Old 20th Dec 2012, 03:37   #1
penryn 2 hertz
Hey, ho, pip and dandy moment's...
penryn 2 hertz's Avatar
penryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for presidentpenryn 2 hertz should be considered for president
PSU needed to run a GTX 295
Hello i would like to add a Gtx 295 to the team but the psu i need to power it are really expensive i have everything to knock up a rig using a core 2 duo 2.1ghz is there anyone willing to help me out with finding a psu or donating one...
__________________
Under progress...
penryn 2 hertz is offline   Reply With Quote
Old 20th Dec 2012, 09:25   #2
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpit
What power level are you wanting? I know the GTX 295 needs up to 285 W and 1 x 6-pin + 1 x 8-pin, so if it'll be the only PSU in the system 550-600W should do, but don't know what else is in the system...
I have thought about adding a GTX 295 as well, alongside the 570 in my SB build, seems like a good idea now we can get QRB with them
__________________
Folding stats
debs3759 is offline   Reply With Quote
Old 20th Dec 2012, 09:26   #3
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
can we??
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 20th Dec 2012, 13:02   #4
debs3759
debs3759's Avatar
Some Beta wu give a QRB, there was a thread about this recently
__________________
Folding stats
Old 20th Dec 2012, 13:34   #5
kirk46
Cheesecake Nom Nom
kirk46's Avatar
oh yeah but they have stopped it now those WU's have gone back to the internal beta testers
__________________
Old 20th Dec 2012, 22:02   #6
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Has the 'unequal number of shaders effect' really gone away? I'm getting curious numbers with GTX 570, 560 Ti, and 560 Ti 448 cores running in one machine.
And I'm fairly certain the beta tests for the QRB were for GTX 400 series and upward.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 20th Dec 2012, 22:16   #7
debs3759
debs3759's Avatar
I didn't realise it was only for 400 series and later, or that it had ended. My ppd is about 25% higher now than pre-beta.
What's the 'unequal number of shaders effect'? I have a 460 GTX and a 550 Ti I might add for the winter if they won't have an adverse effect. Been sorting my collection to see what might be of use
__________________
Folding stats
Old 21st Dec 2012, 00:00   #8
Christopher N. Lew
At the beginning of December 2012 the GPU WUs were 'rebenchmarked', and most of the points went up. Some new WUs were released which take significantly longer than usual to complete, but score well. Both of these changes are independent of the beta-test QRB for GPU WUs.
The 'unequal number of shaders effect' was a nasty little surprise for people who mixed different cards in their machines - basically if they weren't GPUs of the same generation with the same number of shaders, one or more of the cards folded more slowly than it would on its own. This was compounded by nVidia using a crazy naming system at the time of 8800 and 9800 series, so that the generations were not clearly differentiated. The problem eventually appeared to go away with a rewritten core and a driver update.
Mixing GPUs of different architectures is unlikely to give predictable behaviour, even now.
__________________
Folding stats
Old 21st Dec 2012, 02:21   #9
penryn 2 hertz
But the thing is guys i need a power supply lets not run away here...
__________________
Under progress...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
