#1 |
WIIGII!
bit-tech Staff
Nvidia Tegra 4 'Wayne' specs leak ahead of launch
Cortex-A15 SoC to get CES or MWC launch.
http://www.bit-tech.net/news/hardwar...nvidia-wayne/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
Bit-Tech/Asus OC Winner
O.O
__________________
XFXScorpio911 ¦ PHENOM II X4 965 @ 4.02Ghz ¦ SLI GTX 480 1536MB¦ ASUS CROSSHAIR II FORMULA ¦ 4GB OCZ REAPER 1066 5-5-4-8 2T¦ CORSAIR HYDRO H50 ¦ CORSAIR F60 ¦ WINDOWS 7 HP 64bit ¦ Musings On The Technical World ¦ Steam |
#3 |
I Mod, Therefore I Own
Dont see how they will get a quad core to last more than a few hrs in a phone if its been used.
#4 | |
WIIGII!
bit-tech Staff
Given that the Tegra 4 will be a lower-TDP 28nm part, I shouldn't think battery life will be a problem.
__________________
#5 | |
I'm a cat, not a furry.
^Plus, it has a "companion" core. It switches between it and the main. It's lower-clocked, and the two sets are never used at the same time.
__________________
#6 | |
Supermodder
#7 |
There is no rep for awesomeness.
Moderator
Companion core should take care of that.
Sounds like something from Portal...
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#8 | ||
Supermodder
#9 |
I dont really consider 3-4hrs of real usage great battery life. If i play a game on my samsung SG3 it lasts about 2-3hrs maximum, Before i get the 10% warning.
Yes if i use it as a phone email device it lasts the day but any form of music playing / light gaming and your taking the charger to work with you if you want it to last a full day. Note 2 has good battery life if you dont really use it, Same as any smartphone. Put any sort of usage onto a smartphone be it web browsing 3d gaming or otherwise and the battery just tanks. No smartphone has good battery life at the minute if you really use it as a smartphone. 3-5hrs is the best you can hope for with consistant usage. Would personally like to see a longer battery life even if speeds were a touch slower on these quad core phones ( do we even need a quadcore phone, All the SG3 needs is a faster GPU the CPU in it is fast enough) |
#10 |
Ghost In The Machine
I wish people would stop complaining about the battery life of smart phones. It is what it is. You are getting a device that has that latest and greatest technology hardware and then complain that they don't last as long as old style mobiles. That is like buying a super car to replace your economical one and then complaining because it guzzles the petrol. You are not buying a smart phone for its battery, but for what it can do. If you want long lasting performance try buying an old style phone instead,
__________________
Motherboard - ASUS P5K Premium CPU - Q6600 @ 3GHz - Arctic Freezer 13 GPU - Palit 9600GT @ Clock 750MHz - Mem 1100MHz - Shader 1850MHz RAM - 6GB Corsair PC2-6400 DHX @ 960MHz
OS - Windows 7 Ultimate (64bit) |
#11 | |
GIFted
I need my phone to work from 9am - 5pm as I am out of the office a lot, no phone does that yet.
__________________
#12 |
ARM Evangelist
Looking forward to seeing the SBCs are based on this. Quad-core tegra with full OpenGL compatibility? Sign me up.
Though somehow I suspect that the price tags, at least for reference boards, will be rather eye-watering at first...
__________________
What's that? You don't care about my site? I don't care that you don't care - I'm going to spam you with the link anyway. Why yes, I do have a YouTube channel on which I put out Minecraft videos on a somewhat "regular" basis, thank you for asking. |
#13 | ||
__________________
#14 |
Design Warrior
Where is this "3-4hours" battery life coming from? You would have to be pretty much constantly downloading over 3G to burn that much power. Are you running loads of crapware apps that are loading adverts?
I've got a Nokia E6 that does 2 or 3 days on one charge. I have it syncing on 2 email accounts, and each day do ~6 hours of listening to music and ~1hour of browsing. I know plenty of people with similar use patterns that get over a day from their Android phones. |
#15 |
STILL ALIVE
Want more battery, buy a bigger battery! Sure it "ruins" the lines of the phone but if it extends the utility of the phone it must be worth it.
__________________
ook |
#16 | |
'I want, I want, I want...'
__________________
#17 |
Diagnosis: ARMAII-Holic
I
#18 |
I have had the LG optimus 2x and now the 4X models (cores respective to their names) being tegra 2 and tegra 3 respectively, and I have to say im extremely impressed with Tegras capablities. Non gaming on my LG 4X battery power lasts much longer than expected for a quad core. Standby mode lasts even longer still. Shame im now on a 24 month contract for my newer model, as 12/18 month contracts were unfortunately higher initial upfront payments to get. Tegra4 with all the above with the possibility of same or better battery life. If youy havent got a tegra based phone and enjoy games/hd movies/ plugging your phones into HD TV'S at a friends house, you NEED one of these. Best handheld technology purchases in my honest opinion.
#19 |
Supermodder
| Tags |
| arm, ces, cortex-a15, cortex-a9, kal-el, mwc, nvidia, soc, system on chip, tegra, tegra 2, tegra 3, wayne |
| Thread Tools | |
