#21 |
Shut up and Mod
Nice start!
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#22 |
Hypermodder
Ty Furball!
#23 |
Hypermodder
Parvum build Almost ready to run, so i can go build this guy further
#24 |
Car lover and Speed Junkie
HEEEEERRE..... WEEEEEE..... GO!
#25 | |
Dale you're on a roll...
It's odd, manufacturers sometimes put so much effort into making ther GPU coolers look impressive, and then they're gone an put in upside down in most cases, exposing the usually dull PCB instead of the fancy cooler. Naturally this is often a moot point in watercooled builds, but standard air builds often suffer from this IMO.
__________________
Project Azure - MotM Februaray 2013 Nominee
#26 |
Hypermodder
Parvum commin to an end almost (or not
) but progress was needed!Did some things today 2x Gtx 470 incl all EK assecoires, littlte older then people wanna see in buildlogs, but hey, Low budget = me ![]() ![]() ![]() ![]() ![]() I will make Custom tops for the blocks Did also some work on the case, finished the top (the big works) and pop rivited the whole chassis! ![]() ![]() ![]() ![]() ![]() ![]() Gonna create my own feet and gonna remake the back panel, also goin to remake the whole inside! |
#27 |
Hypermodder
Update
![]() Few days back i had allot of scrap plexi, (thanks to father in law ) normally would take 1.5mm alu, but hey, some quality plexi is also a good thing !![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Need to wait on some rads who are still in production soon i wil buy 6pumps/tops: http://www.highflow.nl/pompen/andere...ion-13154.html + http://www.highflow.nl/pompen/andere...top-13136.html . (dual loop) Because i can u know :P just some crazy ass loops! 2loops Loop1: RES-3xPUMP-360(backpanel )-GPU-GPU-RES. Loop2: RES-3xPUMP-360(frontpanel )-CPU-MEM-RES. |
#28 |
Methinks your gonna pimp out that acrylic and were gonna see some K3nney brightpanel awesomeness.
#29 |
Minimodder
Keep it up, buddy! Really great ideas!
#30 |
Multimodder
Love to watch your work. they are allways awesome.
#31 |
Hypermodder
Thnks guys, gonna do my best
#32 |
Supermodder
Hmmmm, I can't see the pictures...
__________________
Current projects: Graphite 5 | Tydirium is on the way! Previous mods:|Sandcrawler Mod| |Illuminated Mind| Follow me on Facebook |
#33 |
Hypermodder
i can? hmm gonna ask some mates
![]() EDIT: there working for 5 random people, think its your problem
#34 |
Looking really cool so far, plexi work is always fun.
Just a quick question about working with acrylic tubes. I know you're not using them in this project, but I thought I'd kill two birds with one stone. Did you use Bitspower Multi-link fittings for the acrylic, or similar ones? I'm a little stuck as to which fittings to order, would rather not get completely the wrong thing as I know not all will fit acrylic tubing. Cheers!
__________________
#35 |
Hypermodder
Bitspower C47
#36 |
Yeah, having the same problem. Not on my end though as I only happens on your thread. Started last night when I checked for updates. Everyone else I can view a-ok
#37 |
Hypermodder
wierd
#38 |
Hypermodder
Update
!!Custom front door, Gonna weld the grill into the door ![]() ![]() ![]() ![]() ![]() Also gonna weld this under airfilter handle thing into the front: ![]() ![]() ![]() The front will be made in one piece, i am going to weld the door also, Clean as a Muttertrucker Also did mounted all the plexi panels because one of these days my rads will come with the mail i needed to be sure it would fit the 8CM!(yes 8!) thick rads ![]() ![]() ![]() ![]() ![]() ![]() Hardware test fit, so i cant make a mistake with the rads ![]() ![]() ![]() see u on the next one. |
#39 |
Hypermodder
Double post YO!
#40 |
Hypermodder
Update!
Did allot today, alle the panels are done! (exclusive the rad cut-outs) NOTE! some pics are edited, Some parts i cant show! (secret stuff )Starting with the hardware AGAIN in the case, so everything get the fit as is should! ![]() Mounted and drilled everything for the panel support and connection. ![]() Rad support 1 ![]() ![]() ![]() Rad support 2 ![]() ![]() Midspeed triebs <3 ![]() getting everything lined up and test mounting it! ![]() ![]() ![]() also i figured out how to connect the first line of 3 pumps, so i could make the support and the connection tabs ![]() ![]() ![]() ![]() ![]() See u soon on the next update
| Thread Tools | |
| View Mode | |
