Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Dec 2012, 09:28   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Be Quiet! Shadow Rock TopFlow SR1 review
http://www.bit-tech.net/hardware/coo...w-sr1-review/1
brumgrunt is offline   Reply With Quote
Old 13th Dec 2012, 11:43   #2
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
are there more cooler reviews still to come? you could at least round the bad / mediocre ones into one article
greigaitken is offline   Reply With Quote
Old 13th Dec 2012, 12:08   #3
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
I got one of these a few months back, the installation is a pig and whilst not tall it is incredibly large, I would also advise that cramped mATX installs may also experience difficulty depending on the CPU placement of the particular board (I had to remove a case fan and a drive cage). Ideally you want to measure up the cooler orientation so it does not overhang the board which may or may not be possible.
__________________
Main rig: i7 2600K + Corsair H75 | P8Z77-M Pro | 8GB DDR3 | MSI GTX 970 4G + NXZT G10 + Corsair H75 | Xonar DX | 840 EVO + 850 EVO RAID0 1TB stripe | F4 2TB | NXZT Hale 650W | Carbide 240 Air | U2713HM
HTPC: A10 5800K | GA-F2A75M | 8GB DDR3 | EVGA GTX 950 SuperClock+ | Be Quiet! TopFlow | M4 512GB | F4 2TB | Lian Li PC-V355B
Server: Xeon E3-1240L v3 | ASRock E3C226D2I | 16GB ECC DDR3 | Fujitsu D2616 RAID | Seagate XT 500GB | MX100 256GB | 5 x 4TB HDD (RAID 5) | SilverStone DS380
Bungletron is offline   Reply With Quote
Old 15th Dec 2012, 14:08   #4
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
... how come the lga1155 score is a .jpg while the amd score is a .gif?
__________________
I'm spending a year dead for tax reasons. - Douglas Adams
Wanna help me and get cloud storage? Use Dropbox http://db.tt/msbUQQC
improprietary is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
