didn't see Intel pissing on AMD when Bulldozer turned out to be a massive failure. Or when Piledriver turned out to be less than it should have been.
Enough already, AMD. Keep your heads down and hope and pray that Steamroller gets AMD competitive with more than the lowest-end i3s...when it's Intel's dual-core versus AMD's 8-core.
fluxtatic is online now   Reply With Quote
Old 14th Dec 2012, 01:03   #3
yougotkicked
A.K.A. YGKtech
yougotkicked's Avatar
yougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremel
That last line kills me, and fills me with hope at the same time. I was doubtful whether intel was actually committed to the massively-multithreaded concept until I saw that price break. I'm betting we'll see server boards come out with support for many processors on riser cards, no one wants a thousand processors if it means they need a thousand motherboards, power supplies, cases etc.
just to put 6W in perspective, you could power a server farm's worth of these chips without breaking a sweat on a stationary bike.
__________________
Corsair Carbide 500R ::::: NINE (!) case fans
Intel I5 2500K @ 4.5Ghz ::::: AIR cooled (modified tuniq tower 120)
Asus P8Z68-V LX ::::: 16GB 1866 9-9-9-27-1T (1.4v) Samsung low profile 30nm's
Gigabyte Radeon HD 6870 1GB ::::: 1TB Samsung Spinpoint F3
128GB Intel SSD :::: 2x WD 1TB drives in RAID 1
yougotkicked is offline   Reply With Quote
Reply
Tags
amd, arm, atom s1200, atom s1220, atom s1240, atom s1260, atom server, cortex-a50, data centre, intel atom, seamicro, server, server soc, soc, system on chip
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
