Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Dec 2012, 10:49   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Internet Explorer bug tracks your mouse cursor
No patch planned, says Microsoft.
http://www.bit-tech.net/news/bits/20...e-bug-cursor/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 13th Dec 2012, 10:58   #2
will_123
Small childs brain in a big body
will_123's Avatar
will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!will_123 - it's over 9000!!!!!!!!1!1!1!!!
Dont use it. Chrome or Firefox for me, but its worrying that they dont intend to patch it.
__________________
i5 3570k @ 4.5GhZ | Fractal Arc Midi | H100i | Twin Frorz 7870 | 8GB Crosair 1600MhZ |
Website - https://www.kerneltalk.co.uk/
BF3 - Pvt_Will123 Steam - hardcorewillie
will_123 is offline   Reply With Quote
Old 13th Dec 2012, 11:01   #3
ShinyAli
Supermodder
ShinyAli's Avatar
ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!
Before I and probably some others go off on an anti IE rant has anyone tested other browsers for this exploit
ShinyAli is offline   Reply With Quote
Old 13th Dec 2012, 11:03   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Yes, and they're not affected: it's specific to IE, as the article explains.
__________________
Old 13th Dec 2012, 11:50   #5
Bede
Ultramodder
Bede's Avatar
Bede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run CrysisBede can run Crysis
I'm confused as to why Microsoft don't want to patch it. Is it a common occurrence to leave security holes open in software?
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | MSI GTX560Ti HAWK | 16gb Corsair Vengeance LP 1600Mhz 1.5V | Gelid Tranquillo | Asus Xonar DS | 700W Coolermaster Silent Pro M | Corsair Force Series 3 60GB | Crucial M4 128GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 13th Dec 2012, 11:52   #6
Anfield
Supermodder
Anfield has yet to learn the way of the DremelAnfield has yet to learn the way of the Dremel
Microsoft says they have no plan to patch it soon? kind of funny considering what they recently tried against android on twitter.
Anfield is offline   Reply With Quote
Old 13th Dec 2012, 12:03   #7
general22
Multimodder
general22 has yet to learn the way of the Dremel
This is pretty much useless without some way to see what the user is looking at onscreen. MS are generally good with security updates and patching this probably isn't worth it.
general22 is offline   Reply With Quote
Old 13th Dec 2012, 12:18   #8
steveo_mcg
STILL ALIVE
steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.
You sufer from a lack of imagination my friend. With a 6x6+1 on-screen keypad it would be fairly trivial to see a code Advertisers would love to see exactly where people are placing their mouse as then they can stick ads right under your nose. And those are just the two examples in the article the more imaginative will probably have even better ideas.
Besides all that if there is a security hole of any shape it should be patched soon after its discovered, it might be a "useless" thing to day but who knows how it will morph. Fit the lock before the horse even realises there is a door.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 13th Dec 2012, 12:22   #9
Snips
I can do dat, giz a job
Snips's Avatar
Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.Snips is the Cheesecake. Relix smiles down upon them.
Well the biggest and best do tend to get a few knocks every now and then. I don't foresee a problem here.
Snips is offline   Reply With Quote
Old 13th Dec 2012, 12:26   #10
Corky42
Multimodder
Corky42 has yet to learn the way of the DremelCorky42 has yet to learn the way of the DremelCorky42 has yet to learn the way of the Dremel
Maybe because they cant, maybe fixing it will mean disabling some important feature.
Its not good to say your not going to fix a security related bug as that is all most people will take away from it, that M$ isn't worried about peoples security.
Corky42 is offline   Reply With Quote
Old 13th Dec 2012, 13:14   #11
Snips
Snips's Avatar
I'd take it with a pinch of salt as this is not an official Microsoft statement. When they come out and state "they aren't doing anything about it" maybe then believe it but at the moment it's one companies word or a small company trying to gain some exposure?
Old 13th Dec 2012, 15:13   #12
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
I can just imagine an advert following the cursor around the screen. That would be very annoying, and I too wonder why Microsoft isn't going to patch it?
fdbh96 is offline   Reply With Quote
Old 13th Dec 2012, 21:03   #13
Snips
Snips's Avatar
Where did it say above that Microsoft said they weren't going to patch it? I didn't see any statement from Microsoft above or anywhere else.
Old 13th Dec 2012, 23:12   #14
Gradius
IT Consultant
Gradius has yet to learn the way of the Dremel
I don't use IE since 2007.
Gradius is offline   Reply With Quote
Old 13th Dec 2012, 23:16   #15
Corky42
Multimodder
I have never know Microsoft to publish details of a bug before they release the update to fix it, normally you get the update and they give details of what that update fixes.
Old 14th Dec 2012, 06:30   #16
SimonStern
Registered Lurker
SimonStern's Avatar
SimonStern has yet to learn the way of the Dremel
I posted about this in software yesterday and nobody seemed to care lol
http://forums.bit-tech.net/showthread.php?t=253175
__________________
I may not be playing with a full deck, but I still deal...
Steam: SimonStern PSN: OvaltineJenkins3
SimonStern is offline   Reply With Quote
Old 14th Dec 2012, 07:00   #17
Gareth Halfacree
WIIGII!
bit-tech Staff
Article updated with official comment from Microsoft: apparently a patch, of sorts, is in the pipeline.
__________________
Old 14th Dec 2012, 09:29   #18
LordPyrinc
Legomaniac
LordPyrinc's Avatar
LordPyrinc has yet to learn the way of the Dremel
I use IE and have recently experienced a temporarily unresponsive mouse on more than one occasion, usually lasts between 3 to 5 seconds. Considering that the mouse is wireless, I first thought it was a battery issue, but after replacing the battery the problem has happened again. If I recall correctly, most of the incidents happened on a very popular news site, formerly known as MSNBC. The plethora of ads on the site and pop-ups that get blocked sometimes crashes the browser and requires IE to try to automatically recover as well.
__________________
Intel i7-920 @ 2.66GHz - CORSAIR 6GB DDR3 @ 1600MHz - Windows7 64bit
2 x 150GB WD VelociRaptor HDs (RAID 0) - 1TB WD 7200 rpm HD - Antec 850W TruePower Quattro
2 x EVGA GeForce GTX 550Ti 2GB Superclocked (Dual SLI) - 27" Samsung S27B550 LED Display
HP Pavilion Elite m9040n - Q6600 @ 2.40GHz - 3GB DDR2 - Vista 32bit - BFG GeForce 9800 GT
LordPyrinc is offline   Reply With Quote
Old 14th Dec 2012, 20:18   #19
Snips
Snips's Avatar
'From what we know now, the underlying issue has more to do with competition between analytics companies than consumer safety or privacy. The only reported active use of this behavior involves competitors to Spider.io providing analytics.'
What was it I said earlier? exactly that
Old 14th Dec 2012, 20:29   #20
ShinyAli
Supermodder
ShinyAli's Avatar
Maybe not,
UPDATE 2012-12-14
Microsoft's Dean Hachamovitch, corporate vice president in charge of Internet Explorer, has issued a statement on the matter. 'We are actively working to adjust this behavior in IE. There are similar capabilities available in other browsers. Analytics firms can expect to do viewpoint detection in IE similarly to how they do this in other browsers,' Hachamovitch claimed.
Reply
Tags
advertising, analytics, ie 10, ie 6, ie 7, ie 8, ie 9, internet explorer, security, spider.io, tracking, vulnerability, windows 8
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
