#1 |
What's a Dremel?
NFusion - IgnitiOn Project 19-FEB-2013
![]() For quite some time I've be following bit-tech forums and I decided to upload my IgnitiOn Project. For IgnitiOn build, I will make a BIG mATX (i know, sounds ridiculous ) modular case that can comfortably house mATX motherboard with all the components and allot of water cooling kit.The case dimensions are 500mm x 700mm x 260mm #H x L x W) and will be made out of acrylic. OK let's get it started. ![]() My little helper. I will be using CNC for cutting acrylic sheets. ![]() ![]() Welding case feet using Tensol 12. ![]() PSU and radiator intakes will be filtered. ![]() Cutting more panels ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Starting to look like PC case ![]() ![]() Im using tapping drill for M4 screws ![]() Welding L pieces, which hold panels togethr and make my case modular. ![]() ![]() Next up is making drive bays, side panel with window and painting. Last edited by NFusion; 20th Feb 2013 at 16:30. |
#2 |
Professional Sleever & Modder
WOW, Amazing dude!
This is so great to watch on, i would love to see some videologs or something !
#4 |
Keep calm & mod on. =)
Very nice,
keenly subbing. ![]() Oh yeah, welcome to bit-tech.
#5 |
Fenrir The Wolf
I like this very much. My favourite material.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#6 |
Hypermodder
Good start, Subbed
#7 |
What's a Dremel?
#8 |
What's a Dremel?
NFusion - IgnitiOn Project 6-JAN-2013
UPdate.
![]() Half of the dive bay holder. ![]() Motherboard panel, Drive and HDD bays are finished. ![]() Time to star painting. I always liked blue color, so blue and black it is. ![]() The resut. ![]() Close up. ![]() Cutting out window. ![]() ![]() Fits like a glove. ![]() Finnished case. I'm very happy with the case, but i still have allot of work to do. Have to install components, do cable sleeving, all watercooling stuff... Last edited by NFusion; 23rd Jan 2013 at 11:32. |
#9 |
Multimodder
Dude that's sweet, some nice touches there!
What sort of kit are you putting in it? I'll be following this!! |
#10 |
Multimodder
Looks wonderful, great job!
#11 |
Fenrir The Wolf
I like this very much. Looks great.
Can't wait for more pics.
__________________
#12 |
Need help with scratchbuild!
Subbed, love the paint!
__________________
i5 3550 // gigabyte g1 sniper m3 // xfx 7950 dd @ 1ghz // 2x4gb C. Vengeance // samsung 256gb 830 // 750gb scorpio black // silverstone tj08be // enermax ets t40 tb // ocz modXstream pro 700w // Dell u2412m // IBM 17" tft. Xbox PC mod (nearly finished): a10 5800k @ 4.6ghz, h100i, msi fm2 a75ia, 8gb samsung greens, 256gb sandisk ultra!
#13 |
wont you polish the plastic first ?
#14 | |
What's a Dremel?
Thank you all for your support.
I dont polish plastic because im going for matt black finish, so i use very fine sandpaper on panels and on the edges. But the case will go through thorough cleaning before instalation of the components. |
#15 |
Multimodder
looks cool
#16 |
What's a Dremel?
Update 16-JAN-2013 - Components
Update: The Components
Motherboard: ASRock Z77 Extreme4M CPU: Intel Core i5-3570k GPU: 2x Powercolor Radeon HD 7950 SSD: Corsair Force 3 240GB Memory: Corsair Vengeance 16GB PSU: XFX ProSeries XXX-Edition 850W Fan Controler: NZXT Sentry LX ![]() I'm still waiting for some watercooling stuff to show up, so that will be next up and i will also reveal a surprise. Last edited by NFusion; 16th Jan 2013 at 16:04. |
#17 |
Multimodder
Superior machinery + cool idea = *thumbs up*
Nice case and beautiful hardware. |
#18 |
What's a Dremel?
Now for a surprise.
I dont know how many of you noticed big cut outs for fans. The case will have 5x 18cm fans all for watercooling with Magicool water blocks. Cooling surface is 3,75 times greater than a single standard 360. This will allow me to set fans on very low speed with fan controler and still have allot of cooling power and a very quiet case. For the comparison, 3x Magicool vs standard 360: ![]() So watercooling compoents will be: 2x Magicool 180mm dual radiator 1x Magicool 180mm single radiator 2x EK-FC7950 EK-Supreme LTX 2x EK-DCP 4.0 EK-Multioption X2 RES 250 Primochill PrimoFlex Pro Tubing and EK Fittings (waiting to arrive) ![]() Next mission, installing components. Last edited by NFusion; 23rd Jan 2013 at 10:50. |
#19 |
What's a Dremel?
Update: I had a fun painting fans and filtering intake, so the intake air is all filtered.
![]() ![]() All the equipment and tools. ![]() ![]() ![]() Primer first, then neon blue color. ![]() ![]() ![]() I also made this shield for all radiators. This rad goes to the bottom compartment. ![]() A BIG ass radiators with BIG ass 18cm fans cheesecake |
#20 |
Multimodder
Very nice mate.
__________________
Urban Camouflage
| Thread Tools | |
| View Mode | |
